uhd::rfnoc::logpwr_block_control Class Reference
#include <uhd/rfnoc/logpwr_block_control.hpp>
Inheritance diagram for uhd::rfnoc::logpwr_block_control:
Log Power Block Control Class
The Log Power Block is an RFNoC block that takes in a packet of signed 16-bit complex samples and computes an estimate of 1024 * log2(i^2 + q^2), putting the result in the upper 16 bits of each 32-bit output sample.
using make_args_ptr = std::unique_ptr< make_args_int_t, make_args_deleter >
 Opaque pointer to the constructor arguments with custom deleter. More...
enum class  action_mode_t { SYNC , ASYNC }
 Action execution modes. More...
using post_action_handler_t = std::function< void(const res_source_info &, action_info::sptr, action_mode_t)>
register_iface & regs ()
void post_action (const res_source_info &edge_info, action_info::sptr action, action_mode_t mode=action_mode_t::SYNC)
