uhd::rfnoc::register_iface_stats Struct Reference
#include <uhd/rfnoc/register_iface.hpp>
Statistics for register interface operations.
This struct contains counters for various register interface operations, useful for debugging and performance monitoring.
Notes:
  • Dropped packets are detected when there is a sequence gap between incoming ACKs. If the incoming ACK sequence numbers are [0,1,3] then we assume number 2 dropped, and ctrl_dropped is incremented.
  • Out-of-sequence packets are only counted when packets with unexpected sequence numbers arrive. If the incoming ACK sequence numbers are [0,2,1], then first we assume that sequence number 1 was dropped (and ctrl_dropped is incremented). We therefore no longer expect sequence number 1, and when it is detected after sequence number 2, ctrl_out_of_sequence is incremented. When ACKs are reordered, they therefore cause both drop counts and out-of-sequence counts.
std::string UHD_API to_string () const
Public Attributes
uint64_t ctrl_packets_sent = 0
 Number of control packets sent. More...
uint64_t ack_packets_received = 0
 Number of ACK packets received. More...
uint64_t async_packets_received = 0
 Number of async packets received. More...
uint64_t ack_packets_sent = 0
 Number of ACK packets sent. More...
uint64_t ctrl_dropped = 0
 Number of control packets dropped (or ACKs not received) More...
uint64_t ctrl_out_of_sequence = 0
 Number of out-of-sequence control packets. More...
ssize_t buffer_fullness = 0
 The fullness of the buffer in the FPGA, as calculated by the software. More...
◆ to_string()
std::string UHD_API uhd::rfnoc::register_iface_stats::to_string ( ) const
◆ ack_packets_received
uint64_t uhd::rfnoc::register_iface_stats::ack_packets_received = 0
◆ ack_packets_sent
uint64_t uhd::rfnoc::register_iface_stats::ack_packets_sent = 0
◆ async_packets_received
uint64_t uhd::rfnoc::register_iface_stats::async_packets_received = 0
◆ buffer_fullness
ssize_t uhd::rfnoc::register_iface_stats::buffer_fullness = 0
◆ ctrl_dropped
uint64_t uhd::rfnoc::register_iface_stats::ctrl_dropped = 0
◆ ctrl_out_of_sequence
uint64_t uhd::rfnoc::register_iface_stats::ctrl_out_of_sequence = 0
◆ ctrl_packets_sent
uint64_t uhd::rfnoc::register_iface_stats::ctrl_packets_sent = 0
