19 #include <boost/units/detail/utility.hpp>
23 namespace uhd {
namespace rfnoc {
34 public std::enable_shared_from_this<rfnoc_graph>
40 using sptr = std::shared_ptr<rfnoc_graph>;
80 const std::string& block_id_hint)
const = 0;
85 std::vector<block_id_t>
find_blocks(
const
87 std::vector<block_id_t> all_block_ids = find_blocks(block_id_hint);
88 std::vector<block_id_t> filt_block_ids;
89 for (
size_t i = 0; i < all_block_ids.size(); i++) {
90 if (has_block<T>(all_block_ids[i])) {
91 filt_block_ids.push_back(all_block_ids[i]);
94 return filt_block_ids;
110 template <
typename T>
113 return has_block(block_id)
114 && bool(std::dynamic_pointer_cast<T>(get_block(block_id)));
141 template <
typename T>
144 std::shared_ptr<T> blk = std::dynamic_pointer_cast<T>(get_block(block_id));
149 std::string(
"This device does not have a block of type ")
150 + boost::units::detail::demangle(
typeid(T).name())
169 size_t dst_port) = 0;
194 bool is_back_edge =
false) = 0;
246 size_t dst_port) = 0;
269 virtual void disconnect(
const std::string& streamer_id,
size_t port) = 0;
281 const block_id_t& src_blk,
size_t src_port) = 0;
293 const block_id_t& dst_blk,
391 const size_t mb_index = 0) = 0;
453 size_t mb_index = 0)
const = 0;
Definition: device_addr.hpp:39
Definition: property_tree.hpp:224
Definition: block_id.hpp:40
std::string to_string() const
Return a string like this: "0/FFT#1" (includes all components, if set)
Definition: noc_block_base.hpp:44
Definition: rfnoc_graph.hpp:35
virtual void disconnect(const std::string &streamer_id, size_t port)=0
virtual size_t get_num_mboards() const =0
virtual std::string to_dot()=0
bool has_block(const block_id_t &block_id) const
Definition: rfnoc_graph.hpp:111
virtual ~rfnoc_graph()
Definition: rfnoc_graph.hpp:42
virtual std::map< std::string, device_addr_t > get_chdr_xport_adapters(size_t mb_index=0) const =0
virtual void connect(uhd::tx_streamer::sptr streamer, size_t strm_port, const block_id_t &dst_blk, size_t dst_port, uhd::transport::adapter_id_t adapter_id=uhd::transport::NULL_ADAPTER_ID)=0
virtual bool is_connectable(const block_id_t &src_blk, size_t src_port, const block_id_t &dst_blk, size_t dst_port)=0
virtual chdr_w_t get_chdr_width(const size_t mb_index=0) const =0
std::vector< block_id_t > find_blocks(const std::string &block_id_hint) const
Definition: rfnoc_graph.hpp:85
virtual std::vector< block_id_t > find_blocks(const std::string &block_id_hint) const =0
virtual std::vector< uhd::transport::adapter_id_t > enumerate_adapters_from_src(const block_id_t &src_blk, size_t src_port)=0
virtual tx_streamer::sptr create_tx_streamer(const size_t num_ports, const stream_args_t &args)=0
virtual std::vector< graph_edge_t > enumerate_active_connections()=0
virtual void connect(const block_id_t &src_blk, size_t src_port, uhd::rx_streamer::sptr streamer, size_t strm_port, uhd::transport::adapter_id_t adapter_id=uhd::transport::NULL_ADAPTER_ID)=0
virtual bool has_block(const block_id_t &block_id) const =0
Checks if a specific NoC block exists on the device.
virtual rx_streamer::sptr create_rx_streamer(const size_t num_ports, const stream_args_t &args)=0
virtual std::shared_ptr< mb_controller > get_mb_controller(const size_t mb_index=0)=0
virtual void disconnect(const block_id_t &src_blk, size_t src_port, const block_id_t &dst_blk, size_t dst_port)=0
virtual std::vector< uhd::transport::adapter_id_t > enumerate_adapters_to_dst(const block_id_t &dst_blk, size_t dst_port)=0
virtual noc_block_base::sptr get_block(const block_id_t &block_id) const =0
Returns a block controller class for an NoC block.
virtual void connect(const block_id_t &src_blk, size_t src_port, const block_id_t &dst_blk, size_t dst_port, bool is_back_edge=false)=0
std::shared_ptr< T > get_block(const block_id_t &block_id) const
Definition: rfnoc_graph.hpp:142
virtual uhd::property_tree::sptr get_tree(void) const =0
Return a reference to the property tree.
virtual std::vector< graph_edge_t > enumerate_static_connections() const =0
virtual void disconnect(const std::string &streamer_id)=0
virtual bool synchronize_devices(const uhd::time_spec_t &time_spec, const bool quiet)=0
std::shared_ptr< rfnoc_graph > sptr
Definition: rfnoc_graph.hpp:40
Definition: stream.hpp:172
Definition: time_spec.hpp:31
std::shared_ptr< tx_streamer > sptr
Definition: stream.hpp:373
Definition: config.h:87
chdr_w_t
Type that indicates the CHDR Width in bits.
Definition: rfnoc_types.hpp:19
size_t adapter_id_t
Host transport adapter ID.
Definition: adapter_id.hpp:19
Definition: build_info.hpp:12
Definition: exception.hpp:59
Definition: stream.hpp:51
