uhd::rfnoc::addsub_block_control Class Reference
#include <uhd/rfnoc/addsub_block_control.hpp>
Inheritance diagram for uhd::rfnoc::addsub_block_control:
Add/Sub Block Control Class
The Add/Sub RFNoC block takes in two streams of sc16-formatted data and performs addition and subtraction on the data in the stream, creating two output streams consisting of the sum and difference of the input streams. The block assumes that the input and output packets are all of the same length.
using make_args_ptr = std::unique_ptr< make_args_int_t, make_args_deleter >
 Opaque pointer to the constructor arguments with custom deleter. More...
enum class  action_mode_t { SYNC , ASYNC }
 Action execution modes. More...
using post_action_handler_t = std::function< void(const res_source_info &, action_info::sptr, action_mode_t)>
register_iface & regs ()
void post_action (const res_source_info &edge_info, action_info::sptr action, action_mode_t mode=action_mode_t::SYNC)
