| virtual  | ~extension ()=default |
| virtual std::string  | get_name ()=0 |
| virtual  | ~core_iface ()=default |
| virtual std::string  | get_tx_antenna (const size_t chan) const =0 |
| virtual std::vector< std::string >  | get_tx_antennas (const size_t chan) const =0 |
| virtual void  | set_tx_antenna (const std::string &ant, const size_t chan)=0 |
| virtual std::string  | get_rx_antenna (const size_t chan) const =0 |
| virtual std::vector< std::string >  | get_rx_antennas (const size_t chan) const =0 |
| virtual void  | set_rx_antenna (const std::string &ant, const size_t chan)=0 |
| virtual double  | get_tx_frequency (const size_t chan)=0 |
| virtual double  | set_tx_frequency (const double freq, size_t chan)=0 |
| virtual void  | set_tx_tune_args (const uhd::device_addr_t &args, const size_t chan)=0 |
| virtual uhd::freq_range_t  | get_tx_frequency_range (const size_t chan) const =0 |
| virtual double  | get_rx_frequency (const size_t chan)=0 |
| virtual double  | set_rx_frequency (const double freq, const size_t chan)=0 |
| virtual void  | set_rx_tune_args (const uhd::device_addr_t &args, const size_t chan)=0 |
| virtual uhd::freq_range_t  | get_rx_frequency_range (const size_t chan) const =0 |
| virtual std::vector< std::string >  | get_tx_gain_names (const size_t chan) const =0 |
| virtual uhd::gain_range_t  | get_tx_gain_range (const size_t chan) const =0 |
| virtual uhd::gain_range_t  | get_tx_gain_range (const std::string &name, const size_t chan) const =0 |
| virtual double  | get_tx_gain (const size_t chan)=0 |
| virtual double  | get_tx_gain (const std::string &name, const size_t chan)=0 |
| virtual double  | set_tx_gain (const double gain, const size_t chan)=0 |
| virtual double  | set_tx_gain (const double gain, const std::string &name, const size_t chan)=0 |
| virtual std::vector< std::string >  | get_rx_gain_names (const size_t chan) const =0 |
| virtual uhd::gain_range_t  | get_rx_gain_range (const size_t chan) const =0 |
| virtual uhd::gain_range_t  | get_rx_gain_range (const std::string &name, const size_t chan) const =0 |
| virtual double  | get_rx_gain (const size_t chan)=0 |
| virtual double  | get_rx_gain (const std::string &name, const size_t chan)=0 |
| virtual double  | set_rx_gain (const double gain, const size_t chan)=0 |
| virtual double  | set_rx_gain (const double gain, const std::string &name, const size_t chan)=0 |
| virtual void  | set_rx_agc (const bool enable, const size_t chan)=0 |
| virtual meta_range_t  | get_tx_bandwidth_range (size_t chan) const =0 |
| virtual double  | get_tx_bandwidth (const size_t chan)=0 |
| virtual double  | set_tx_bandwidth (const double bandwidth, const size_t chan)=0 |
| virtual meta_range_t  | get_rx_bandwidth_range (size_t chan) const =0 |
| virtual double  | get_rx_bandwidth (const size_t chan)=0 |
| virtual double  | set_rx_bandwidth (const double bandwidth, const size_t chan)=0 |
| virtual std::vector< std::string >  | get_rx_lo_names (const size_t chan) const =0 |
| virtual std::vector< std::string >  | get_rx_lo_sources (const std::string &name, const size_t chan) const =0 |
| virtual freq_range_t  | get_rx_lo_freq_range (const std::string &name, const size_t chan) const =0 |
| virtual void  | set_rx_lo_source (const std::string &src, const std::string &name, const size_t chan)=0 |
| virtual std::string  | get_rx_lo_source (const std::string &name, const size_t chan)=0 |
| virtual void  | set_rx_lo_export_enabled (bool enabled, const std::string &name, const size_t chan)=0 |
| virtual bool  | get_rx_lo_export_enabled (const std::string &name, const size_t chan)=0 |
| virtual double  | set_rx_lo_freq (double freq, const std::string &name, const size_t chan)=0 |
| virtual double  | get_rx_lo_freq (const std::string &name, const size_t chan)=0 |
| virtual std::vector< std::string >  | get_tx_lo_names (const size_t chan) const =0 |
| virtual std::vector< std::string >  | get_tx_lo_sources (const std::string &name, const size_t chan) const =0 |
| virtual freq_range_t  | get_tx_lo_freq_range (const std::string &name, const size_t chan)=0 |
| virtual void  | set_tx_lo_source (const std::string &src, const std::string &name, const size_t chan)=0 |
| virtual std::string  | get_tx_lo_source (const std::string &name, const size_t chan)=0 |
| virtual void  | set_tx_lo_export_enabled (const bool enabled, const std::string &name, const size_t chan)=0 |
| virtual bool  | get_tx_lo_export_enabled (const std::string &name, const size_t chan)=0 |
| virtual double  | set_tx_lo_freq (const double freq, const std::string &name, const size_t chan)=0 |
| virtual double  | get_tx_lo_freq (const std::string &name, const size_t chan)=0 |
| virtual  | ~power_reference_iface ()=default |
| virtual bool  | has_rx_power_reference (const size_t chan=0)=0 |
| virtual void  | set_rx_power_reference (const double power_dbm, const size_t chan=0)=0 |
| virtual double  | get_rx_power_reference (const size_t chan=0)=0 |
| virtual std::vector< std::string >  | get_rx_power_ref_keys (const size_t chan=0)=0 |
| virtual meta_range_t  | get_rx_power_range (const size_t chan)=0 |
| virtual bool  | has_tx_power_reference (const size_t chan=0)=0 |
| virtual void  | set_tx_power_reference (const double power_dbm, const size_t chan=0)=0 |
| virtual double  | get_tx_power_reference (const size_t chan=0)=0 |
| virtual std::vector< std::string >  | get_tx_power_ref_keys (const size_t chan=0)=0 |
| virtual meta_range_t  | get_tx_power_range (const size_t chan)=0 |
Common base class for RF extensions
