uhd::rfnoc::test::mock_edge_node_t Class Reference
#include <uhd/rfnoc/mock_nodes.hpp>
Inheritance diagram for uhd::rfnoc::test::mock_edge_node_t:
uhd::rfnoc::node_t
Mock node with configurable number of input and output ports that have an edge property associated with each. The node can source actions with key 'action' from any of its edges. Incoming actions with key 'action' are stored in a (source port --> list of incoming actions) map.
using received_actions_map_t = std::unordered_map< res_source_info, std::vector< action_info::sptr > >
enum class  action_mode_t { SYNC , ASYNC }
 Action execution modes. More...
using post_action_handler_t = std::function< void(const res_source_info &, action_info::sptr, action_mode_t)>
 mock_edge_node_t (size_t input_ports, size_t output_ports, const std::string &name="MOCK_EDGE_NODE")
template<typename T >
void set_edge_property (const std::string &id, const T &val, const res_source_info &rsi)
T get_edge_property (const std::string &id, const res_source_info &rsi)
 Return the number of input ports for this block. More...
 Return the number of output ports for this block. More...
 Return a unique identifier string for this node. More...
void post_input_edge_action (action_info::sptr action, size_t port)
void post_output_edge_action (action_info::sptr action, size_t port)
const received_actions_map_t & get_received_actions_map () const
void clear_received_actions_map ()
void post_action (const res_source_info &edge_info, action_info::sptr action, action_mode_t mode=action_mode_t::SYNC)
◆ received_actions_map_t
◆ mock_edge_node_t()
uhd::rfnoc::test::mock_edge_node_t::mock_edge_node_t ( size_t  input_ports,
const std::string &  name = "MOCK_EDGE_NODE"
◆ clear_received_actions_map()
void uhd::rfnoc::test::mock_edge_node_t::clear_received_actions_map ( )
◆ get_edge_property()
T uhd::rfnoc::test::mock_edge_node_t::get_edge_property ( const std::string &  id,
const res_source_info &  rsi
◆ get_num_input_ports()
size_t uhd::rfnoc::test::mock_edge_node_t::get_num_input_ports ( ) const
inlineoverridevirtual
This function needs to be overridden.
noc_id The number of ports
Implements uhd::rfnoc::node_t.
◆ get_num_output_ports()
size_t uhd::rfnoc::test::mock_edge_node_t::get_num_output_ports ( ) const
◆ get_received_actions_map()
const received_actions_map_t& uhd::rfnoc::test::mock_edge_node_t::get_received_actions_map ( ) const
◆ get_unique_id()
std::string uhd::rfnoc::test::mock_edge_node_t::get_unique_id ( ) const
In every RFNoC graph, no two nodes cannot have the same ID.
The unique ID as a string
Reimplemented from uhd::rfnoc::node_t.
◆ post_input_edge_action()
void uhd::rfnoc::test::mock_edge_node_t::post_input_edge_action ( action_info::sptr  action,
size_t  port
◆ post_output_edge_action()
void uhd::rfnoc::test::mock_edge_node_t::post_output_edge_action ( action_info::sptr  action,
size_t  port
◆ set_edge_property()
void uhd::rfnoc::test::mock_edge_node_t::set_edge_property ( const std::string &  id,
const T &  val,
