uhd::rfnoc::siggen_block_control Class Referenceabstract
#include <uhd/rfnoc/siggen_block_control.hpp>
Inheritance diagram for uhd::rfnoc::siggen_block_control:
Siggen Control Class
The Siggen Block is an RFNoC block that acts as a simple function generating source block. The block supports three functions: generating a constant value, generating a sinusoidal wave with a configurable amplitude and phase increment between samples (but with a random initial phase offset), and a noise source.
 RFNOC_DECLARE_BLOCK (siggen_block_control)
virtual void set_enable (const bool enable, const size_t port)=0
virtual bool get_enable (const size_t port) const =0
virtual void set_waveform (const siggen_waveform type, const size_t port)=0
virtual siggen_waveform get_waveform (const size_t port) const =0
virtual void set_amplitude (const double amplitude, const size_t port)=0
virtual double get_amplitude (const size_t port) const =0
virtual void set_constant (const std::complex< double > constant, const size_t port)=0
virtual std::complex< double > get_constant (const size_t port) const =0
virtual void set_sine_phase_increment (const double phase_inc, const size_t port)=0
virtual double get_sine_phase_increment (const size_t port) const =0
virtual void set_samples_per_packet (const size_t spp, const size_t port)=0
virtual size_t get_samples_per_packet (const size_t port) const =0
void set_sine_frequency (const double frequency, const double sample_rate, const size_t port)
register_iface & regs ()
static const uint32_t REG_ENABLE_OFFSET
static const uint32_t REG_SPP_OFFSET
static const uint32_t REG_WAVEFORM_OFFSET
static const uint32_t REG_GAIN_OFFSET
static const uint32_t REG_CONSTANT_OFFSET
static const uint32_t REG_PHASE_INC_OFFSET
static const uint32_t REG_CARTESIAN_OFFSET
using make_args_ptr = std::unique_ptr< make_args_int_t, make_args_deleter >
 Opaque pointer to the constructor arguments with custom deleter. More...
enum class  action_mode_t { SYNC , ASYNC }
 Action execution modes. More...
using post_action_handler_t = std::function< void(const res_source_info &, action_info::sptr, action_mode_t)>
void post_action (const res_source_info &edge_info, action_info::sptr action, action_mode_t mode=action_mode_t::SYNC)
◆ get_amplitude()
virtual double uhd::rfnoc::siggen_block_control::get_amplitude ( const size_t  port) const
Get the amplitude value for noise and sine wave data
Returns the current maximum amplitude of the data generated by the given port on the block. The value only applies to the noise and sine wave functions. Calling this function when in constant mode will return 1.0.
portThe port on the block whose amplitude value to return
Amplitude value
◆ get_constant()
virtual std::complex<double> uhd::rfnoc::siggen_block_control::get_constant ( const size_t  port) const
Get the constant value to generate in constant mode
Returns the current constant value to be generated by the function generator on the given block when the block is configured in constant mode.
portThe port on the block whose constant value to return
Constant value to generate
◆ get_enable()
virtual bool uhd::rfnoc::siggen_block_control::get_enable ( const size_t  port) const
Get the function generator stream enable flag
Returns the current enable flag for function generator stream data from the given port on the block.
portThe port on the block to get the flag from
Function generator stream data enable/disable flag
◆ get_samples_per_packet()
virtual size_t uhd::rfnoc::siggen_block_control::get_samples_per_packet ( const size_t  port) const
Get the number of samples per packet to generate
Returns the current number of samples per packet generated by the function generator on the given block.
portThe port on the block whose samples per packet value to get
Number of samples per packet to generate
◆ get_sine_phase_increment()
virtual double uhd::rfnoc::siggen_block_control::get_sine_phase_increment ( const size_t  port) const
Get the phase increment between samples in sine wave mode
Returns the current phase increment between successive samples generated by the function generator on the given block when the block is configured in sine wave mode.
portThe port on the block whose phase increment to return
Phase increment between samples
◆ get_waveform()
virtual siggen_waveform uhd::rfnoc::siggen_block_control::get_waveform ( const size_t  port) const
Get the function generator waveform type
Returns the current waveform type for the given port on the block.
portThe port on the block whose waveform type to return
Waveform type
◆ RFNOC_DECLARE_BLOCK()
uhd::rfnoc::siggen_block_control::RFNOC_DECLARE_BLOCK ( siggen_block_control  )
◆ set_amplitude()
virtual void uhd::rfnoc::siggen_block_control::set_amplitude ( const double  amplitude,
const size_t  port
Set the amplitude value for noise and sine wave data
Sets the maximum amplitude of the data generated by the given port on the block. The hardware can generate function data with an amplitude between -1.0 and (2^15-1)/(2^15), or approximately 0.99997, so the provided value must reside within this range. However, for convenience, clients may pass 1.0 to get the maximum amplitude that can be generated.
Setting the amplitude applies only to the noise and to the sine wave functions. The value generated when in constant mode is the value that is configured via the set_constant() function. Calling this function when in constant mode will range check the amplitude value, but will otherwise have no impact on the generated signal.
amplitudeAmplitude of sine wave and noise data
portThe port on the block whose amplitude value to set
◆ set_constant()
virtual void uhd::rfnoc::siggen_block_control::set_constant ( const std::complex< double >  constant,
const size_t  port
Set the constant value to generate in constant mode
Sets the value that should be generated by the function generator on the given block when the block is configured in constant mode. The hardware can output a complex value where the real and imaginary components can be between -1.0 and (2^15-1)/(2^15), or approximately 0.99997, so the provided value must reside within this range. However, for convenience, clients may pass 1.0 for either component to get the maximum positive value that can be generated.
constantThe constant value to generate
portThe port on the block whose constant value to set
◆ set_enable()
virtual void uhd::rfnoc::siggen_block_control::set_enable ( const bool  enable,
const size_t  port
Set the function generator stream enable flag
Enables or disables the stream of function generator data from the given port on the block.
enableStream enable/disable flag
portThe port on the block to enable or disable
◆ set_samples_per_packet()
virtual void uhd::rfnoc::siggen_block_control::set_samples_per_packet ( const size_t  spp,
const size_t  port
Set the number of samples per packet to generate
Sets the number of samples per packet to be generated by the function generator on the given block. The value will be coerced such that outgoing packets will not exceed the graph MTU.
sppNumber of samples per packet to generate
portThe port on the block whose samples per packet to set
◆ set_sine_frequency()
void uhd::rfnoc::siggen_block_control::set_sine_frequency ( const double  frequency,
const size_t  port
Configure the sinusoidal waveform generator given frequency and rate
Convenience function to configure the current phase increment between successive samples generated by the sinusoidal function generator given the desired frequency and assumed sample rate.
frequencyThe desired frequency of the sinusoid
sample_rateThe assumed sample rate
portThe port on the block whose phase increment to set
◆ set_sine_phase_increment()
virtual void uhd::rfnoc::siggen_block_control::set_sine_phase_increment ( const double  phase_inc,
const size_t  port
Set the phase increment between samples in sine wave mode
Sets the phase increment between successive samples generated by the function generator on the given block when the block is configured in sine wave mode. The value must be in the range [-pi, pi].
phase_incThe phase increment between samples
◆ set_waveform()
virtual void uhd::rfnoc::siggen_block_control::set_waveform ( const siggen_waveform  type,
const size_t  port
Set the function generator waveform type
Sets the waveform type that the given port on the block should generate when enabled.
typeFunction generator waveform type
portThe port on the block whose waveform type to set
◆ REG_BLOCK_SIZE
const uint32_t uhd::rfnoc::siggen_block_control::REG_BLOCK_SIZE
◆ REG_CARTESIAN_OFFSET
const uint32_t uhd::rfnoc::siggen_block_control::REG_CARTESIAN_OFFSET
◆ REG_CONSTANT_OFFSET
const uint32_t uhd::rfnoc::siggen_block_control::REG_CONSTANT_OFFSET
◆ REG_ENABLE_OFFSET
const uint32_t uhd::rfnoc::siggen_block_control::REG_ENABLE_OFFSET
◆ REG_GAIN_OFFSET
const uint32_t uhd::rfnoc::siggen_block_control::REG_GAIN_OFFSET
◆ REG_PHASE_INC_OFFSET
const uint32_t uhd::rfnoc::siggen_block_control::REG_PHASE_INC_OFFSET
◆ REG_SPP_OFFSET
const uint32_t uhd::rfnoc::siggen_block_control::REG_SPP_OFFSET
◆ REG_WAVEFORM_OFFSET
const uint32_t uhd::rfnoc::siggen_block_control::REG_WAVEFORM_OFFSET
