uhd::rfnoc::test::mock_terminator_t Class Reference
#include <uhd/rfnoc/mock_nodes.hpp>
Inheritance diagram for uhd::rfnoc::test::mock_terminator_t:
uhd::rfnoc::node_t
Terminator: Probe edge properties
 mock_terminator_t (const size_t num_ports, const std::vector< std::string > expected_actions={}, const std::string name="MOCK_TERMINATOR")
 Return a unique identifier string for this node. More...
 Return the number of input ports for this block. More...
 Return the number of output ports for this block. More...
template<typename data_t >
void set_edge_property (const std::string &id, data_t val, res_source_info edge_info)
data_t get_edge_property (const std::string &id, res_source_info edge_info)
Public Attributes
std::list< action_info::sptr > received_actions
static size_t counter = 0
enum class  action_mode_t { SYNC , ASYNC }
 Action execution modes. More...
using post_action_handler_t = std::function< void(const res_source_info &, action_info::sptr, action_mode_t)>
void post_action (const res_source_info &edge_info, action_info::sptr action, action_mode_t mode=action_mode_t::SYNC)
◆ mock_terminator_t()
uhd::rfnoc::test::mock_terminator_t::mock_terminator_t ( const size_t  num_ports,
const std::vector< std::string >  expected_actions = {},
const std::string  name = "MOCK_TERMINATOR"
◆ get_edge_property()
data_t uhd::rfnoc::test::mock_terminator_t::get_edge_property ( const std::string &  id,
◆ get_num_input_ports()
size_t uhd::rfnoc::test::mock_terminator_t::get_num_input_ports ( ) const
inlineoverridevirtual
This function needs to be overridden.
noc_id The number of ports
Implements uhd::rfnoc::node_t.
◆ get_num_output_ports()
size_t uhd::rfnoc::test::mock_terminator_t::get_num_output_ports ( ) const
◆ get_unique_id()
std::string uhd::rfnoc::test::mock_terminator_t::get_unique_id ( ) const
In every RFNoC graph, no two nodes cannot have the same ID.
The unique ID as a string
Reimplemented from uhd::rfnoc::node_t.
◆ post_action()
void uhd::rfnoc::test::mock_terminator_t::post_action ( const res_source_info &  edge_info,
◆ set_edge_property()
void uhd::rfnoc::test::mock_terminator_t::set_edge_property ( const std::string &  id,
data_t  val,
◆ counter
size_t uhd::rfnoc::test::mock_terminator_t::counter = 0
◆ received_actions
std::list<action_info::sptr> uhd::rfnoc::test::mock_terminator_t::received_actions
