uhd::rfnoc::split_stream_block_control Class Reference
#include <uhd/rfnoc/split_stream_block_control.hpp>
Inheritance diagram for uhd::rfnoc::split_stream_block_control:
Split Stream Block Control Class
The Split Stream Block is an RFNoC block that takes in a single CHDR stream and duplicates it, creating a number of output streams for each input stream. The number of streams is defined by the NUM_PORTS parameter used to instantiate the RFNoC block in the image, while the number of output branches is defined by the NUM_BRANCH parameter. In software, this corresponds to an RFNoC block having NUM_PORTS input ports and NUM_PORTS * NUM_BRANCH output ports.
Given the following example of a split stream RFNoC block with NUM_PORTS = 2 and NUM_BRANCH = 3, the input streams map to output branches and streams as follows. The number located at each input and output indicates the port number corresponding to that stream and branch:
Stream A --->|0        0|---> Stream A } Branch 0
Stream B --->|1        1|---> Stream B
             |         2|---> Stream A } Branch 1
             |         3|---> Stream B
             |         4|---> Stream A } Branch 2
             |         5|---> Stream B
In other words, the port number corresponding to stream S of branch B is given by B * (num_input_ports) + S.
Property Propagation and Action Forwarding Behavior
The default behavior of the split stream block controller is to propagate properties received on a particular stream to all branches of that stream. For example, if a property is received at branch 0, stream B in the example above, that property will be propagated to stream B in branches 1 and 2 AND to stream B in the input. The property will not propagate across streams.
For actions, an action received on a particular stream is forwarded to that stream on all opposite branches. If in the example above, an action is received at branch 2, stream A, it will be forwarded to stream A on the input side. Similarly, if an action is received on stream B of the input, it will be forwarded to stream B on branches 0, 1, AND 2.
using make_args_ptr = std::unique_ptr< make_args_int_t, make_args_deleter >
 Opaque pointer to the constructor arguments with custom deleter. More...
enum class  action_mode_t { SYNC , ASYNC }
 Action execution modes. More...
using post_action_handler_t = std::function< void(const res_source_info &, action_info::sptr, action_mode_t)>
register_iface & regs ()
void post_action (const res_source_info &edge_info, action_info::sptr action, action_mode_t mode=action_mode_t::SYNC)
