uhd::rfnoc::block_ctrl Class Reference
This is the default implementation of a block_ctrl_base. More...
#include <uhd/rfnoc/block_ctrl.hpp>
Inheritance diagram for uhd::rfnoc::block_ctrl:
uhd::rfnoc::source_block_ctrl_base uhd::rfnoc::sink_block_ctrl_base uhd::rfnoc::block_ctrl_base uhd::rfnoc::source_node_ctrl uhd::rfnoc::block_ctrl_base uhd::rfnoc::sink_node_ctrl uhd::rfnoc::node_ctrl_base uhd::rfnoc::node_ctrl_base uhd::rfnoc::node_ctrl_base uhd::rfnoc::node_ctrl_base
- Public Types inherited from uhd::rfnoc::source_block_ctrl_base
typedef boost::shared_ptr< source_block_ctrl_base > sptr
- Public Types inherited from uhd::rfnoc::block_ctrl_base
typedef boost::shared_ptr< block_ctrl_base > sptr
typedef boost::function< sptr(const make_args_t &)> make_t
- Public Types inherited from uhd::rfnoc::node_ctrl_base
typedef boost::shared_ptr< node_ctrl_base > sptr
typedef boost::weak_ptr< node_ctrl_base > wptr
typedef std::map< size_t, wptr > node_map_t
typedef std::pair< size_t, wptr > node_map_pair_t
typedef boost::function< void(void)> graph_update_cb_t
- Public Types inherited from uhd::rfnoc::source_node_ctrl
typedef boost::shared_ptr< source_node_ctrl > sptr
typedef std::map< size_t, boost::weak_ptr< source_node_ctrl > > node_map_t
typedef std::pair< size_t, boost::weak_ptr< source_node_ctrl > > node_map_pair_t
- Public Types inherited from uhd::rfnoc::sink_block_ctrl_base
typedef boost::shared_ptr< sink_block_ctrl_base > sptr
- Public Types inherited from uhd::rfnoc::sink_node_ctrl
typedef boost::shared_ptr< sink_node_ctrl > sptr
typedef std::map< size_t, boost::weak_ptr< sink_node_ctrl > > node_map_t
typedef std::pair< size_t, boost::weak_ptr< sink_node_ctrl > > node_map_pair_t
- Public Member Functions inherited from uhd::rfnoc::source_block_ctrl_base
virtual void issue_stream_cmd (const uhd::stream_cmd_t &stream_cmd, const size_t chan=0)
stream_sig_t get_output_signature (size_t block_port=0) const
std::vector< size_t > get_output_ports () const
virtual void set_destination (uint32_t next_address, size_t output_block_port=0)
virtual void configure_flow_control_out (const bool enable_output, const bool lossless_link, const size_t buf_size_bytes, const size_t pkt_limit=0, const size_t block_port=0, const uhd::sid_t &sid=uhd::sid_t())
size_t get_mtu (size_t block_port=0) const
- Public Member Functions inherited from uhd::rfnoc::block_ctrl_base
uint32_t get_address (size_t block_port=0)
block_id_t get_block_id () const
std::string unique_id () const
std::vector< size_t > get_ctrl_ports () const
void sr_write (const uint32_t reg, const uint32_t data, const size_t port=0)
void sr_write (const std::string &reg, const uint32_t data, const size_t port=0)
uint64_t sr_read64 (const settingsbus_reg_t reg, const size_t port=0)
uint32_t sr_read32 (const settingsbus_reg_t reg, const size_t port=0)
uint64_t user_reg_read64 (const uint32_t addr, const size_t port=0)
uint64_t user_reg_read64 (const std::string &reg, const size_t port=0)
uint32_t user_reg_read32 (const uint32_t addr, const size_t port=0)
uint32_t user_reg_read32 (const std::string &reg, const size_t port=0)
void set_command_time (const time_spec_t &time_spec, const size_t port=ANY_PORT)
time_spec_t get_command_time (const size_t port=0)
void set_command_tick_rate (const double tick_rate, const size_t port=ANY_PORT)
void clear_command_time (const size_t port)
void clear ()
void set_args (const uhd::device_addr_t &args, const size_t port=0)
void set_arg (const std::string &key, const std::string &val, const size_t port=0)
 Set a specific block argument. val is converted to the corresponding. More...
template<typename T >
void set_arg (const std::string &key, const T &val, const size_t port=0)
 Direct access to set a block argument. More...
uhd::device_addr_t get_args (const size_t port=0) const
 Return all block arguments as a device_addr_t. More...
std::string get_arg (const std::string &key, const size_t port=0) const
 Return a single block argument in string format. More...
T get_arg (const std::string &key, const size_t port=0) const
 Direct access to get a block argument. More...
std::string get_arg_type (const std::string &key, const size_t port=0) const
- Public Member Functions inherited from uhd::rfnoc::node_ctrl_base
node_map_t list_downstream_nodes ()
node_map_t list_upstream_nodes ()
void disconnect ()
void disconnect_output_port (const size_t output_port)
void disconnect_input_port (const size_t input_port)
void set_downstream_port (const size_t this_port, const size_t remote_port)
size_t get_downstream_port (const size_t this_port)
void set_upstream_port (const size_t this_port, const size_t remote_port)
size_t get_upstream_port (const size_t this_port)
UHD_INLINE std::vector< boost::shared_ptr< T > > find_downstream_node (bool active_only=false)
UHD_INLINE std::vector< boost::shared_ptr< T > > find_upstream_node (bool active_only=false)
template<typename T , typename value_type >
UHD_INLINE value_type find_downstream_unique_property (boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >())
UHD_INLINE value_type find_upstream_unique_property (boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >())
- Public Member Functions inherited from uhd::rfnoc::source_node_ctrl
size_t connect_downstream (node_ctrl_base::sptr downstream_node, size_t port=ANY_PORT, const uhd::device_addr_t &args=uhd::device_addr_t())
virtual void set_rx_streamer (bool active, const size_t port)
- Public Member Functions inherited from uhd::rfnoc::sink_block_ctrl_base
stream_sig_t get_input_signature (size_t block_port=0) const
std::vector< size_t > get_input_ports () const
size_t get_fifo_size (size_t block_port=0) const
virtual void configure_flow_control_in (const size_t bytes, const size_t block_port=0)
virtual void set_error_policy (const std::string &policy)
- Public Member Functions inherited from uhd::rfnoc::sink_node_ctrl
size_t connect_upstream (node_ctrl_base::sptr upstream_node, size_t port=ANY_PORT, const uhd::device_addr_t &args=uhd::device_addr_t())
virtual void set_tx_streamer (bool active, const size_t port)
- Static Public Member Functions inherited from uhd::rfnoc::block_ctrl_base
static void register_block (const make_t &make, const std::string &name)
static sptr make (const make_args_t &make_args, uint64_t noc_id=~0)
 Create a block controller class given a NoC-ID or a block name. More...
- Protected Member Functions inherited from uhd::rfnoc::source_block_ctrl_base
virtual size_t _request_output_port (const size_t suggested_port, const uhd::device_addr_t &args) const
- Protected Member Functions inherited from uhd::rfnoc::block_ctrl_base
 block_ctrl_base (void)
virtual ~block_ctrl_base ()
 block_ctrl_base (const make_args_t &make_args)
stream_sig_t _resolve_port_def (const blockdef::port_t &port_def) const
uhd::fs_path get_arg_path (const std::string &key, size_t port=0) const
 Return the property tree path to a block argument key on port. More...
timed_wb_iface::sptr get_ctrl_iface (const size_t block_port)
 Get a control interface object for block port block_port. More...
virtual void _clear (const size_t port=0)
 Override this function if your block does something else. More...
virtual void _set_command_time (const time_spec_t &time_spec, const size_t port=ANY_PORT)
 Override this function if your block needs to specially handle. More...
- Protected Member Functions inherited from uhd::rfnoc::node_ctrl_base
 node_ctrl_base (void)
virtual ~node_ctrl_base ()
void update_graph ()
- Protected Member Functions inherited from uhd::rfnoc::sink_block_ctrl_base
virtual size_t _request_input_port (const size_t suggested_port, const uhd::device_addr_t &args) const
- Protected Attributes inherited from uhd::rfnoc::block_ctrl_base
uhd::property_tree::sptr _tree
 Property sub-tree. More...
uhd::fs_path _root_path
 Root node of this block's properties. More...
blockdef::sptr _block_def
 Block definition (stores info about the block such as ports) More...
- Protected Attributes inherited from uhd::rfnoc::node_ctrl_base
uhd::device_addr_t _args
 Stores default arguments. More...
node_map_t _upstream_nodes
 List of upstream nodes. More...
node_map_t _downstream_nodes
 List of downstream nodes. More...
size_t _num_input_ports
size_t _num_output_ports
std::map< size_t, bool > _rx_streamer_active
std::map< size_t, bool > _tx_streamer_active
For most blocks, this will be a sufficient implementation. All registers can be set by sr_write(). The default behaviour of functions is documented in uhd::rfnoc::block_ctrl_base.
