#include <uhd/rfnoc/addsub_block_control.hpp>
using | sptr = std::shared_ptr< noc_block_base > |
using | make_args_ptr = std::unique_ptr< make_args_t > |
Opaque pointer to the constructor arguments. More... | |
enum class | forwarding_policy_t { ONE_TO_ONE , ONE_TO_FAN , ONE_TO_ALL_IN , ONE_TO_ALL_OUT , ONE_TO_ALL , DROP , USE_MAP } |
Types of property/action forwarding for those not defined by the block itself. More... | |
using | resolver_fn_t = std::function< void(void)> |
using | resolve_callback_t = std::function< void(void)> |
using | action_handler_t = std::function< void(const res_source_info &, action_info::sptr)> |
using | forwarding_map_t = std::unordered_map< res_source_info, std::vector< res_source_info > > |
~noc_block_base () override | |
std::string | get_unique_id () const override |
Unique ID for an RFNoC block is its block ID. More... | |
size_t | get_num_input_ports () const override |
Number of input ports. Note: This gets passed into this block from the. More... | |
size_t | get_num_output_ports () const override |
Number of output ports. Note: This gets passed outto this block from the. More... | |
noc_id_t | get_noc_id () const |
const block_id_t & | get_block_id () const |
double | get_tick_rate () const |
size_t | get_mtu (const res_source_info &edge) |
uhd::device_addr_t | get_block_args () const |
uhd::property_tree::sptr & | get_tree () const |
Return a reference to this block's subtree. More... | |
uhd::property_tree::sptr & | get_tree () |
Return a reference to this block's subtree (non-const version) More... | |
node_t () | |
virtual | ~node_t () |
virtual std::string | get_unique_id () const |
Return a unique identifier string for this node. In every RFNoC graph,. More... | |
virtual size_t | get_num_input_ports () const =0 |
virtual size_t | get_num_output_ports () const =0 |
std::vector< std::string > | get_property_ids () const |
template<typename prop_data_t > | |
void | set_property (const std::string &id, const prop_data_t &val, const size_t instance=0) |
void | set_properties (const uhd::device_addr_t &props, const size_t instance=0) |
const prop_data_t & | get_property (const std::string &id, const size_t instance=0) |
virtual void | set_command_time (uhd::time_spec_t time, const size_t instance) |
virtual uhd::time_spec_t | get_command_time (const size_t instance) const |
virtual void | clear_command_time (const size_t instance) |
register_iface_holder (register_iface::sptr reg) | |
virtual | ~register_iface_holder ()=default |
register_iface & | regs () |
static const size_t | ANY_PORT = size_t(~0) |
using | prop_ptrs_t = std::unordered_set< property_base_t * > |
noc_block_base (make_args_ptr make_args) | |
void | set_num_input_ports (const size_t num_ports) |
Update number of input ports. More... | |
void | set_num_output_ports (const size_t num_ports) |
Update number of output ports. More... | |
void | set_tick_rate (const double tick_rate) |
void | set_mtu_forwarding_policy (const forwarding_policy_t policy) |
void | set_mtu (const res_source_info &edge, const size_t new_mtu) |
property_base_t * | get_mtu_prop_ref (const res_source_info &edge) |
std::shared_ptr< mb_controller > | get_mb_controller () |
virtual void | deinit () |
void | register_property (property_base_t *prop, resolve_callback_t &&clean_callback=nullptr) |
void | add_property_resolver (prop_ptrs_t &&inputs, prop_ptrs_t &&outputs, resolver_fn_t &&resolver_fn) |
void | set_prop_forwarding_policy (forwarding_policy_t policy, const std::string &prop_id="") |
void | set_prop_forwarding_map (const forwarding_map_t &map) |
void | set_property (const std::string &id, const prop_data_t &val, const res_source_info &src_info) |
const prop_data_t & | get_property (const std::string &id, const res_source_info &src_info) |
void | register_action_handler (const std::string &id, action_handler_t &&handler) |
void | set_action_forwarding_policy (forwarding_policy_t policy, const std::string &action_key="") |
void | set_action_forwarding_map (const forwarding_map_t &map) |
void | post_action (const res_source_info &edge_info, action_info::sptr action) |
virtual bool | check_topology (const std::vector< size_t > &connected_inputs, const std::vector< size_t > &connected_outputs) |
virtual void | shutdown () |
void | update_reg_iface (register_iface::sptr new_iface=nullptr) |
static dirtifier_t | ALWAYS_DIRTY |
A dirtifyer object, useful for properties that always need updating. More... | |
Add/Sub Block Control Class
The Add/Sub RFNoC block takes in two streams of sc16-formatted data and performs addition and subtraction on the data in the stream, creating two output streams consisting of the sum and difference of the input streams. The block assumes that the input and output packets are all of the same length.
