uhd::rfnoc::test::mock_routing_node_t Class Reference
#include <uhd/rfnoc/mock_nodes.hpp>
Inheritance diagram for uhd::rfnoc::test::mock_routing_node_t:
uhd::rfnoc::node_t
Do-nothing mock node used for testing property and action propagation between various edges with the USE_MAP forwarding strategy.
 mock_routing_node_t (size_t input_ports, size_t output_ports)
 Return the number of input ports for this block. More...
 Return the number of output ports for this block. More...
 Return a unique identifier string for this node. More...
void set_prop_forwarding_map (const node_t::forwarding_map_t &fwd_map)
void set_action_forwarding_map (const node_t::forwarding_map_t &fwd_map)
enum class  action_mode_t { SYNC , ASYNC }
 Action execution modes. More...
using post_action_handler_t = std::function< void(const res_source_info &, action_info::sptr, action_mode_t)>
void post_action (const res_source_info &edge_info, action_info::sptr action, action_mode_t mode=action_mode_t::SYNC)
◆ mock_routing_node_t()
uhd::rfnoc::test::mock_routing_node_t::mock_routing_node_t ( size_t  input_ports,
size_t  output_ports
◆ get_num_input_ports()
size_t uhd::rfnoc::test::mock_routing_node_t::get_num_input_ports ( ) const
inlineoverridevirtual
This function needs to be overridden.
noc_id The number of ports
Implements uhd::rfnoc::node_t.
◆ get_num_output_ports()
size_t uhd::rfnoc::test::mock_routing_node_t::get_num_output_ports ( ) const
◆ get_unique_id()
std::string uhd::rfnoc::test::mock_routing_node_t::get_unique_id ( ) const
In every RFNoC graph, no two nodes cannot have the same ID.
The unique ID as a string
Reimplemented from uhd::rfnoc::node_t.
◆ set_action_forwarding_map()
void uhd::rfnoc::test::mock_routing_node_t::set_action_forwarding_map ( const node_t::forwarding_map_t &  fwd_map)
◆ set_prop_forwarding_map()
void uhd::rfnoc::test::mock_routing_node_t::set_prop_forwarding_map ( const node_t::forwarding_map_t &  fwd_map)
