mb_controller.hpp
1//
2// Copyright 2019 Ettus Research, a National Instruments Brand
3//
4// SPDX-License-Identifier: GPL-3.0-or-later
5//
6
7#pragma once
8
9#include <uhd/config.hpp>
12#include <uhd/types/sensors.hpp>
16#include <unordered_map>
17#include <functional>
18#include <memory>
19#include <vector>
21namespace uhd { namespace rfnoc {
22
27{
28public:
29 using sptr = std::shared_ptr<mb_controller>;
31
37 using sync_source_updater_t = std::function<void(const sync_source_t& sync_source)>;
38
39 virtual ~mb_controller() {}
40
41 /**************************************************************************
42 * Timebase API
43 *************************************************************************/
50 {
51 public:
52 using sptr = std::shared_ptr<timekeeper>;
53 using write_period_fn_t = std::function<void(uint64_t)>;
54
56
57 virtual ~timekeeper() {}
58
69
76 virtual uint64_t get_ticks_now() = 0;
77
86
91 virtual uint64_t get_ticks_last_pps() = 0;
92
95 void set_time_now(const uhd::time_spec_t& time);
96
99 virtual void set_ticks_now(const uint64_t ticks) = 0;
100
104
107 virtual void set_ticks_next_pps(const uint64_t ticks) = 0;
108
112 {
113 return _tick_rate;
114 }
115
116 protected:
125 void set_tick_rate(const double rate);
126
131 virtual void set_period(const uint64_t period_ns) = 0;
132
133 private:
135 double _tick_rate = 1.0;
136 };
137
139 // on this device.
140 size_t get_num_timekeepers() const;
141
143 //
144 // \throws uhd::index_error if \p tk_idx is not valid
145 timekeeper::sptr get_timekeeper(const size_t tk_idx) const;
146
147 /**************************************************************************
148 * Motherboard Control
149 *************************************************************************/
152 virtual void init() {}
153
158 virtual std::string get_mboard_name() const = 0;
159
201 virtual void set_time_source(const std::string& source) = 0;
202
207 virtual std::string get_time_source() const = 0;
208
213 virtual std::vector<std::string> get_time_sources() const = 0;
214
256 virtual void set_clock_source(const std::string& source) = 0;
257
262 virtual std::string get_clock_source() const = 0;
263
268 virtual std::vector<std::string> get_clock_sources() const = 0;
269
279 virtual void set_sync_source(
280 const std::string& clock_source, const std::string& time_source) = 0;
281
303 virtual void set_sync_source(const uhd::device_addr_t& sync_source) = 0;
304
310
315 virtual std::vector<uhd::device_addr_t> get_sync_sources() = 0;
316
324 virtual void set_clock_source_out(const bool enb) = 0;
325
333 virtual void set_time_source_out(const bool enb) = 0;
334
340 virtual uhd::sensor_value_t get_sensor(const std::string& name) = 0;
341
346 virtual std::vector<std::string> get_sensor_names() = 0;
347
351
366 virtual bool synchronize(std::vector<mb_controller::sptr>& mb_controllers,
367 const uhd::time_spec_t& time_spec = uhd::time_spec_t(0.0),
368 const bool quiet = false);
369
375 virtual std::vector<std::string> get_gpio_banks() const;
376
382 virtual std::vector<std::string> get_gpio_srcs(const std::string& bank) const;
383
386 virtual std::vector<std::string> get_gpio_src(const std::string& bank);
387
395 virtual void set_gpio_src(
396 const std::string& bank, const std::vector<std::string>& src);
397
407
408protected:
412 void register_timekeeper(const size_t idx, timekeeper::sptr tk);
413
414private:
415 /**************************************************************************
416 * Attributes
417 *************************************************************************/
418 std::unordered_map<size_t, timekeeper::sptr> _timekeepers;
419};
420
421}} // namespace uhd::rfnoc
Definition: discoverable_feature_getter_iface.hpp:18
Definition: mb_controller.hpp:50
virtual void set_ticks_now(const uint64_t ticks)=0
Definition: mb_controller.hpp:57
uhd::time_spec_t get_time_last_pps(void)
void set_time_next_pps(const uhd::time_spec_t &time)
uhd::time_spec_t get_time_now(void)
virtual void set_period(const uint64_t period_ns)=0
void set_time_now(const uhd::time_spec_t &time)
std::shared_ptr< timekeeper > sptr
Definition: mb_controller.hpp:52
virtual void set_ticks_next_pps(const uint64_t ticks)=0
double get_tick_rate()
Definition: mb_controller.hpp:111
std::function< void(uint64_t)> write_period_fn_t
Definition: mb_controller.hpp:53
virtual uint64_t get_ticks_last_pps()=0
Definition: mb_controller.hpp:27
virtual std::string get_mboard_name() const =0
virtual uhd::usrp::mboard_eeprom_t get_eeprom()=0
Return a reference to the tk_idx-th timekeeper on this motherboard.
virtual void init()
Definition: mb_controller.hpp:152
virtual uhd::sensor_value_t get_sensor(const std::string &name)=0
virtual std::vector< std::string > get_gpio_banks() const
virtual void set_time_source(const std::string &source)=0
virtual void register_sync_source_updater(sync_source_updater_t callback_f)
virtual void set_sync_source(const std::string &clock_source, const std::string &time_source)=0
virtual std::vector< std::string > get_time_sources() const =0
virtual std::string get_time_source() const =0
std::shared_ptr< mb_controller > sptr
Definition: mb_controller.hpp:29
virtual std::vector< uhd::device_addr_t > get_sync_sources()=0
virtual std::string get_clock_source() const =0
std::function< void(const sync_source_t &sync_source)> sync_source_updater_t
Definition: mb_controller.hpp:37
virtual void set_clock_source_out(const bool enb)=0
virtual void set_gpio_src(const std::string &bank, const std::vector< std::string > &src)
virtual std::vector< std::string > get_sensor_names()=0
Returns the number of timekeepers, which equals the number of timebases.
virtual bool synchronize(std::vector< mb_controller::sptr > &mb_controllers, const uhd::time_spec_t &time_spec=uhd::time_spec_t(0.0), const bool quiet=false)
virtual void set_sync_source(const uhd::device_addr_t &sync_source)=0
virtual void set_clock_source(const std::string &source)=0
virtual std::vector< std::string > get_gpio_src(const std::string &bank)
virtual std::vector< std::string > get_clock_sources() const =0
virtual void set_time_source_out(const bool enb)=0
Definition: mb_controller.hpp:39
virtual uhd::device_addr_t get_sync_source() const =0
virtual std::vector< std::string > get_gpio_srcs(const std::string &bank) const
Definition: time_spec.hpp:31
Definition: config.h:70
source
Identify the source of calibration data, i.e., where was it stored.
Definition: database.hpp:22
Definition: build_info.hpp:12
Definition: sensors.hpp:29
