uhd::rfnoc::mb_controller::timekeeper Class Referenceabstract
#include <uhd/rfnoc/mb_controller.hpp>
using sptr = std::shared_ptr< timekeeper >
using write_period_fn_t = std::function< void(uint64_t)>
 timekeeper ()
virtual ~timekeeper ()
uhd::time_spec_t get_time_now (void)
virtual uint64_t get_ticks_now ()=0
uhd::time_spec_t get_time_last_pps (void)
virtual uint64_t get_ticks_last_pps ()=0
void set_time_now (const uhd::time_spec_t &time)
virtual void set_ticks_now (const uint64_t ticks)=0
void set_time_next_pps (const uhd::time_spec_t &time)
virtual void set_ticks_next_pps (const uint64_t ticks)=0
double get_tick_rate ()
void set_tick_rate (const double rate)
virtual void set_period (const uint64_t period_ns)=0
Interface to interact with timekeepers
Timekeepers are objects separate from RFNoC blocks. This class is meant to be subclassed by motherboards implementing it.
◆ write_period_fn_t
using uhd::rfnoc::mb_controller::timekeeper::write_period_fn_t = std::function<void(uint64_t)>
◆ timekeeper()
uhd::rfnoc::mb_controller::timekeeper::timekeeper ( )
◆ ~timekeeper()
virtual uhd::rfnoc::mb_controller::timekeeper::~timekeeper ( )
◆ get_tick_rate()
double uhd::rfnoc::mb_controller::timekeeper::get_tick_rate ( )
Return the current tick rate
◆ get_ticks_last_pps()
virtual uint64_t uhd::rfnoc::mb_controller::timekeeper::get_ticks_last_pps ( )
Return the time from the last PPS as a tick count
See also get_time_last_pps()
◆ get_ticks_now()
virtual uint64_t uhd::rfnoc::mb_controller::timekeeper::get_ticks_now ( )
Return the current time as a tick count
See also get_time_now().
the current time
◆ get_time_last_pps()
uhd::time_spec_t uhd::rfnoc::mb_controller::timekeeper::get_time_last_pps ( void  )
Return the time from the last PPS as a time spec
Note that there is no control over when this command gets executed, it will read the time "as soon as possible", and then return that value. Calling this on two synchronized clocks sequentially will definitely return two different values.
◆ get_time_now()
uhd::time_spec_t uhd::rfnoc::mb_controller::timekeeper::get_time_now ( void  )
Return the current time as a time spec
the current time
◆ set_period()
virtual void uhd::rfnoc::mb_controller::timekeeper::set_period ( const uint64_t  period_ns)
protectedpure virtual
Set the time period as a 64-bit Q32 value
period_nsThe period as nanoseconds per tick, in Q32 format
◆ set_tick_rate()
void uhd::rfnoc::mb_controller::timekeeper::set_tick_rate ( const double  rate)
Set the tick rate
This doesn't change the input clock to the timekeeper, but does two things:
  • Update the local value of the tick rate, so the time-spec based API calls work
  • Convert the tick rate to a period and call set_period()
◆ set_ticks_next_pps()
virtual void uhd::rfnoc::mb_controller::timekeeper::set_ticks_next_pps ( const uint64_t  ticks)
Set the ticks at next PPS
◆ set_ticks_now()
virtual void uhd::rfnoc::mb_controller::timekeeper::set_ticks_now ( const uint64_t  ticks)
Set the ticks "now"
◆ set_time_next_pps()
void uhd::rfnoc::mb_controller::timekeeper::set_time_next_pps ( const uhd::time_spec_t &  time)
Set the time at next PPS from a time spec
◆ set_time_now()
void uhd::rfnoc::mb_controller::timekeeper::set_time_now ( const uhd::time_spec_t &  time)
Set the time "now" from a time spec
