#include <uhd/rfnoc/fft_block_control.hpp>
| virtual void | set_direction (const fft_direction direction)=0 |
| virtual fft_direction | get_direction () const =0 |
| virtual void | set_magnitude (const fft_magnitude magnitude)=0 |
| virtual fft_magnitude | get_magnitude () const =0 |
| virtual void | set_shift_config (const fft_shift shift)=0 |
| virtual fft_shift | get_shift_config () const =0 |
| virtual void | set_scaling (const uint16_t scaling)=0 |
| virtual uint16_t | get_scaling () const =0 |
| virtual void | set_length (const size_t length)=0 |
| virtual size_t | get_length () const =0 |
| static const uint32_t | REG_RESET_ADDR |
| static const uint32_t | REG_LENGTH_LOG2_ADDR |
| static const uint32_t | REG_MAGNITUDE_OUT_ADDR |
| static const uint32_t | REG_DIRECTION_ADDR |
| static const uint32_t | REG_SCALING_ADDR |
| static const uint32_t | REG_SHIFT_CONFIG_ADDR |
FFT Block Control Class
The FFT block is an RFNoC block that accepts signed complex 16-bit data at its input and computes the forward or reverse FFT of the input data, outputting signed complex 16-bit data at its output. The output data may be configured as complex, magnitude, or mag-squared values, its spectrum shifted and/or reversed, and scaled by a scaled factor.
The FFT length is configured via the length parameter, up to a maximum of 2048 samples. The FFT IP requires a power-of-two number of samples; the length will be coerced to the closest power of two which is smaller than length. The block will output packets of the same length in the desired format as configured via the API.
Get the FFT direction
Returns the current direction of the FFT.
Get the length of the FFT
Returns the current length of the FFT.
Get the format of the returned FFT output data
Returns the current output format of the FFT data.
Get the scaling schedule for the FFT block
Returns the current scaling schedule for the FFT block.
Get the shift configuration of the output FFT data
Returns the current shift configuration of the output FFT data.
Set the FFT direction
Sets the direction of the FFT, either forward (FORWARD) or inverse (REVERSE).
| direction | FFT direction |
Set the length of the FFT
Sets the length of the FFT in number of samples. Note that the FFT IP requires a power-of-two number of samples; the incoming value will be coerced to the closest smaller power of two.
| length | Desired FFT length |
Set the format of the returned FFT output data
Sets the format in which the FFT output data is returned. The following formats are supported:
* amplitude/phase data (COMPLEX) * magnitude data (MAGNITUDE) * mag-squared data (MAGNITUDE_SQUARED)
| magnitude | Format of the returned FFT output data |
Set the scaling schedule for the FFT block
Sets the scaling for each stage of the FFT. This value maps directly to the scale schedule field in the configuration channel data that is passed to the Xilinx AXI FFT IP. For more information on the format of this data, see Xilinx document PG109, Fast Fourier Transform LogiCORE IP Product Guide.
| scaling | Scaling schedule for the FFT block |
Set the shift configuration of the output FFT data
Sets how the FFT output data is shifted (to get the zero frequency bin to the center of the output data). The following output data shift configurations are supported:
* Negative frequencies first, then positive frequencies (NORMAL) * Positive frequencies first, then negative frequencies (REVERSE) * Bypass the shift altogether, leaving the zero frequency bin returned first (NATURAL).
| shift | Configuration for shifting FFT output data |
