paths.hpp File Reference
#include <uhd/config.hpp>
#include <filesystem>
#include <string>
#include <vector>
Namespaces
 uhd
Functions
UHD_API std::string uhd::get_tmp_path (void)
 Get a string representing the system's temporary directory. More...
UHD_API std::string uhd::get_lib_path (void)
 Get a string representing the system's library directory. More...
UHD_API std::string uhd::get_pkg_path (void)
 Get a string representing the system's pkg directory. More...
UHD_API std::string uhd::get_pkg_data_path (void)
 Get a string representing the system's package data directory ("share"). More...
UHD_API std::string uhd::get_cal_data_path (void)
 Get a string representing the location of the calibration database. More...
UHD_API std::vector< std::filesystem::path > uhd::get_module_paths (void)
 Get UHD library paths. More...
UHD_API std::string uhd::get_images_dir (const std::string &search_paths)
 Return the UHD images directory path. More...
UHD_API std::string uhd::find_image_path (const std::string &image_name, const std::string &search_paths="")
 Return the full path to particular UHD binary image. More...
UHD_API std::string uhd::find_utility (const std::string &name)
 Search for the location of a particular UHD utility. More...
UHD_API std::string uhd::print_utility_error (const std::string &name, const std::string &args="")
 Return an error string recommending the user run the utility. More...
