uhd::rfnoc::duc_block_ctrl Member List
This is the complete list of members for uhd::rfnoc::duc_block_ctrl, including all inherited members.
_argsuhd::rfnoc::node_ctrl_baseprotected
_block_defuhd::rfnoc::block_ctrl_baseprotected
_clear(const size_t port=0)uhd::rfnoc::block_ctrl_baseprotectedvirtual
_downstream_nodesuhd::rfnoc::node_ctrl_baseprotected
uhd::_register_downstream_node(node_ctrl_base::sptr downstream_node, size_t port)uhd::rfnoc::node_ctrl_baseprotectedvirtual
_register_upstream_node(node_ctrl_base::sptr upstream_node, size_t port)uhd::rfnoc::node_ctrl_baseprotectedvirtual
_request_input_port(const size_t suggested_port, const uhd::device_addr_t &args) constuhd::rfnoc::sink_block_ctrl_baseprotectedvirtual
_request_output_port(const size_t suggested_port, const uhd::device_addr_t &args) constuhd::rfnoc::source_block_ctrl_baseprotectedvirtual
_resolve_port_def(const blockdef::port_t &port_def) constuhd::rfnoc::block_ctrl_baseprotected
_root_pathuhd::rfnoc::block_ctrl_baseprotected
_rx_streamer_activeuhd::rfnoc::source_node_ctrlprotected
_transport_is_big_endianuhd::rfnoc::block_ctrl_baseprotected
_treeuhd::rfnoc::block_ctrl_baseprotected
_tx_streamer_activeuhd::rfnoc::sink_node_ctrlprotected
_upstream_nodesuhd::rfnoc::node_ctrl_baseprotected
block_ctrl_base(void)uhd::rfnoc::block_ctrl_baseinlineprotected
block_ctrl_base(const make_args_t &make_args)uhd::rfnoc::block_ctrl_baseprotected
uhd::rfnoc::node_ctrl_base::clear()uhd::rfnoc::node_ctrl_basevirtual
clear_command_time(const size_t port)uhd::rfnoc::block_ctrl_base
configure_flow_control_in(size_t cycles, size_t packets, size_t block_port=0)uhd::rfnoc::sink_block_ctrl_basevirtual
configure_flow_control_out(size_t buf_size_pkts, size_t block_port=0, const uhd::sid_t &sid=uhd::sid_t())uhd::rfnoc::source_block_ctrl_basevirtual
connect_downstream(node_ctrl_base::sptr downstream_node, size_t port=ANY_PORT, const uhd::device_addr_t &args=uhd::device_addr_t())uhd::rfnoc::source_node_ctrl
connect_upstream(node_ctrl_base::sptr upstream_node, size_t port=ANY_PORT, const uhd::device_addr_t &args=uhd::device_addr_t())uhd::rfnoc::sink_node_ctrl
find_downstream_node()uhd::rfnoc::node_ctrl_baseinline
find_downstream_unique_property(boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >())uhd::rfnoc::node_ctrl_baseinline
find_upstream_node()uhd::rfnoc::node_ctrl_baseinline
find_upstream_unique_property(boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >())uhd::rfnoc::node_ctrl_baseinline
get_address(size_t block_port=0)uhd::rfnoc::block_ctrl_base
get_arg(const std::string &key, const size_t port=0) constuhd::rfnoc::block_ctrl_base
get_arg(const std::string &key, const size_t port=0) constuhd::rfnoc::block_ctrl_baseinline
get_arg_path(const std::string &key, size_t port=0) constuhd::rfnoc::block_ctrl_baseinlineprotected
get_arg_type(const std::string &key, const size_t port=0) constuhd::rfnoc::block_ctrl_base
get_args(const size_t port=0) constuhd::rfnoc::block_ctrl_base
get_block_id() constuhd::rfnoc::block_ctrl_baseinline
get_command_time(const size_t port=0)uhd::rfnoc::block_ctrl_base
get_ctrl_iface(const size_t block_port)uhd::rfnoc::block_ctrl_baseprotected
get_ctrl_ports() constuhd::rfnoc::block_ctrl_base
get_downstream_port(const size_t this_port)uhd::rfnoc::node_ctrl_base
get_fifo_size(size_t block_port=0) constuhd::rfnoc::sink_block_ctrl_base
get_input_ports() constuhd::rfnoc::sink_block_ctrl_base
get_input_samp_rate(size_t port=ANY_PORT)uhd::rfnoc::rate_node_ctrlvirtual
get_input_scale_factor(size_t port=ANY_PORT)uhd::rfnoc::scalar_node_ctrlvirtual
get_input_signature(size_t block_port=0) constuhd::rfnoc::sink_block_ctrl_base
get_output_ports() constuhd::rfnoc::source_block_ctrl_base
get_output_samp_rate(size_t port=ANY_PORT)uhd::rfnoc::rate_node_ctrlvirtual
get_output_scale_factor(size_t port=ANY_PORT)uhd::rfnoc::scalar_node_ctrlvirtual
get_output_signature(size_t block_port=0) constuhd::rfnoc::source_block_ctrl_base
get_upstream_port(const size_t this_port)uhd::rfnoc::node_ctrl_base
issue_stream_cmd(const uhd::stream_cmd_t &stream_cmd, const size_t chan=0)uhd::rfnoc::source_block_ctrl_basevirtual
list_downstream_nodes()uhd::rfnoc::node_ctrl_baseinline
list_upstream_nodes()uhd::rfnoc::node_ctrl_baseinline
make(const make_args_t &make_args, boost::uint64_t noc_id=~0)uhd::rfnoc::block_ctrl_basestatic
make_t typedefuhd::rfnoc::block_ctrl_base
node_ctrl_base(void)uhd::rfnoc::node_ctrl_baseinlineprotected
uhd::node_map_pair_t typedefuhd::rfnoc::node_ctrl_base
uhd::rfnoc::source_node_ctrl::node_map_pair_t typedefuhd::rfnoc::source_node_ctrl
uhd::rfnoc::sink_block_ctrl_base::uhd::rfnoc::sink_node_ctrl::node_map_pair_t typedefuhd::rfnoc::sink_node_ctrl
uhd::node_map_t typedefuhd::rfnoc::node_ctrl_base
uhd::rfnoc::source_node_ctrl::node_map_t typedefuhd::rfnoc::source_node_ctrl
uhd::rfnoc::sink_block_ctrl_base::uhd::rfnoc::sink_node_ctrl::node_map_t typedefuhd::rfnoc::sink_node_ctrl
RATE_UNDEFINEDuhd::rfnoc::rate_node_ctrlstatic
register_block(const make_t &make, const std::string &name)uhd::rfnoc::block_ctrl_basestatic
SCALE_UNDEFINEDuhd::rfnoc::scalar_node_ctrlstatic
set_arg(const std::string &key, const std::string &val, const size_t port=0)uhd::rfnoc::block_ctrl_base
set_arg(const std::string &key, const T &val, const size_t port=0)uhd::rfnoc::block_ctrl_baseinline
set_args(const uhd::device_addr_t &args, const size_t port=0)uhd::rfnoc::block_ctrl_base
set_command_tick_rate(const double tick_rate, const size_t port=ANY_PORT)uhd::rfnoc::block_ctrl_base
set_command_time(const time_spec_t &time_spec, const size_t port=ANY_PORT)uhd::rfnoc::block_ctrl_base
set_destination(boost::uint32_t next_address, size_t output_block_port=0)uhd::rfnoc::source_block_ctrl_basevirtual
set_downstream_port(const size_t this_port, const size_t remote_port)uhd::rfnoc::node_ctrl_base
set_error_policy(const std::string &policy)uhd::rfnoc::sink_block_ctrl_basevirtual
set_rx_streamer(bool active, const size_t port)uhd::rfnoc::source_node_ctrlvirtual
set_tx_streamer(bool active, const size_t port)uhd::rfnoc::sink_node_ctrlvirtual
set_upstream_port(const size_t this_port, const size_t remote_port)uhd::rfnoc::node_ctrl_base
uhd::sptr typedefuhd::rfnoc::source_block_ctrl_base
uhd::rfnoc::sink_block_ctrl_base::sptr typedefuhd::rfnoc::sink_block_ctrl_base
uhd::rfnoc::rate_node_ctrl::sptr typedefuhd::rfnoc::rate_node_ctrl
uhd::rfnoc::scalar_node_ctrl::sptr typedefuhd::rfnoc::scalar_node_ctrl
sr_read32(const settingsbus_reg_t reg, const size_t port=0)uhd::rfnoc::block_ctrl_base
sr_read64(const settingsbus_reg_t reg, const size_t port=0)uhd::rfnoc::block_ctrl_base
sr_write(const boost::uint32_t reg, const boost::uint32_t data, const size_t port=0)uhd::rfnoc::block_ctrl_base
sr_write(const std::string &reg, const boost::uint32_t data, const size_t port=0)uhd::rfnoc::block_ctrl_base
unique_id() constuhd::rfnoc::block_ctrl_baseinlinevirtual
user_reg_read32(const boost::uint32_t addr, const size_t port=0)uhd::rfnoc::block_ctrl_base
user_reg_read32(const std::string &reg, const size_t port=0)uhd::rfnoc::block_ctrl_base
user_reg_read64(const boost::uint32_t addr, const size_t port=0)uhd::rfnoc::block_ctrl_base
user_reg_read64(const std::string &reg, const size_t port=0)uhd::rfnoc::block_ctrl_base
wptr typedefuhd::rfnoc::node_ctrl_base
~block_ctrl_base()uhd::rfnoc::block_ctrl_baseprotectedvirtual
~node_ctrl_base()uhd::rfnoc::node_ctrl_baseinlineprotectedvirtual
