19namespace uhd {
namespace rfnoc {
   39    virtual
double set_rate(const
double rate) = 0;
  158        const
std::
string& name, const
size_t chan) const = 0;
  182    virtual
double set_tx_gain(const
double gain, const
size_t chan) = 0;
  192        const
double gain, const
std::
string& name, const
size_t chan) = 0;
  227        const
double power_dbm, const
size_t chan) = 0;
  286        const
std::
string& name, const
  307    virtual
double set_rx_gain(const
double gain, const
size_t chan) = 0;
  317        const
double gain, const
std::
string& name, const
size_t chan) = 0;
  323    virtual
void set_rx_agc(const
bool enable, const
size_t chan) = 0;
  358        const
size_t chan) = 0;
  409        const
  414        const
  487        const
std::
string& name, const
  498        const
std::
string& name, const
  510        const
std::
string& src, const
std::
string& name, const
size_t chan) = 0;
  521        const
std::
string& name, const
size_t chan) = 0;
  532        bool enabled, const
std::
string& name, const
size_t chan) = 0;
  540        const
std::
string& name, const
  550        double freq, const
std::
string& name, const
size_t chan) = 0;
  578        const
std::
string& name, const
size_t chan) = 0;
  589        const
std::
string& name, const
size_t chan) = 0;
  601        const
std::
string& src, const
std::
string& name, const
size_t chan) = 0;
  612        const
std::
string& name, const
size_t chan) = 0;
  623        const
bool enabled, const
std::
string& name, const
size_t chan) = 0;
  642        const
double freq, const
std::
string& name, const
size_t chan) = 0;
  683        const
std::complex<
double>& correction,
size_t chan) = 0;
  726        const
std::complex<
size_t chan) = 0;
  752        const
std::
string& bank, const
std::
string& attr, const uint32_t value) = 0;
Definition: discoverable_feature_getter_iface.hpp:18
Definition: noc_block_base.hpp:42
Definition: radio_control.hpp:25
virtual std::string get_rx_antenna(const size_t chan) const =0
virtual std::vector< std::string > get_rx_sensor_names(size_t chan) const =0
virtual std::string get_dboard_fe_from_chan(const size_t chan, const uhd::direction_t direction) const =0
Return the frontend name for a channel index.
virtual uhd::freq_range_t get_tx_frequency_range(const size_t chan) const =0
virtual meta_range_t get_tx_power_range(const size_t chan)=0
virtual const std::string get_rx_lo_source(const std::string &name, const size_t chan)=0
virtual uint32_t get_gpio_attr(const std::string &bank, const std::string &attr)=0
virtual double get_tx_gain(const size_t chan)=0
virtual meta_range_t get_rx_dc_offset_range(size_t chan) const =0
virtual void set_tx_dc_offset(const std::complex< double > &offset, size_t chan)=0
virtual std::string get_slot_name() const =0
Returns this radio's slot name (typically "A" or "B")
virtual std::vector< std::string > get_tx_lo_names(const size_t chan) const =0
virtual const std::string get_tx_lo_source(const std::string &name, const size_t chan)=0
virtual meta_range_t get_tx_bandwidth_range(size_t chan) const =0
virtual double set_rx_frequency(const double freq, const size_t chan)=0
virtual double set_tx_bandwidth(const double bandwidth, const size_t chan)=0
virtual double get_tx_lo_freq(const std::string &name, const size_t chan)=0
virtual void issue_stream_cmd(const uhd::stream_cmd_t &stream_cmd, const size_t port)=0
virtual bool get_tx_lo_export_enabled(const std::string &name, const size_t chan)=0
virtual void set_tx_tune_args(const uhd::device_addr_t &args, const size_t chan)=0
virtual void set_rx_iq_balance(const bool enb, size_t chan)=0
static const std::string ALL_LOS
Definition: radio_control.hpp:27
virtual double get_tx_frequency(const size_t chan)=0
virtual void enable_rx_timestamps(const bool enable, const size_t chan)=0
virtual double set_rx_bandwidth(const double bandwidth, const size_t chan)=0
virtual void set_db_eeprom(const uhd::eeprom_map_t &db_eeprom)=0
Update the daughterboard EEPROM.
virtual void set_tx_lo_export_enabled(const bool enabled, const std::string &name, const size_t chan)=0
virtual std::vector< std::string > get_rx_power_ref_keys(const size_t chan=0)=0
virtual uhd::gain_range_t get_rx_gain_range(const size_t chan) const =0
virtual double get_rx_frequency(const size_t chan)=0
virtual std::vector< std::string > get_gpio_banks() const =0
virtual std::vector< std::string > get_tx_antennas(const size_t chan) const =0
virtual uhd::eeprom_map_t get_db_eeprom()=0
Return the content of the daughterboard EEPROM.
virtual std::vector< std::string > get_tx_sensor_names(size_t chan) const =0
virtual uhd::freq_range_t get_rx_frequency_range(const size_t chan) const =0
virtual std::vector< std::string > get_rx_gain_profile_names(const size_t chan) const =0
virtual std::vector< std::string > get_tx_power_ref_keys(const size_t chan=0)=0
virtual uhd::meta_range_t get_rate_range() const =0
Return a list of valid rates.
virtual std::vector< std::string > get_rx_lo_sources(const std::string &name, const size_t chan) const =0
virtual double get_rate() const =0
Get the sample rate.
virtual void set_tx_iq_balance(const std::complex< double > &correction, size_t chan)=0
virtual double set_tx_gain(const double gain, const size_t chan)=0
virtual void set_rx_antenna(const std::string &ant, const size_t chan)=0
virtual std::string get_tx_antenna(const size_t chan) const =0
virtual double set_rate(const double rate)=0
Set the sample rate.
virtual freq_range_t get_rx_lo_freq_range(const std::string &name, const size_t chan) const =0
virtual void set_rx_dc_offset(const bool enb, size_t chan=ALL_CHANS)=0
virtual double set_rx_gain(const double gain, const size_t chan)=0
virtual double get_rx_power_reference(const size_t chan)=0
virtual uhd::sensor_value_t get_rx_sensor(const std::string &name, size_t chan)=0
virtual freq_range_t get_tx_lo_freq_range(const std::string &name, const size_t chan)=0
virtual meta_range_t get_tx_dc_offset_range(size_t chan) const =0
virtual double get_rx_gain(const size_t chan)=0
virtual void set_rx_power_reference(const double power_dbm, const size_t chan)=0
virtual void set_rx_gain_profile(const std::string &profile, const size_t chan)=0
virtual meta_range_t get_rx_bandwidth_range(size_t chan) const =0
virtual double get_rx_bandwidth(const size_t chan)=0
virtual bool has_tx_power_reference(const size_t chan)=0
virtual std::vector< std::string > get_tx_gain_profile_names(const size_t chan) const =0
virtual void set_rx_agc(const bool enable, const size_t chan)=0
virtual std::vector< std::string > get_tx_gain_names(const size_t chan) const =0
virtual double get_tx_power_reference(const size_t chan)=0
virtual std::string get_tx_gain_profile(const size_t chan) const =0
static const std::string ALL_GAINS
Definition: radio_control.hpp:28
virtual std::vector< std::string > get_rx_antennas(const size_t chan) const =0
static constexpr size_t ALL_CHANS
Definition: radio_control.hpp:29
virtual std::vector< std::string > get_rx_lo_names(const size_t chan) const =0
virtual double set_tx_frequency(const double freq, size_t chan)=0
virtual void set_tx_power_reference(const double power_dbm, const size_t chan)=0
virtual void set_gpio_attr(const std::string &bank, const std::string &attr, const uint32_t value)=0
virtual uhd::gain_range_t get_tx_gain_range(const size_t chan) const =0
virtual void set_tx_antenna(const std::string &ant, const size_t chan)=0
virtual std::vector< std::string > get_rx_gain_names(const size_t chan) const =0
virtual void set_tx_gain_profile(const std::string &profile, const size_t chan)=0
virtual bool has_rx_power_reference(const size_t chan)=0
virtual double set_tx_lo_freq(const double freq, const std::string &name, const size_t chan)=0
virtual void set_tx_lo_source(const std::string &src, const std::string &name, const size_t chan)=0
virtual std::string get_fe_name(const size_t chan, const uhd::direction_t direction) const =0
Return the name of the frontend, as given by the dboard driver.
virtual size_t get_chan_from_dboard_fe(const std::string &fe, const uhd::direction_t direction) const =0
Return the channel that corresponds to a frontend's name.
virtual std::vector< std::string > get_tx_lo_sources(const std::string &name, const size_t chan)=0
virtual double set_rx_lo_freq(double freq, const std::string &name, const size_t chan)=0
virtual double get_rx_lo_freq(const std::string &name, const size_t chan)=0
virtual meta_range_t get_rx_power_range(const size_t chan)=0
virtual void set_rx_lo_export_enabled(bool enabled, const std::string &name, const size_t chan)=0
virtual double get_tx_bandwidth(const size_t chan)=0
virtual uhd::sensor_value_t get_tx_sensor(const std::string &name, size_t chan)=0
virtual bool get_rx_lo_export_enabled(const std::string &name, const size_t chan) const =0
virtual std::string get_rx_gain_profile(const size_t chan) const =0
virtual void set_rx_lo_source(const std::string &src, const std::string &name, const size_t chan)=0
virtual void set_rx_tune_args(const uhd::device_addr_t &args, const size_t chan)=0
Definition: build_info.hpp:12
direction_t
Definition: direction.hpp:12
std::map< std::string, std::vector< uint8_t > > eeprom_map_t
Definition: eeprom.hpp:15
#define RFNOC_DECLARE_BLOCK(CLASS_NAME)
Definition: noc_block_base.hpp:21
Definition: sensors.hpp:29
Definition: stream_cmd.hpp:36
