uhd::rfnoc::lc_block_control Class Referenceabstract
#include <uhd/rfnoc/lc_block_control.hpp>
Inheritance diagram for uhd::rfnoc::lc_block_control:
License Checker Block Control Class
The License Checker Block is a block for RFNoC without any streaming ports. Its sole purpose is to read and evaluate license keys.
virtual bool load_key (const std::string &key)=0
virtual std::vector< uint32_t > get_feature_ids ()=0
register_iface & regs ()
static const uint32_t REG_COMPAT_NUM
static const uint32_t REG_FEATURE_ID
static const uint32_t REG_USER_KEY
static const uint32_t REG_FEATURE_ENABLE_RB
static const uint32_t REG_FEATURE_LIST_RB
using make_args_ptr = std::unique_ptr< make_args_int_t, make_args_deleter >
 Opaque pointer to the constructor arguments with custom deleter. More...
enum class  action_mode_t { SYNC , ASYNC }
 Action execution modes. More...
using post_action_handler_t = std::function< void(const res_source_info &, action_info::sptr, action_mode_t)>
void post_action (const res_source_info &edge_info, action_info::sptr action, action_mode_t mode=action_mode_t::SYNC)
◆ get_feature_ids()
virtual std::vector<uint32_t> uhd::rfnoc::lc_block_control::get_feature_ids ( )
Return a list of feature IDs this block is managing
◆ load_key()
virtual bool uhd::rfnoc::lc_block_control::load_key ( const std::string &  key)
Load a license key into the checker
Get the maximum number of window coefficients supported by this block.
keyThe channel to retrieve the maximum number of coefficients from
True if the key was successfully loaded. This does not mean that the key was valid, only that loading the key worked.
◆ MAJOR_COMPAT
const uint16_t uhd::rfnoc::lc_block_control::MAJOR_COMPAT
◆ MINOR_COMPAT
const uint16_t uhd::rfnoc::lc_block_control::MINOR_COMPAT
◆ REG_COMPAT_NUM
const uint32_t uhd::rfnoc::lc_block_control::REG_COMPAT_NUM
◆ REG_FEATURE_ENABLE_RB
const uint32_t uhd::rfnoc::lc_block_control::REG_FEATURE_ENABLE_RB
◆ REG_FEATURE_ID
const uint32_t uhd::rfnoc::lc_block_control::REG_FEATURE_ID
◆ REG_FEATURE_LIST_RB
const uint32_t uhd::rfnoc::lc_block_control::REG_FEATURE_LIST_RB
◆ REG_USER_KEY
const uint32_t uhd::rfnoc::lc_block_control::REG_USER_KEY
