#include <uhd/rfnoc/duc_block_control.hpp>
| virtual double | set_freq (const double freq, const size_t chan, const boost::optional< uhd::time_spec_t > time=boost::none)=0 |
| virtual double | get_freq (const size_t chan) const =0 |
| virtual uhd::freq_range_t | get_frequency_range (const size_t chan) const =0 |
| virtual double | get_input_rate (const size_t chan) const =0 |
| virtual double | get_output_rate (const size_t chan) const =0 |
| virtual void | set_output_rate (const double rate, const size_t chan)=0 |
| virtual uhd::meta_range_t | get_input_rates (const size_t chan) const =0 |
| virtual double | set_input_rate (const double rate, const size_t chan)=0 |
| Number of input ports. Note: This gets passed into this block from the. More... | |
| Number of output ports. Note: This gets passed outto this block from the. More... | |
| Return a unique identifier string for this node. In every RFNoC graph,. More... | |
| static const uint16_t | MAJOR_COMPAT |
| static const uint16_t | MINOR_COMPAT |
| static const uint32_t | RB_COMPAT_NUM |
| static const uint32_t | RB_NUM_HB |
| static const uint32_t | RB_CIC_MAX_INTERP |
| static const uint32_t | SR_N_ADDR |
| static const uint32_t | SR_M_ADDR |
| static const uint32_t | SR_CONFIG_ADDR |
| static const uint32_t | SR_FREQ_ADDR |
| static const uint32_t | SR_SCALE_IQ_ADDR |
| static const uint32_t | SR_INTERP_ADDR |
| static const uint32_t | SR_TIME_INCR_ADDR |
| enum class | forwarding_policy_t { ONE_TO_ONE , ONE_TO_FAN , ONE_TO_ALL_IN , ONE_TO_ALL_OUT , ONE_TO_ALL , DROP , USE_MAP } |
| Update number of input ports. More... | |
| Update number of output ports. More... | |
DUC Block Control Class
The DUC Block is a multi-channel digital upconverter (DUC) with built-in frequency shift. The number of channels as well as the maximum interpolation is configurable in the FPGA, the block controller will read out registers to identify the capabilities of this block.
freq: The frequency shift at the input. Note: A convenience method set_freq() is provided to set this property. It also takes care of the command time, which set_property() does not, and thus should be preferred.interp: The interpolation value
Return the current DDS frequency
Return the range of frequencies that chan can be set to.
Return the sampling rate at this block's input
| chan | The channel for which the rate is being queried |
Return a range of valid input rates, based on the current output rate
Note the return value is only valid as long as the output rate does not change.
Return the sampling rate at this block's output
This is equivalent to calling get_input_rate() multiplied by the interpolation
Set the DDS frequency
| freq | The frequency shift in Hz |
| chan | The channel to which this change shall be applied |
| time | When to apply the new frequency |
Attempt to set the input rate of this block
This will set the interpolation such that the output rate is untouched, and that the output rate divided by the new interpolation is as close as possible to the requested rate.
| rate | The requested rate |
Manually set the sampling rate at this block's output
| chan | The channel for which the rate is being set |
