uhd::rfnoc::test::mock_fifo_t Class Reference
#include <uhd/rfnoc/mock_nodes.hpp>
Inheritance diagram for uhd::rfnoc::test::mock_fifo_t:
uhd::rfnoc::node_t
FIFO
Not much here – we use it to test dynamic prop and action forwarding.
 mock_fifo_t (const size_t num_ports)
 Return a unique identifier string for this node. More...
 Return the number of input ports for this block. More...
 Return the number of output ports for this block. More...
enum class  action_mode_t { SYNC , ASYNC }
 Action execution modes. More...
using post_action_handler_t = std::function< void(const res_source_info &, action_info::sptr, action_mode_t)>
void post_action (const res_source_info &edge_info, action_info::sptr action, action_mode_t mode=action_mode_t::SYNC)
◆ mock_fifo_t()
uhd::rfnoc::test::mock_fifo_t::mock_fifo_t ( const size_t  num_ports)
◆ get_num_input_ports()
size_t uhd::rfnoc::test::mock_fifo_t::get_num_input_ports ( ) const
inlineoverridevirtual
This function needs to be overridden.
noc_id The number of ports
Implements uhd::rfnoc::node_t.
◆ get_num_output_ports()
size_t uhd::rfnoc::test::mock_fifo_t::get_num_output_ports ( ) const
◆ get_unique_id()
std::string uhd::rfnoc::test::mock_fifo_t::get_unique_id ( ) const
In every RFNoC graph, no two nodes cannot have the same ID.
The unique ID as a string
Reimplemented from uhd::rfnoc::node_t.
