uhd::rfnoc::window_block_control Class Referenceabstract
#include <uhd/rfnoc/window_block_control.hpp>
Inheritance diagram for uhd::rfnoc::window_block_control:
virtual size_t get_max_num_coefficients (const size_t chan) const =0
virtual void set_coefficients (const std::vector< int16_t > &coeffs, const size_t chan)=0
virtual std::vector< int16_t > get_coefficients (const size_t chan) const =0
register_iface & regs ()
static const uint32_t REG_WINDOW_BLOCK_SIZE
static const uint32_t REG_WINDOW_LEN_OFFSET
static const uint32_t REG_WINDOW_MAX_LEN_OFFSET
static const uint32_t REG_WINDOW_LOAD_COEFF_OFFSET
static const uint32_t REG_WINDOW_LOAD_COEFF_LAST_OFFSET
Window Block Control Class
The Window Block is a windowing block for RFNoC that is intended to be used with the FFT block. The block can be configured with coefficients, by which the samples in each input packet are multiplied before begin output. The first sample of the first packet is multiplied by the first first coefficient, the second sample is multiplied by the second coefficient, and so on.
The RFNoC window block supports a configurable number of pairs of input and output ports of sc16 data (16-bit fixed-point complex samples) and a configurable window length and coefficients for each.
◆ get_coefficients()
virtual std::vector< int16_t > uhd::rfnoc::window_block_control::get_coefficients ( const size_t  chan) const
Get the window coefficients
Return a vector with the current window coefficients for a given channel.
chanThe channel to retrieve the current window coefficients from
The vector of current window coefficients
◆ get_max_num_coefficients()
virtual size_t uhd::rfnoc::window_block_control::get_max_num_coefficients ( const size_t  chan) const
Get the maximum number of window coefficients supported by this block
Get the maximum number of window coefficients supported by this block.
chanThe channel to retrieve the maximum number of coefficients from
The maximum number of window coefficients supported by this block
◆ set_coefficients()
virtual void uhd::rfnoc::window_block_control::set_coefficients ( const std::vector< int16_t > &  coeffs,
const size_t  chan
Set the window coefficients
Set the window coefficients for a given channel. The number of coefficients must be equal to or less than the maximum number of coefficients supported by the given channel of the block.
coeffsA vector of integer coefficients for the window
chanThe channel to apply the coefficients to
◆ REG_WINDOW_BLOCK_SIZE
const uint32_t uhd::rfnoc::window_block_control::REG_WINDOW_BLOCK_SIZE
◆ REG_WINDOW_LEN_OFFSET
const uint32_t uhd::rfnoc::window_block_control::REG_WINDOW_LEN_OFFSET
◆ REG_WINDOW_LOAD_COEFF_LAST_OFFSET
const uint32_t uhd::rfnoc::window_block_control::REG_WINDOW_LOAD_COEFF_LAST_OFFSET
◆ REG_WINDOW_LOAD_COEFF_OFFSET
const uint32_t uhd::rfnoc::window_block_control::REG_WINDOW_LOAD_COEFF_OFFSET
◆ REG_WINDOW_MAX_LEN_OFFSET
const uint32_t uhd::rfnoc::window_block_control::REG_WINDOW_MAX_LEN_OFFSET
