USRP Hardware Driver and USRP Manual  Version: 4.9.0.0
uhd::rfnoc::fir_filter_block_control Class Referenceabstract
#include <uhd/rfnoc/fir_filter_block_control.hpp>
Inheritance diagram for uhd::rfnoc::fir_filter_block_control:
virtual size_t get_max_num_coefficients (const size_t chan=0) const =0
virtual void set_coefficients (const std::vector< int16_t > &coeffs, const size_t chan=0)=0
virtual std::vector< int16_t > get_coefficients (const size_t chan=0) const =0
static const uint32_t REG_FIR_BLOCK_SIZE
static const uint32_t REG_FIR_MAX_NUM_COEFFS_ADDR
static const uint32_t REG_FIR_LOAD_COEFF_ADDR
static const uint32_t REG_FIR_LOAD_COEFF_LAST_ADDR
static const uint32_t REG_COMPAT_NUM_ADDR
FIR Filter Block Control Class
The FIR Filter Block is a finite impulse response filter block for RFNoC.
The RFNoC FIR block supports one input and output port of sc16 data (16-bit fixed-point complex samples) and a configurable (but fixed) number of taps.
◆ get_coefficients()
virtual std::vector<int16_t> uhd::rfnoc::fir_filter_block_control::get_coefficients ( const size_t  chan = 0) const
Get the filter coefficients
Return a vector with the current filter coefficients.
The vector of current filter coefficients
◆ get_max_num_coefficients()
virtual size_t uhd::rfnoc::fir_filter_block_control::get_max_num_coefficients ( const size_t  chan = 0) const
Get the maximum number of filter coefficients supported by this block
Get the maximum number of filter coefficients supported by this block.
The maximum number of filter coefficients supported by this block
◆ set_coefficients()
virtual void uhd::rfnoc::fir_filter_block_control::set_coefficients ( const std::vector< int16_t > &  coeffs,
Set the filter coefficients
Set the filter coefficients for this FIR block. The number of coefficients must be equal to or less than the maximum number of coefficients supported by the block. If the vector of coefficients passed to this function is smaller than the maximum number of coefficients supported by the block, it will automatically be padded with zeroes. If the vector of coefficients passed to this function is larger than the maximum number of coefficients supported by the block, a uhd::value_error is thrown.
coeffsA vector of integer coefficients for the FIR filter
chanChannel index
◆ MAJOR_COMPAT
const uint16_t uhd::rfnoc::fir_filter_block_control::MAJOR_COMPAT
◆ MINOR_COMPAT
const uint16_t uhd::rfnoc::fir_filter_block_control::MINOR_COMPAT
◆ REG_COMPAT_NUM_ADDR
const uint32_t uhd::rfnoc::fir_filter_block_control::REG_COMPAT_NUM_ADDR
◆ REG_FIR_BLOCK_SIZE
const uint32_t uhd::rfnoc::fir_filter_block_control::REG_FIR_BLOCK_SIZE
◆ REG_FIR_LOAD_COEFF_ADDR
const uint32_t uhd::rfnoc::fir_filter_block_control::REG_FIR_LOAD_COEFF_ADDR
◆ REG_FIR_LOAD_COEFF_LAST_ADDR
const uint32_t uhd::rfnoc::fir_filter_block_control::REG_FIR_LOAD_COEFF_LAST_ADDR
◆ REG_FIR_MAX_NUM_COEFFS_ADDR
const uint32_t uhd::rfnoc::fir_filter_block_control::REG_FIR_MAX_NUM_COEFFS_ADDR
