uhd::rfnoc::mb_controller Class Referenceabstract
#include <uhd/rfnoc/mb_controller.hpp>
Inheritance diagram for uhd::rfnoc::mb_controller:
uhd::features::discoverable_feature_getter_iface
Classes
class  timekeeper
using sptr = std::shared_ptr< mb_controller >
using sync_source_t = device_addr_t
using sync_source_updater_t = std::function< void(const sync_source_t &sync_source)>
 ~mb_controller () override=default
size_t get_num_timekeepers () const
 Returns the number of timekeepers, which equals the number of timebases. More...
timekeeper::sptr get_timekeeper (const size_t tk_idx) const
 Return a reference to the tk_idx-th timekeeper on this motherboard. More...
virtual void init ()
virtual std::string get_mboard_name () const =0
virtual void set_time_source (const std::string &source)=0
virtual std::string get_time_source () const =0
virtual std::vector< std::string > get_time_sources () const =0
virtual void set_clock_source (const std::string &source)=0
virtual std::string get_clock_source () const =0
virtual std::vector< std::string > get_clock_sources () const =0
virtual void set_sync_source (const std::string &clock_source, const std::string &time_source)=0
virtual void set_sync_source (const uhd::device_addr_t &sync_source)=0
virtual uhd::device_addr_t get_sync_source () const =0
virtual std::vector< uhd::device_addr_t > get_sync_sources ()=0
virtual void set_clock_source_out (const bool enb)=0
virtual void set_time_source_out (const bool enb)=0
virtual uhd::sensor_value_t get_sensor (const std::string &name)=0
virtual std::vector< std::string > get_sensor_names ()=0
virtual uhd::usrp::mboard_eeprom_t get_eeprom ()=0
virtual bool synchronize (std::vector< mb_controller::sptr > &mb_controllers, const uhd::time_spec_t &time_spec=uhd::time_spec_t(0.0), const bool quiet=false)
virtual std::vector< std::string > get_gpio_banks () const
virtual std::vector< std::string > get_gpio_srcs (const std::string &bank) const
virtual std::vector< std::string > get_gpio_src (const std::string &bank)
virtual void set_gpio_src (const std::string &bank, const std::vector< std::string > &src)
virtual void register_sync_source_updater (sync_source_updater_t callback_f)
- Public Member Functions inherited from uhd::features::discoverable_feature_getter_iface
virtual ~discoverable_feature_getter_iface ()=default
template<typename T >
T & get_feature ()
 Retrieves a feature of the specified type. More...
bool has_feature ()
 Determines whether a given feature exists. More...
virtual std::vector< std::string > enumerate_features ()=0
 Enumerate all discoverable features present on the device. More...
void register_timekeeper (const size_t idx, timekeeper::sptr tk)
A default block controller for blocks that can't be found in the registry
◆ sync_source_t
◆ sync_source_updater_t
using uhd::rfnoc::mb_controller::sync_source_updater_t = std::function<void(const sync_source_t& sync_source)>
Callback function for changing sync sources
When a sync source is changed, the sync source callback function is called to notify any registrants of the update
◆ ~mb_controller()
uhd::rfnoc::mb_controller::~mb_controller ( )
overridedefault
◆ get_clock_source()
virtual std::string uhd::rfnoc::mb_controller::get_clock_source ( ) const
Get the currently set clock source
the string representing the clock source
◆ get_clock_sources()
virtual std::vector<std::string> uhd::rfnoc::mb_controller::get_clock_sources ( ) const
Get a list of possible clock sources
a vector of strings for possible settings
◆ get_eeprom()
virtual uhd::usrp::mboard_eeprom_t uhd::rfnoc::mb_controller::get_eeprom ( )
Return the motherboard EEPROM data
◆ get_gpio_banks()
virtual std::vector<std::string> uhd::rfnoc::mb_controller::get_gpio_banks ( ) const
virtual
Return the list of GPIO banks that are controlled by this MB controller
Note that this list may be empty. Only if the MB controller has any control over GPIOs, do the get listed here.
◆ get_gpio_src()
virtual std::vector<std::string> uhd::rfnoc::mb_controller::get_gpio_src ( const std::string &  bank)
virtual
Return the current sources for a given GPIO bank
◆ get_gpio_srcs()
virtual std::vector<std::string> uhd::rfnoc::mb_controller::get_gpio_srcs ( const std::string &  bank) const
virtual
Return a list of possible sources to drive GPIOs
Sources can be "PS", for when an embedded device can drive the pins from software, "Radio#0", if a radio block can drive them, and so on.
◆ get_mboard_name()
virtual std::string uhd::rfnoc::mb_controller::get_mboard_name ( ) const
Get canonical name for this USRP motherboard
a string representing the name
◆ get_num_timekeepers()
size_t uhd::rfnoc::mb_controller::get_num_timekeepers ( ) const
◆ get_sensor()
virtual uhd::sensor_value_t uhd::rfnoc::mb_controller::get_sensor ( const std::string &  name)
Get a motherboard sensor value
namethe name of the sensor
a sensor value object
◆ get_sensor_names()
virtual std::vector<std::string> uhd::rfnoc::mb_controller::get_sensor_names ( )
Get a list of possible motherboard sensor names
a vector of sensor names
◆ get_sync_source()
virtual uhd::device_addr_t uhd::rfnoc::mb_controller::get_sync_source ( ) const
Get the currently set sync source
the dictionary representing the sync source settings
◆ get_sync_sources()
virtual std::vector<uhd::device_addr_t> uhd::rfnoc::mb_controller::get_sync_sources ( )
Get a list of available sync sources
◆ get_time_source()
virtual std::string uhd::rfnoc::mb_controller::get_time_source ( ) const
Get the currently set time source
the string representing the time source
◆ get_time_sources()
virtual std::vector<std::string> uhd::rfnoc::mb_controller::get_time_sources ( ) const
Get a list of possible time sources.
◆ get_timekeeper()
timekeeper::sptr uhd::rfnoc::mb_controller::get_timekeeper ( const size_t  tk_idx) const
◆ init()
virtual void uhd::rfnoc::mb_controller::init ( )
Run initializations of this motherboard that have to occur post-block init
◆ register_sync_source_updater()
virtual void uhd::rfnoc::mb_controller::register_sync_source_updater ( sync_source_updater_t  callback_f)
virtual
Register a callback function to update sync sources
This callback alerts those registered that a change has occurred to a sync source, whether that be the clock_source, time_source, or both via sync_source.
callback_fThe function to call when a sync source is updated
◆ register_timekeeper()
void uhd::rfnoc::mb_controller::register_timekeeper ( const size_t  idx,
timekeeper::sptr  tk
Stash away a timekeeper. This needs to be called by the implementer of mb_controller.
◆ set_clock_source()
virtual void uhd::rfnoc::mb_controller::set_clock_source ( const std::string &  source)
Set the clock source for the USRP device
This sets the source of the frequency reference, typically a 10 MHz signal. In order to frequency-align multiple USRPs, it is necessary to connect all of them to a common reference and provide them with the same clock source. Typical values for source are 'internal', 'external'. Refer to the specific device manual for a full list of options.
If the value for for source is not available for this device, it will throw an exception. Calling get_clock_sources() will return a valid list of options for this method.
Side effects: Some devices only support certain combinations of time and clock source. It is possible that the underlying device implementation will change the time source when the clock source changes and vice versa. Reading back the current values of clock and time source using get_clock_source() and get_time_source() is the only certain way of knowing which clock and time source are currently selected.
This function does not force a re-initialization of the underlying hardware when the value does not change. Consider the following snippet:
auto usrp = uhd::usrp::multi_usrp::make(device_args);
// This may or may not cause the hardware to reconfigure, depending on
// the default state of the device
usrp->set_clock_source("internal");
// Now, the clock source is definitely set to "internal"!
// The next call probably won't do anything but will return immediately,
// because the clock source was already set to "internal"
// The clock source is still guaranteed to be "internal" at this point
See also:
sourcea string representing the time source
Exceptions
uhd::value_errorif source is an invalid option
◆ set_clock_source_out()
virtual void uhd::rfnoc::mb_controller::set_clock_source_out ( const bool  enb)
Send the clock source to an output connector
This call is only applicable on devices with reference outputs. By default, the reference output will be enabled for ease of use. This call may be used to enable or disable the output.
enbtrue to output the clock source.
◆ set_gpio_src()
virtual void uhd::rfnoc::mb_controller::set_gpio_src ( const std::string &  bank,
const std::vector< std::string > &  src
virtual
Set the source for GPIO pins on a given bank.
Exceptions
uhd::key_errorif the bank does not exist
uhd::value_errorif the source does not exist
uhd::not_implemented_errorif the current motherboard does not support this feature
◆ set_sync_source() [1/2]
virtual void uhd::rfnoc::mb_controller::set_sync_source ( const std::string &  clock_source,
const std::string &  time_source
Set the reference/synchronization sources for the USRP device
This is a shorthand for calling set_sync_source(device_addr_t("clock_source=$CLOCK_SOURCE,time_source=$TIME_SOURCE"))
clock_sourceA string representing the clock source
time_sourceA string representing the time source
Exceptions
uhd::value_errorif the sources don't actually exist
◆ set_sync_source() [2/2]
virtual void uhd::rfnoc::mb_controller::set_sync_source ( const uhd::device_addr_t &  sync_source)
Typically, this will set both clock and time source in a single call. For some USRPs, this may be significantly faster than calling set_time_source() and set_clock_source() individually.
Example:
usrp->set_sync_source(
device_addr_t("clock_source=external,time_source=external"));
This function does not force a re-initialization of the underlying hardware when the value does not change. See also set_time_source() and set_clock_source() for more details.
sync_sourceA dictionary representing the various source settings.
Exceptions
uhd::value_errorif the sources don't actually exist or if the combination of clock and time source is invalid.
◆ set_time_source()
virtual void uhd::rfnoc::mb_controller::set_time_source ( const std::string &  source)
Set the time source for the USRP device
This sets the method of time synchronization, typically a pulse per second signal. In order to time-align multiple USRPs, it is necessary to connect all of them to a common reference and provide them with the same time source. Typical values for source are 'internal', 'external'. Refer to the specific device manual for a full list of options.
If the value for for source is not available for this device, it will throw an exception. Calling get_time_sources() will return a valid list of options for this method.
Side effects: Some devices only support certain combinations of time and clock source. It is possible that the underlying device implementation will change the clock source when the time source changes and vice versa. Reading back the current values of clock and time source using get_clock_source() and get_time_source() is the only certain way of knowing which clock and time source are currently selected.
usrp->set_time_source("internal");
// Now, the time source is definitely set to "internal"!
// because the time source was already set to "internal"
// The time source is still guaranteed to be "internal" at this point
See also:
Exceptions
◆ set_time_source_out()
virtual void uhd::rfnoc::mb_controller::set_time_source_out ( const bool  enb)
Send the time source to an output connector
This call is only applicable on devices with PPS outputs. By default, the PPS output will be enabled for ease of use. This call may be used to enable or disable the output.
enbtrue to output the time source.
◆ synchronize()
virtual bool uhd::rfnoc::mb_controller::synchronize ( std::vector< mb_controller::sptr > &  mb_controllers,
const uhd::time_spec_t &  time_spec = uhd::time_spec_t(0.0),
const bool  quiet = false
virtual
Synchronize a list of motherboards in time and frequency
Note: When a uhd::rfnoc_graph is instantiated, this method is called on all motherboards.
The exact steps taken when calling this method are hardware-specific, but in all cases, they will ensure that:
  • Timekeepers are synchronized. That means that timekeepers with the same clock rate increment are in unison, and at all times have the same time. This allows sending timed commands to the motherboards and expect them to be executed at the same time.
  • Any hardware settings that need to be applied to synchronize will be configured. For example, the X3x0 DAC (AD9146) requires synchronization triggers for all the DACs to run synchronously, and the X4x0 RFSoC requires programming an identical tile latency.
mb_controllersA list of motherboard controllers to synchronize. Any motherboard controllers that could not be synchronized because they're incompatible with this motherboard controller are removed from the list. On return, the list should be (ideally) identical to its value at call time.
time_specTime specification to synchronize mb_controllers to
quietIf true, don't print any errors or warnings if synchronization fails. During initialization of uhd::rfnoc_graph, UHD will call synchronize() on all motherboards with quiet set to true.
true if all motherboards that were listed in mb_controllers could be synchronized.
