11#define UHD_USRP_MULTI_USRP_REF_SOURCES_API
   12#define UHD_USRP_MULTI_USRP_GET_RATES_API
   13#define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API
   14#define UHD_USRP_MULTI_USRP_FRONTEND_IQ_AUTO_API
   15#define UHD_USRP_MULTI_USRP_COMMAND_TIME_API
   16#define UHD_USRP_MULTI_USRP_BW_RANGE_API
   17#define UHD_USRP_MULTI_USRP_USER_REGS_API
   18#define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API
   19#define UHD_USRP_MULTI_USRP_NORMALIZED_GAIN
   20#define UHD_USRP_MULTI_USRP_GPIO_API
   21#define UHD_USRP_MULTI_USRP_REGISTER_API
   22#define UHD_USRP_MULTI_USRP_FILTER_API
   23#define UHD_USRP_MULTI_USRP_LO_CONFIG_API
   24#define UHD_USRP_MULTI_USRP_TX_LO_CONFIG_API
   25#define UHD_USRP_MULTI_USRP_POWER_LEVEL
   99    typedef std::shared_ptr<multi_usrp>
sptr;
  262        const time_spec_t& time_spec,
size_t mboard = ALL_MBOARDS) = 0;
  277        const time_spec_t& time_spec,
  337        const stream_cmd_t& stream_cmd,
size_t chan = ALL_CHANS) = 0;
  382        const std::string&
source,
const size_t mboard = ALL_MBOARDS) = 0;
  441        const std::string&
source,
  468        const std::string& time_source,
  469        const size_t mboard = ALL_MBOARDS) = 0;
  494        const device_addr_t& sync_source,
  519        const bool enb,
  530        const bool enb,
  544        const std::string& name,
size_t mboard = 0) = 0;
  563        const uint8_t addr,
const uint32_t data,
  650    virtual void set_rx_rate(
double rate,
  661    virtual void set_rx_spp(
const size_t spp,
const size_t chan = ALL_CHANS) = 0;
  741        const std::string& src,
const std::string& name = ALL_LOS,
size_t chan = 0) = 0;
  752        const std::string& name = ALL_LOS,
  766        const std::string& name = ALL_LOS,
  779        bool enabled,
  787        const std::string& name = ALL_LOS,
  813        double freq,
  837        const std::string& name,
  865        const std::string& name = ALL_LOS,
  866        const size_t chan       = 0) = 0;
  877        const std::string& name = ALL_LOS,
  890        const std::string& name = ALL_LOS,
  903        const bool enabled,
  911        const std::string& name = ALL_LOS,
  937        const double freq,
  949    virtual double get_tx_lo_freq(
  961        const std::string& name,
  973    virtual void set_rx_gain(
double gain,
  995        const std::string& profile,
 1007        return this->set_rx_gain(gain, ALL_GAINS, chan);
 1045    virtual double get_rx_gain(
 1050        return this->get_rx_gain(ALL_GAINS, chan);
 1077        return this->get_rx_gain_range(ALL_GAINS, chan);
 1176        const std::complex<double>& offset,
 1200        const std::complex<double>& correction,
 1239        const double power_dbm,
 1363    virtual void set_tx_gain(
double gain,
 1385        const std::string& profile,
 1397        return this->set_tx_gain(gain, ALL_GAINS, chan);
 1419    virtual double get_tx_gain(
 1424        return this->get_tx_gain(ALL_GAINS, chan);
 1451        return this->get_tx_gain_range(ALL_GAINS, chan);
 1498        const double power_dbm,
 1598        const std::complex<double>& offset,
 1614        const std::complex<double>& correction,
 1644        const std::string& attr,
 1645        const uint32_t value,
 1646        const uint32_t
mask = 0xffffffff,
 1647        const size_t mboard = 0) = 0;
 1666        const std::string& bank,
 1694        const std::string& bank,
 1706        const std::string& bank,
 1719        const std::vector<std::string>& src,
 1720        const size_t mboard = 0) = 0;
 1743        const std::string& name,
const size_t chan) = 0;
 1754        const size_t chan) = 0;
 1774        const std::string& name,
 1785        const size_t chan) = 0;
std::shared_ptr< device > sptr
Definition: device.hpp:29
std::shared_ptr< filter_info_base > sptr
Definition: filters.hpp:26
Definition: property_tree.hpp:217
Definition: radio_control.hpp:25
Definition: stream.hpp:172
Definition: time_spec.hpp:31
std::shared_ptr< tx_streamer > sptr
Definition: stream.hpp:250
std::shared_ptr< dboard_iface > sptr
Definition: dboard_iface.hpp:55
Definition: multi_usrp.hpp:97
virtual void set_rx_filter(const std::string &name, uhd::filter_info_base::sptr filter, const size_t chan)=0
virtual uhd::usrp::subdev_spec_t get_tx_subdev_spec(size_t mboard=0)=0
virtual meta_range_t get_rx_power_range(const size_t chan)=0
virtual tx_streamer::sptr get_tx_stream(const stream_args_t &args)=0
Convenience method to get a TX streamer. See also uhd::device::get_tx_stream().
Definition: multi_usrp.hpp:1395
virtual std::string get_time_source(const size_t mboard)=0
virtual void set_command_time(const uhd::time_spec_t &time_spec, size_t mboard=ALL_MBOARDS)=0
virtual meta_range_t get_master_clock_rate_range(const size_t mboard=0)=0
static const std::string ALL_LOS
A wildcard LO stage name.
Definition: multi_usrp.hpp:113
virtual std::vector< device_addr_t > get_sync_sources(const size_t mboard)=0
virtual void set_tx_lo_export_enabled(const bool enabled, const std::string &name=ALL_LOS, const size_t chan=0)=0
virtual std::string get_clock_source(const size_t mboard)=0
virtual void set_rx_spp(const size_t spp, const size_t chan=ALL_CHANS)=0
virtual std::vector< std::string > get_rx_sensor_names(size_t chan=0)=0
static const size_t ALL_MBOARDS
A wildcard motherboard index.
Definition: multi_usrp.hpp:104
virtual std::vector< std::string > get_tx_filter_names(const size_t chan)=0
virtual double get_tx_bandwidth(size_t chan=0)=0
virtual void set_tx_dc_offset(const std::complex< double > &offset, size_t chan=ALL_CHANS)=0
virtual device_addr_t get_sync_source(const size_t mboard)=0
virtual double get_tx_rate(size_t chan=0)=0
virtual sensor_value_t get_mboard_sensor(const std::string &name, size_t mboard=0)=0
virtual void set_rx_gain_profile(const std::string &profile, const size_t chan=0)=0
virtual std::vector< std::string > get_rx_antennas(size_t chan=0)=0
virtual dboard_iface::sptr get_rx_dboard_iface(size_t chan=0)=0
virtual std::string get_rx_subdev_name(size_t chan=0)=0
virtual void set_time_now(const time_spec_t &time_spec, size_t mboard=ALL_MBOARDS)=0
virtual meta_range_t get_tx_rates(size_t chan=0)=0
virtual std::vector< std::string > get_tx_antennas(size_t chan=0)=0
virtual std::vector< std::string > get_tx_lo_names(size_t chan=0)=0
virtual void set_time_source_out(const bool enb, const size_t mboard=ALL_MBOARDS)=0
virtual std::vector< std::string > get_rx_lo_sources(const std::string &name=ALL_LOS, size_t chan=0)=0
virtual double get_rx_lo_freq(const std::string &name, size_t chan=0)=0
virtual double set_rx_lo_freq(double freq, const std::string &name, size_t chan=0)=0
virtual void set_tx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard=ALL_MBOARDS)=0
virtual size_t get_tx_num_channels(void)=0
virtual double get_tx_power_reference(const size_t chan=0)=0
virtual std::vector< std::string > get_rx_lo_names(size_t chan=0)=0
virtual void set_time_unknown_pps(const time_spec_t &time_spec)=0
virtual void set_user_register(const uint8_t addr, const uint32_t data, size_t mboard=ALL_MBOARDS)=0
virtual void set_tx_gain(double gain, const std::string &name, size_t chan=0)=0
virtual std::vector< std::string > get_rx_filter_names(const size_t chan)=0
virtual sensor_value_t get_tx_sensor(const std::string &name, size_t chan=0)=0
virtual bool get_rx_lo_export_enabled(const std::string &name=ALL_LOS, size_t chan=0)=0
virtual std::string get_tx_subdev_name(size_t chan=0)=0
virtual double get_rx_gain(const std::string &name, size_t chan=0)=0
virtual const std::string get_rx_lo_source(const std::string &name=ALL_LOS, size_t chan=0)=0
virtual void set_rx_bandwidth(double bandwidth, size_t chan=0)=0
virtual void set_tx_antenna(const std::string &ant, size_t chan=0)=0
virtual meta_range_t get_tx_power_range(const size_t chan)=0
virtual void set_gpio_src(const std::string &bank, const std::vector< std::string > &src, const size_t mboard=0)=0
virtual bool get_tx_lo_export_enabled(const std::string &name=ALL_LOS, const size_t chan=0)=0
static const std::string ALL_GAINS
A wildcard gain element name.
Definition: multi_usrp.hpp:110
virtual std::string get_rx_gain_profile(const size_t chan=0)=0
virtual std::vector< std::string > get_tx_gain_names(size_t chan=0)=0
virtual rx_streamer::sptr get_rx_stream(const stream_args_t &args)=0
Convenience method to get a RX streamer. See also uhd::device::get_rx_stream().
virtual time_spec_t get_time_last_pps(size_t mboard=0)=0
virtual void set_time_source(const std::string &source, const size_t mboard=ALL_MBOARDS)=0
virtual void set_gpio_attr(const std::string &bank, const std::string &attr, const uint32_t value, const uint32_t mask=0xffffffff, const size_t mboard=0)=0
virtual void set_rx_iq_balance(const bool enb, size_t chan)=0
virtual void set_rx_rate(double rate, size_t chan=ALL_CHANS)=0
virtual std::vector< std::string > get_time_sources(const size_t mboard)=0
virtual void set_clock_source_out(const bool enb, const size_t mboard=ALL_MBOARDS)=0
virtual void clear_command_time(size_t mboard=ALL_MBOARDS)=0
virtual meta_range_t get_rx_dc_offset_range(size_t chan=0)=0
Definition: multi_usrp.hpp:1422
Definition: multi_usrp.hpp:1048
virtual std::vector< std::string > get_gpio_banks(const size_t mboard)=0
virtual double get_normalized_rx_gain(size_t chan=0)=0
virtual void set_sync_source(const device_addr_t &sync_source, const size_t mboard=ALL_MBOARDS)=0
virtual meta_range_t get_rx_rates(size_t chan=0)=0
virtual ~multi_usrp(void)=0
virtual double set_tx_lo_freq(const double freq, const std::string &name, const size_t chan=0)=0
virtual double get_tx_lo_freq(const std::string &name, const size_t chan=0)=0
Definition: multi_usrp.hpp:1449
virtual std::vector< std::string > get_mboard_sensor_names(size_t mboard=0)=0
virtual std::vector< std::string > get_gpio_src(const std::string &bank, const size_t mboard=0)=0
virtual void set_rx_antenna(const std::string &ant, size_t chan=0)=0
virtual std::vector< std::string > get_rx_gain_profile_names(const size_t chan=0)=0
virtual void set_clock_source(const std::string &source, const size_t mboard=ALL_MBOARDS)=0
virtual void set_time_next_pps(const time_spec_t &time_spec, size_t mboard=ALL_MBOARDS)=0
virtual void set_rx_dc_offset(const bool enb, size_t chan=ALL_CHANS)=0
virtual freq_range_t get_tx_lo_freq_range(const std::string &name, const size_t chan=0)=0
virtual void set_rx_iq_balance(const std::complex< double > &correction, size_t chan=ALL_CHANS)=0
virtual gain_range_t get_rx_gain_range(const std::string &name, size_t chan=0)=0
Definition: multi_usrp.hpp:1075
virtual std::string get_tx_antenna(size_t chan=0)=0
virtual void set_rx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard=ALL_MBOARDS)=0
virtual void set_tx_gain_profile(const std::string &profile, const size_t chan=0)=0
Definition: multi_usrp.hpp:1005
virtual const std::string get_tx_lo_source(const std::string &name=ALL_LOS, const size_t chan=0)=0
virtual uint32_t get_gpio_attr(const std::string &bank, const std::string &attr, const size_t mboard=0)=0
virtual void set_rx_lo_source(const std::string &src, const std::string &name=ALL_LOS, size_t chan=0)=0
virtual uhd::wb_iface::sptr get_user_settings_iface(const size_t chan=0)=0
virtual freq_range_t get_tx_freq_range(size_t chan=0)=0
virtual uhd::filter_info_base::sptr get_rx_filter(const std::string &name, const size_t chan)=0
virtual void set_rx_dc_offset(const std::complex< double > &offset, size_t chan=ALL_CHANS)=0
virtual uhd::usrp::subdev_spec_t get_rx_subdev_spec(size_t mboard=0)=0
virtual double get_rx_bandwidth(size_t chan=0)=0
virtual void set_master_clock_rate(double rate, size_t mboard=ALL_MBOARDS)=0
virtual freq_range_t get_rx_freq_range(size_t chan=0)=0
virtual double get_tx_freq(size_t chan=0)=0
virtual tune_result_t set_rx_freq(const tune_request_t &tune_request, size_t chan=0)=0
virtual double get_rx_rate(size_t chan=0)=0
virtual double get_rx_power_reference(const size_t chan=0)=0
virtual std::string get_pp_string(void)=0
virtual std::vector< std::string > get_gpio_srcs(const std::string &bank, const size_t mboard=0)=0
virtual std::string get_tx_gain_profile(const size_t chan=0)=0
virtual double get_normalized_tx_gain(size_t chan=0)=0
virtual std::vector< std::string > get_clock_sources(const size_t mboard)=0
virtual uhd::rfnoc::radio_control & get_radio_control(const size_t chan=0)=0
virtual std::vector< std::string > get_tx_lo_sources(const std::string &name=ALL_LOS, const size_t chan=0)=0
virtual void set_normalized_tx_gain(double gain, size_t chan=0)=0
virtual meta_range_t get_tx_dc_offset_range(size_t chan=0)=0
virtual uhd::property_tree::sptr get_tree(void) const =0
virtual void set_normalized_rx_gain(double gain, size_t chan=0)=0
virtual void set_tx_rate(double rate, size_t chan=ALL_CHANS)=0
virtual dict< std::string, std::string > get_usrp_rx_info(size_t chan=0)=0
virtual gain_range_t get_tx_gain_range(const std::string &name, size_t chan=0)=0
virtual void set_rx_agc(bool enable, size_t chan=0)=0
virtual dboard_iface::sptr get_tx_dboard_iface(size_t chan=0)=0
virtual meta_range_t get_tx_bandwidth_range(size_t chan=0)=0
virtual std::string get_mboard_name(size_t mboard=0)=0
virtual void set_tx_power_reference(const double power_dbm, const size_t chan=0)=0
virtual device::sptr get_device(void)=0
virtual void set_rx_lo_export_enabled(bool enabled, const std::string &name=ALL_LOS, size_t chan=0)=0
virtual freq_range_t get_fe_rx_freq_range(size_t chan=0)=0
virtual void set_sync_source(const std::string &clock_source, const std::string &time_source, const size_t mboard=ALL_MBOARDS)=0
std::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:99
virtual std::vector< std::string > get_gpio_src_banks(const size_t mboard=0)=0
virtual sensor_value_t get_rx_sensor(const std::string &name, size_t chan=0)=0
virtual bool get_time_synchronized(void)=0
virtual void set_tx_bandwidth(double bandwidth, size_t chan=0)=0
virtual std::string get_rx_antenna(size_t chan=0)=0
virtual uhd::filter_info_base::sptr get_tx_filter(const std::string &name, const size_t chan)=0
virtual freq_range_t get_fe_tx_freq_range(size_t chan=0)=0
virtual void set_rx_gain(double gain, const std::string &name, size_t chan=0)=0
virtual void set_tx_iq_balance(const std::complex< double > &correction, size_t chan=ALL_CHANS)=0
virtual double get_rx_freq(size_t chan=0)=0
virtual freq_range_t get_rx_lo_freq_range(const std::string &name, size_t chan=0)=0
virtual size_t get_num_mboards(void)=0
virtual tune_result_t set_tx_freq(const tune_request_t &tune_request, size_t chan=0)=0
virtual double get_tx_gain(const std::string &name, size_t chan=0)=0
virtual double get_master_clock_rate(size_t mboard=0)=0
virtual bool has_rx_power_reference(const size_t chan=0)=0
virtual bool has_tx_power_reference(const size_t chan=0)=0
virtual void set_tx_filter(const std::string &name, uhd::filter_info_base::sptr filter, const size_t chan)=0
virtual meta_range_t get_rx_bandwidth_range(size_t chan=0)=0
virtual std::vector< std::string > get_rx_gain_names(size_t chan=0)=0
virtual std::vector< std::string > get_tx_gain_profile_names(const size_t chan=0)=0
virtual void set_tx_lo_source(const std::string &src, const std::string &name=ALL_LOS, const size_t chan=0)=0
virtual void set_rx_power_reference(const double power_dbm, const size_t chan=0)=0
virtual size_t get_rx_num_channels(void)=0
virtual time_spec_t get_time_now(size_t mboard=0)=0
virtual std::vector< std::string > get_tx_sensor_names(size_t chan=0)=0
virtual void issue_stream_cmd(const stream_cmd_t &stream_cmd, size_t chan=ALL_CHANS)=0
virtual dict< std::string, std::string > get_usrp_tx_info(size_t chan=0)=0
static const size_t ALL_CHANS
A wildcard channel index.
Definition: subdev_spec.hpp:60
std::shared_ptr< wb_iface > sptr
Definition: wb_iface.hpp:20
Definition: config.h:67
Definition: soft_register.hpp:87
source
Identify the source of calibration data, i.e., where was it stored.
Definition: database.hpp:22
Definition: build_info.hpp:12
Definition: sensors.hpp:29
Definition: stream.hpp:59
Definition: stream_cmd.hpp:36
Definition: tune_request.hpp:25
Definition: tune_result.hpp:19
