uhd::rfnoc::test::mock_radio_node_t Class Reference
#include <uhd/rfnoc/mock_nodes.hpp>
Inheritance diagram for uhd::rfnoc::test::mock_radio_node_t:
uhd::rfnoc::node_t
Mock Radio node
  • "Full Duplex"
  • Has two master clock rates: 100e6 and 200e6
  • RSSI is a read-only prop that always needs updating
 mock_radio_node_t (const size_t radio_idx)
void update_fwd_policy (forwarding_policy_t policy)
 Return a unique identifier string for this node. More...
 Return the number of input ports for this block. More...
 Return the number of output ports for this block. More...
void generate_overrun (const size_t chan)
void generate_underrun (const size_t chan, uhd::time_spec_t time_spec)
Public Attributes
size_t rssi_resolver_count = 0
bool disable_samp_out_resolver = false
double force_samp_out_value = 23e6
size_t last_num_samps = 0
enum class  action_mode_t { SYNC , ASYNC }
 Action execution modes. More...
using post_action_handler_t = std::function< void(const res_source_info &, action_info::sptr, action_mode_t)>
void post_action (const res_source_info &edge_info, action_info::sptr action, action_mode_t mode=action_mode_t::SYNC)
◆ mock_radio_node_t()
uhd::rfnoc::test::mock_radio_node_t::mock_radio_node_t ( const size_t  radio_idx)
◆ generate_overrun()
void uhd::rfnoc::test::mock_radio_node_t::generate_overrun ( const size_t  chan)
◆ generate_underrun()
void uhd::rfnoc::test::mock_radio_node_t::generate_underrun ( const size_t  chan,
◆ get_num_input_ports()
size_t uhd::rfnoc::test::mock_radio_node_t::get_num_input_ports ( ) const
inlineoverridevirtual
This function needs to be overridden.
noc_id The number of ports
Implements uhd::rfnoc::node_t.
◆ get_num_output_ports()
size_t uhd::rfnoc::test::mock_radio_node_t::get_num_output_ports ( ) const
◆ get_unique_id()
std::string uhd::rfnoc::test::mock_radio_node_t::get_unique_id ( ) const
In every RFNoC graph, no two nodes cannot have the same ID.
The unique ID as a string
Reimplemented from uhd::rfnoc::node_t.
◆ update_fwd_policy()
void uhd::rfnoc::test::mock_radio_node_t::update_fwd_policy ( forwarding_policy_t  policy)
◆ disable_samp_out_resolver
bool uhd::rfnoc::test::mock_radio_node_t::disable_samp_out_resolver = false
◆ force_samp_out_value
double uhd::rfnoc::test::mock_radio_node_t::force_samp_out_value = 23e6
◆ last_num_samps
size_t uhd::rfnoc::test::mock_radio_node_t::last_num_samps = 0
◆ rssi_resolver_count
size_t uhd::rfnoc::test::mock_radio_node_t::rssi_resolver_count = 0
