16 #include <unordered_map>    17 #include <unordered_set>    18 #include <boost/graph/adjacency_list.hpp>    26 namespace uhd {
namespace rfnoc {
    41         std::function<void(const res_source_info&, action_info::sptr)>;
    43         std::unordered_map<res_source_info, std::vector<res_source_info>>;
    64     static const size_t ANY_PORT = size_t(~0);
    80     virtual std::string get_unique_id()
const;
    88     virtual size_t get_num_input_ports()
const = 0;
    96     virtual size_t get_num_output_ports()
const = 0;
   110     std::vector<std::string> get_property_ids()
const;
   127     template <
typename prop_data_t>
   129         const std::string&
id,
const prop_data_t& val,
const size_t instance = 0);
   182     template <
   183     const prop_data_t& get_property(
   184         const std::string&
id,
const size_t instance = 0) ;
   201     virtual void set_command_time(
uhd::time_spec_t time,
const size_t instance);
   214     virtual void clear_command_time(
   242     void register_property(
   279     void add_property_resolver(
   305     void set_prop_forwarding_policy(
   342     template <
   344         const std::string&
id,
const res_source_info& src_info);
   357     template <
   358     const prop_data_t& get_property(
   377     void register_action_handler(
const std::string&
id,
action_handler_t&& handler);
   397     void set_action_forwarding_policy(
   460     virtual bool check_topology(
const std::vector<size_t>& connected_inputs,
   461         const std::vector<size_t>& connected_outputs);
   468     virtual void shutdown();
   477     friend class node_accessor_t;
   498     template <
typename PredicateType>
   499     prop_ptrs_t filter_props(PredicateType&& predicate)
   502         for (
const auto& type_prop_pair : _props) {
   503             for (
const auto& prop : type_prop_pair.second) {
   504                 if (predicate(prop)) {
   505                     filtered_props.push_back(prop);
   510         return filtered_props;
   561     void resolve_props();
   579         _resolve_all_cb = resolver;
   584     void clear_resolve_all_callback()
   586         _resolve_all_cb = _default_resolve_all_cb;
   594         _graph_mutex_cb = mutex;
   600     void clear_graph_mutex_callback()
   602         _graph_mutex_cb = NULL;
   639     void forward_edge_property(
   650         _post_action_cb = std::move(post_handler);
   670     template <
   672         const std::string&
id,
   678     mutable std::mutex _prop_mutex;
   682         std::vector<property_base_t*>,
   687     std::unordered_map<property_base_t*, resolve_callback_t> _clean_cb_registry;
   689     using property_resolver_t = std::tuple<prop_ptrs_t, prop_ptrs_t, resolver_fn_t>;
   691     std::vector<property_resolver_t> _prop_resolvers;
   716     std::unordered_set<std::unique_ptr<property_base_t>> _dynamic_props;
   721     std::unordered_map<std::string, forwarding_policy_t> _prop_fwd_policies{
   722         {
"", forwarding_policy_t::ONE_TO_ONE}};
   730     mutable std::mutex _action_mutex;
   733     std::unordered_map<std::string, action_handler_t> _action_handlers;
   736     std::unordered_map<std::string, forwarding_policy_t> _action_fwd_policies{
   737         {
   751     std::vector<uhd::time_spec_t> _cmd_timespecs;
 std::function< void(const res_source_info &, action_info::sptr)> action_handler_t
Definition: node.hpp:41
std::vector< property_base_t * > prop_ptrs_t
Definition: node.hpp:220
static dirtifier_t ALWAYS_DIRTY
A dirtifyer object, useful for properties that always need updating.
Definition: node.hpp:474
Definition: time_spec.hpp:28
Definition: dirtifier.hpp:18
Definition: build_info.hpp:12
access_t
Definition: property.hpp:28
std::function< void(void)> resolve_callback_t
Definition: node.hpp:38
std::unordered_map< res_source_info, std::vector< res_source_info > > forwarding_map_t
Definition: node.hpp:43
std::shared_ptr< action_info > sptr
Definition: actions.hpp:32
forwarding_policy_t
Types of property/action forwarding for those not defined by the block itself.
Definition: node.hpp:46
source_t
Definition: res_source_info.hpp:21
std::function< std::recursive_mutex &(void)> graph_mutex_callback_t
Definition: node.hpp:39
Definition: res_source_info.hpp:17
std::unique_ptr< scope_exit > uptr
Definition: scope_exit.hpp:25
Definition: config.h:87
Definition: property.hpp:25
std::function< void(void)> resolver_fn_t
Definition: node.hpp:37
Definition: device_addr.hpp:37
virtual ~node_t()
Definition: node.hpp:71
