uhd::rfnoc::test::mock_ddc_node_t Class Reference
#include <uhd/rfnoc/mock_nodes.hpp>
Inheritance diagram for uhd::rfnoc::test::mock_ddc_node_t:
uhd::rfnoc::node_t
Mock DDC node
  • Single channel
  • Does simple coercion of decimation
  • Keeps output and input rates consistent with decimation
 mock_ddc_node_t ()
 Return a unique identifier string for this node. More...
 Return the number of input ports for this block. More...
 Return the number of output ports for this block. More...
static int coerce_decim (const int requested_decim)
Public Attributes
property_t< double > _samp_rate_in
property_t< double > _samp_rate_out
property_t< int > _decim {"decim", DEFAULT_DECIM, {res_source_info::USER}}
enum class  action_mode_t { SYNC , ASYNC }
 Action execution modes. More...
using post_action_handler_t = std::function< void(const res_source_info &, action_info::sptr, action_mode_t)>
void post_action (const res_source_info &edge_info, action_info::sptr action, action_mode_t mode=action_mode_t::SYNC)
◆ mock_ddc_node_t()
uhd::rfnoc::test::mock_ddc_node_t::mock_ddc_node_t ( )
◆ coerce_decim()
static int uhd::rfnoc::test::mock_ddc_node_t::coerce_decim ( const int  requested_decim)
inlinestatic
◆ get_num_input_ports()
size_t uhd::rfnoc::test::mock_ddc_node_t::get_num_input_ports ( ) const
inlineoverridevirtual
This function needs to be overridden.
noc_id The number of ports
Implements uhd::rfnoc::node_t.
◆ get_num_output_ports()
size_t uhd::rfnoc::test::mock_ddc_node_t::get_num_output_ports ( ) const
◆ get_unique_id()
std::string uhd::rfnoc::test::mock_ddc_node_t::get_unique_id ( ) const
In every RFNoC graph, no two nodes cannot have the same ID.
The unique ID as a string
Reimplemented from uhd::rfnoc::node_t.
◆ _decim
property_t<int> uhd::rfnoc::test::mock_ddc_node_t::_decim {"decim", DEFAULT_DECIM, {res_source_info::USER}}
◆ _samp_rate_in
property_t<double> uhd::rfnoc::test::mock_ddc_node_t::_samp_rate_in
Initial value:
constexpr double DEFAULT_RATE
Definition: mock_nodes.hpp:19
@ INPUT_EDGE
An input edge sources this resource.
Definition: res_source_info.hpp:23
◆ _samp_rate_out
property_t<double> uhd::rfnoc::test::mock_ddc_node_t::_samp_rate_out
Initial value:
@ OUTPUT_EDGE
Definition: res_source_info.hpp:24
