uhd::rfnoc::node_accessor_t Class Reference
Special class which may access nodes. More...
#include <uhd/rfnoc/node_accessor.hpp>
For the sake of property resolution, we require access to certain private members of nodes. Instead of giving everyone access to everything, we create this accessor class to allow by-passing the access control.
This class is not meant to be used by users of the RFNoC API, but in certain corner cases, it may be useful for RFNoC block developers. One main use case is unit tests, where we need to access the internals of nodes to test their functionality (e.g., by reading hidden state). It is not considered good practice to use this class in production code, as it breaks encapsulation.
using prop_ptrs_t = node_t::prop_ptrs_t
void init_props (node_t *node)
void resolve_props (node_t *node)
template<typename PredicateType >
node_t::prop_ptrs_t filter_props (node_t *node, PredicateType &&predicate)
void clean_props (node_t *node)
void set_resolve_all_callback (node_t *node, node_t::resolve_callback_t &&resolver)
void clear_resolve_all_callback (node_t *node)
void set_graph_mutex_callback (node_t *node, node_t::graph_mutex_callback_t &&mutex)
void clear_graph_mutex_callback (node_t *node)
void forward_edge_property (node_t *dst_node, const size_t dst_port, property_base_t *incoming_prop)
void set_post_action_callback (node_t *node, node_t::post_action_handler_t &&post_handler)
void send_action (node_t *node, const res_source_info &port_info, action_info::sptr action)
void post_action (node_t *node, const res_source_info &edge_info, action_info::sptr action)
bool check_topology (node_t *node, const std::vector< size_t > &connected_inputs, const std::vector< size_t > &connected_outputs)
void shutdown (node_t *node)
◆ prop_ptrs_t
◆ check_topology()
bool uhd::rfnoc::node_accessor_t::check_topology ( node_t *  node,
const std::vector< size_t > &  connected_inputs,
const std::vector< size_t > &  connected_outputs
Check topology for this block
See node_t::check_topology() for details
◆ clean_props()
void uhd::rfnoc::node_accessor_t::clean_props ( node_t *  node)
Mark all properties on this node as clean
See node_t::clean_props() for details.
◆ clear_graph_mutex_callback()
void uhd::rfnoc::node_accessor_t::clear_graph_mutex_callback ( node_t *  node)
Clears the graph mutex callback. Called when node is disconnected from the graph.
See node_t::clear_graph_mutex_callback() for details.
◆ clear_resolve_all_callback()
void uhd::rfnoc::node_accessor_t::clear_resolve_all_callback ( node_t *  node)
◆ filter_props()
node_t::prop_ptrs_t uhd::rfnoc::node_accessor_t::filter_props ( node_t *  node,
PredicateType &&  predicate
Returns a filtered list of properties.
The return list contains all properties that match a given predicate.
◆ forward_edge_property()
void uhd::rfnoc::node_accessor_t::forward_edge_property ( node_t *  dst_node,
property_base_t *  incoming_prop
Forward an edge property to dst_node
See node_t::forward_edge_property() for details.
◆ init_props()
void uhd::rfnoc::node_accessor_t::init_props ( node_t *  node)
Initializes the properties of a node. See node_t::init_props() for details.
◆ post_action()
void uhd::rfnoc::node_accessor_t::post_action ( node_t *  node,
const res_source_info &  edge_info,
Fake a post_action() call from this node
This will call node_t::post_action() (see that for details).
◆ resolve_props()
void uhd::rfnoc::node_accessor_t::resolve_props ( node_t *  node)
Does a local resolution of properties on node.
See node_t::resolve_props for details.
◆ send_action()
void uhd::rfnoc::node_accessor_t::send_action ( node_t *  node,
const res_source_info &  port_info,
Send an action to node
This will call node_t::receive_action() (see that for details).
◆ set_graph_mutex_callback()
void uhd::rfnoc::node_accessor_t::set_graph_mutex_callback ( node_t *  node,
node_t::graph_mutex_callback_t &&  mutex
Sets a callback that the node can call to the mutex to the graph it is connected to. Used for setting properties and propagation.
See node_t::set_graph_mutex_callback() for details.
◆ set_post_action_callback()
void uhd::rfnoc::node_accessor_t::set_post_action_callback ( node_t *  node,
node_t::post_action_handler_t &&  post_handler
Set post action callback for the node
See node_t::set_post_action_callback() for details.
◆ set_resolve_all_callback()
void uhd::rfnoc::node_accessor_t::set_resolve_all_callback ( node_t *  node,
node_t::resolve_callback_t &&  resolver
Set a resolver callback for the node
See node_t::set_resolve_all_callback() for details.
◆ shutdown()
void uhd::rfnoc::node_accessor_t::shutdown ( node_t *  node)
Put a node into shutdown
See node_t::shutdown(), and also noc_block_base::shutdown() for details.
