uhd::rfnoc::sink_block_ctrl_base Class Reference
#include <uhd/rfnoc/sink_block_ctrl_base.hpp>
Inheritance diagram for uhd::rfnoc::sink_block_ctrl_base:
uhd::rfnoc::block_ctrl_base uhd::rfnoc::sink_node_ctrl uhd::rfnoc::node_ctrl_base uhd::rfnoc::node_ctrl_base uhd::rfnoc::block_ctrl uhd::rfnoc::ddc_block_ctrl uhd::rfnoc::dma_fifo_block_ctrl uhd::rfnoc::duc_block_ctrl uhd::rfnoc::fir_block_ctrl uhd::rfnoc::null_block_ctrl uhd::rfnoc::radio_ctrl uhd::rfnoc::replay_block_ctrl uhd::rfnoc::siggen_block_ctrl uhd::rfnoc::window_block_ctrl
typedef boost::shared_ptr< sink_block_ctrl_base > sptr
- Public Types inherited from uhd::rfnoc::block_ctrl_base
typedef boost::shared_ptr< block_ctrl_base > sptr
typedef boost::function< sptr(const make_args_t &)> make_t
- Public Types inherited from uhd::rfnoc::node_ctrl_base
typedef boost::shared_ptr< node_ctrl_base > sptr
typedef boost::weak_ptr< node_ctrl_base > wptr
typedef std::map< size_t, wptr > node_map_t
typedef std::pair< size_t, wptr > node_map_pair_t
typedef boost::function< void(void)> graph_update_cb_t
- Public Types inherited from uhd::rfnoc::sink_node_ctrl
typedef boost::shared_ptr< sink_node_ctrl > sptr
typedef std::map< size_t, boost::weak_ptr< sink_node_ctrl > > node_map_t
typedef std::pair< size_t, boost::weak_ptr< sink_node_ctrl > > node_map_pair_t
stream_sig_t get_input_signature (size_t block_port=0) const
std::vector< size_t > get_input_ports () const
size_t get_fifo_size (size_t block_port=0) const
size_t get_mtu (size_t block_port=0) const
virtual void configure_flow_control_in (const size_t bytes, const size_t block_port=0)
virtual void set_error_policy (const std::string &policy)
- Public Member Functions inherited from uhd::rfnoc::block_ctrl_base
uint32_t get_address (size_t block_port=0)
block_id_t get_block_id () const
std::string unique_id () const
std::vector< size_t > get_ctrl_ports () const
void sr_write (const uint32_t reg, const uint32_t data, const size_t port=0)
void sr_write (const std::string &reg, const uint32_t data, const size_t port=0)
uint64_t sr_read64 (const settingsbus_reg_t reg, const size_t port=0)
uint32_t sr_read32 (const settingsbus_reg_t reg, const size_t port=0)
uint64_t user_reg_read64 (const uint32_t addr, const size_t port=0)
uint64_t user_reg_read64 (const std::string &reg, const size_t port=0)
uint32_t user_reg_read32 (const uint32_t addr, const size_t port=0)
uint32_t user_reg_read32 (const std::string &reg, const size_t port=0)
void set_command_time (const time_spec_t &time_spec, const size_t port=ANY_PORT)
time_spec_t get_command_time (const size_t port=0)
void set_command_tick_rate (const double tick_rate, const size_t port=ANY_PORT)
void clear_command_time (const size_t port)
void clear ()
void set_args (const uhd::device_addr_t &args, const size_t port=0)
void set_arg (const std::string &key, const std::string &val, const size_t port=0)
 Set a specific block argument. val is converted to the corresponding. More...
template<typename T >
void set_arg (const std::string &key, const T &val, const size_t port=0)
 Direct access to set a block argument. More...
uhd::device_addr_t get_args (const size_t port=0) const
 Return all block arguments as a device_addr_t. More...
std::string get_arg (const std::string &key, const size_t port=0) const
 Return a single block argument in string format. More...
T get_arg (const std::string &key, const size_t port=0) const
 Direct access to get a block argument. More...
std::string get_arg_type (const std::string &key, const size_t port=0) const
- Public Member Functions inherited from uhd::rfnoc::node_ctrl_base
node_map_t list_downstream_nodes ()
node_map_t list_upstream_nodes ()
void disconnect ()
void disconnect_output_port (const size_t output_port)
void disconnect_input_port (const size_t input_port)
void set_downstream_port (const size_t this_port, const size_t remote_port)
size_t get_downstream_port (const size_t this_port)
void set_upstream_port (const size_t this_port, const size_t remote_port)
size_t get_upstream_port (const size_t this_port)
UHD_INLINE std::vector< boost::shared_ptr< T > > find_downstream_node (bool active_only=false)
UHD_INLINE std::vector< boost::shared_ptr< T > > find_upstream_node (bool active_only=false)
template<typename T , typename value_type >
UHD_INLINE value_type find_downstream_unique_property (boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >())
UHD_INLINE value_type find_upstream_unique_property (boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >())
- Public Member Functions inherited from uhd::rfnoc::sink_node_ctrl
size_t connect_upstream (node_ctrl_base::sptr upstream_node, size_t port=ANY_PORT, const uhd::device_addr_t &args=uhd::device_addr_t())
virtual void set_tx_streamer (bool active, const size_t port)
virtual size_t _request_input_port (const size_t suggested_port, const uhd::device_addr_t &args) const
- Protected Member Functions inherited from uhd::rfnoc::block_ctrl_base
 block_ctrl_base (void)
virtual ~block_ctrl_base ()
 block_ctrl_base (const make_args_t &make_args)
stream_sig_t _resolve_port_def (const blockdef::port_t &port_def) const
uhd::fs_path get_arg_path (const std::string &key, size_t port=0) const
 Return the property tree path to a block argument key on port. More...
timed_wb_iface::sptr get_ctrl_iface (const size_t block_port)
 Get a control interface object for block port block_port. More...
virtual void _clear (const size_t port=0)
 Override this function if your block does something else. More...
virtual void _set_command_time (const time_spec_t &time_spec, const size_t port=ANY_PORT)
 Override this function if your block needs to specially handle. More...
- Protected Member Functions inherited from uhd::rfnoc::node_ctrl_base
 node_ctrl_base (void)
virtual ~node_ctrl_base ()
virtual void _register_downstream_node (node_ctrl_base::sptr downstream_node, size_t port)
void update_graph ()
- Static Public Member Functions inherited from uhd::rfnoc::block_ctrl_base
static void register_block (const make_t &make, const std::string &name)
static sptr make (const make_args_t &make_args, uint64_t noc_id=~0)
 Create a block controller class given a NoC-ID or a block name. More...
- Protected Attributes inherited from uhd::rfnoc::block_ctrl_base
uhd::property_tree::sptr _tree
 Property sub-tree. More...
uhd::fs_path _root_path
 Root node of this block's properties. More...
blockdef::sptr _block_def
 Block definition (stores info about the block such as ports) More...
- Protected Attributes inherited from uhd::rfnoc::node_ctrl_base
uhd::device_addr_t _args
 Stores default arguments. More...
node_map_t _upstream_nodes
 List of upstream nodes. More...
node_map_t _downstream_nodes
 List of downstream nodes. More...
size_t _num_input_ports
size_t _num_output_ports
std::map< size_t, bool > _rx_streamer_active
std::map< size_t, bool > _tx_streamer_active
◆ _request_input_port()
virtual size_t uhd::rfnoc::sink_block_ctrl_base::_request_input_port ( const size_t  suggested_port,
const uhd::device_addr_t &  args
) const
protectedvirtual
Like sink_node_ctrl::_request_input_port(), but also checks the port has an input signature.
Reimplemented from uhd::rfnoc::sink_node_ctrl.
◆ configure_flow_control_in()
virtual void uhd::rfnoc::sink_block_ctrl_base::configure_flow_control_in ( const size_t  bytes,
const size_t  block_port = 0
virtual
Configure flow control for incoming streams.
If flow control is enabled for incoming streams, this block will periodically send out ACKs, telling the upstream block which packets have been consumed, so the upstream block can increase his flow control credit.
In the default implementation, this just sets register SR_FLOW_CTRL_PKTS_PER_ACK accordingly.
Override this function if your block has port-specific flow control settings.
bytesSend an ACK after this many bytes have been consumed. Setting this to zero disables flow control acknowledgement.
block_portSet up flow control for a stream coming in on this particular block port.
◆ get_fifo_size()
size_t uhd::rfnoc::sink_block_ctrl_base::get_fifo_size ( size_t  block_port = 0) const
Return the size of input buffer on a given block port.
This is necessary for setting up flow control, among other things. Note: This does not query the block's settings register. The FIFO size is queried once during construction and cached.
If the block port is not defined, it will return 0, and not throw.
block_portThe block port (0 through 15).
Returns the size of the buffer in bytes.
◆ get_input_ports()
std::vector<size_t> uhd::rfnoc::sink_block_ctrl_base::get_input_ports ( ) const
Return a list of valid input ports.
◆ get_input_signature()
stream_sig_t uhd::rfnoc::sink_block_ctrl_base::get_input_signature ( size_t  block_port = 0) const
Return the input stream signature for a given block port.
The actual signature is determined by the current configuration and the block definition file. The value returned here is calculated on-the-fly and is only valid as long as the configuration does not change.
The stream signature for port block_port
Exceptions
uhd::runtime_errorif block_port is not a valid port
◆ get_mtu()
size_t uhd::rfnoc::sink_block_ctrl_base::get_mtu ( size_t  block_port = 0) const
Return the MTU size on a given block port.
This is necessary for setting up transports, among other things.
Returns the MTU in bytes.
◆ set_error_policy()
virtual void uhd::rfnoc::sink_block_ctrl_base::set_error_policy ( const std::string &  policy)
virtual
Configure the behaviour for errors on incoming packets (e.g. sequence errors).
