11 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API    12 #define UHD_USRP_MULTI_USRP_GET_RATES_API    13 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API    14 #define UHD_USRP_MULTI_USRP_FRONTEND_IQ_AUTO_API    15 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API    16 #define UHD_USRP_MULTI_USRP_BW_RANGE_API    17 #define UHD_USRP_MULTI_USRP_USER_REGS_API    18 #define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API    19 #define UHD_USRP_MULTI_USRP_NORMALIZED_GAIN    20 #define UHD_USRP_MULTI_USRP_GPIO_API    21 #define UHD_USRP_MULTI_USRP_REGISTER_API    22 #define UHD_USRP_MULTI_USRP_FILTER_API    23 #define UHD_USRP_MULTI_USRP_LO_CONFIG_API    24 #define UHD_USRP_MULTI_USRP_TX_LO_CONFIG_API    25 #define UHD_USRP_MULTI_USRP_POWER_LEVEL    47 namespace uhd {
namespace usrp {
    98     typedef std::shared_ptr<multi_usrp>
sptr;
   193     virtual void set_master_clock_rate(
double rate,
size_t mboard = ALL_MBOARDS) = 0;
   200     virtual double get_master_clock_rate(
size_t mboard = 0) = 0;
   220     virtual meta_range_t get_master_clock_rate_range(
const size_t mboard = 0) = 0;
   226     virtual std::string get_pp_string(
void) = 0;
   233     virtual std::string get_mboard_name(
   245     virtual time_spec_t get_time_now(
   257     virtual time_spec_t get_time_last_pps(
   268     virtual void set_time_now(
   269         const time_spec_t& time_spec,
   299     virtual void set_time_next_pps(
   300         const time_spec_t& time_spec,
   322     virtual void set_time_unknown_pps(
const time_spec_t& time_spec) = 0;
   330     virtual bool get_time_synchronized(
void) = 0;
   342     virtual void set_command_time(
   350     virtual void clear_command_time(
   364     virtual void issue_stream_cmd(
   365         const stream_cmd_t& stream_cmd,
size_t chan = ALL_CHANS) = 0;
   409     virtual void set_time_source(
   410         const std::string&
source,
const size_t mboard = ALL_MBOARDS) = 0;
   417     virtual std::string get_time_source(
const size_t mboard) = 0;
   424     virtual std::vector<std::string> get_time_sources(
   476     virtual void set_clock_source(
   477         const std::string&
source,
   484     virtual std::string get_clock_source(
   491     virtual std::vector<std::string> get_clock_sources(
   503     virtual void set_sync_source(
const std::string& clock_source,
   504         const std::string& time_source,
   505         const size_t mboard = ALL_MBOARDS) = 0;
   537     virtual void set_sync_source(
   538         const device_addr_t& sync_source,
   545     virtual device_addr_t get_sync_source(
   552     virtual std::vector<device_addr_t> get_sync_sources(
   568     virtual void set_clock_source_out(
   569         const bool enb,
   585     virtual void set_time_source_out(
   586         const bool enb,
   591     virtual size_t get_num_mboards(
void) = 0;
   600         const std::string& name,
   607     virtual std::vector<std::string> get_mboard_sensor_names(
   618     virtual void set_user_register(
   619         const uint8_t addr,
const uint32_t data,
   685     template <
typename T>
   688         return std::dynamic_pointer_cast<T>(get_extension(trx, chan));
   704     virtual void set_rx_subdev_spec(
   719     virtual size_t get_rx_num_channels(
void) = 0;
   726     virtual std::string get_rx_subdev_name(
size_t chan = 0) = 0;
   737     virtual void set_rx_rate(
double rate,
   748     virtual void set_rx_spp(
const size_t spp,
const size_t chan = ALL_CHANS) = 0;
   755     virtual double get_rx_rate(
   782     virtual double get_rx_freq(
   793     virtual freq_range_t get_rx_freq_range(
   800     virtual freq_range_t get_fe_rx_freq_range(
   818     virtual std::vector<std::string> get_rx_lo_names(
   838     virtual void set_rx_lo_source(
   839         const std::string& src,
const std::string& name = ALL_LOS,
   849     virtual const std::string get_rx_lo_source(
   850         const std::string& name = ALL_LOS,
   864     virtual std::vector<std::string> get_rx_lo_sources(
   865         const std::string& name = ALL_LOS,
   877     virtual void set_rx_lo_export_enabled(
   878         bool enabled,
   885     virtual bool get_rx_lo_export_enabled(
   886         const std::string& name = ALL_LOS,
   912     virtual double set_rx_lo_freq(
   913         double freq,
   925     virtual double get_rx_lo_freq(
   937         const std::string& name,
   951     virtual std::vector<std::string> get_tx_lo_names(
   968     virtual void set_tx_lo_source(
   969         const std::string& name = ALL_LOS,
   970         const size_t chan       = 0) = 0;
   980     virtual const std::string get_tx_lo_source(
   981         const std::string& name = ALL_LOS,
   993     virtual std::vector<std::string> get_tx_lo_sources(
   994         const std::string& name = ALL_LOS,
  1006     virtual void set_tx_lo_export_enabled(
  1007         const bool enabled,
  1014     virtual bool get_tx_lo_export_enabled(
  1015         const std::string& name = ALL_LOS,
  1041     virtual double set_tx_lo_freq(
  1042         const double freq,
  1054     virtual double get_tx_lo_freq(
  1066         const std::string& name,
  1084     virtual void set_rx_gain(
double gain,
  1098     virtual std::vector<std::string> get_rx_gain_profile_names(
  1108     virtual void set_rx_gain_profile(
  1109         const std::string& profile,
  1116     virtual std::string get_rx_gain_profile(
  1121         return this->set_rx_gain(gain, ALL_GAINS, chan);
  1141     virtual void set_normalized_rx_gain(
double gain,
  1160     virtual void set_rx_agc(
bool enable,
  1169     virtual double get_rx_gain(
  1174         return this->get_rx_gain(ALL_GAINS, chan);
  1187     virtual double get_normalized_rx_gain(
  1196     virtual gain_range_t get_rx_gain_range(
  1201         return this->get_rx_gain_range(ALL_GAINS, chan);
  1210     virtual std::vector<std::string> get_rx_gain_names(
  1220     virtual void set_rx_antenna(
const std::string& ant,
  1227     virtual std::string get_rx_antenna(
  1234     virtual std::vector<std::string> get_rx_antennas(
  1245     virtual void set_rx_bandwidth(
double bandwidth,
  1252     virtual double get_rx_bandwidth(
  1259     virtual meta_range_t get_rx_bandwidth_range(
  1276     virtual sensor_value_t get_rx_sensor(
  1283     virtual std::vector<std::string> get_rx_sensor_names(
  1297     virtual void set_rx_dc_offset(
const bool enb,
  1306     virtual void set_rx_dc_offset(
  1307         const std::complex<double>& offset,
  1313     virtual meta_range_t get_rx_dc_offset_range(
  1321     virtual void set_rx_iq_balance(
const bool enb,
size_t chan) = 0;
  1330     virtual void set_rx_iq_balance(
  1331         const std::complex<double>& correction,
  1353     virtual bool has_rx_power_reference(
  1369     virtual void set_rx_power_reference(
  1370         const double power_dbm,
  1384     virtual double get_rx_power_reference(
  1395     virtual meta_range_t get_rx_power_range(
const size_t chan) = 0;
  1409     virtual void set_tx_subdev_spec(
  1424     virtual size_t get_tx_num_channels(
void) = 0;
  1431     virtual std::string get_tx_subdev_name(
  1442     virtual void set_tx_rate(
double rate,
  1449     virtual double get_tx_rate(
  1456     virtual meta_range_t get_tx_rates(
  1476     virtual double get_tx_freq(
  1487     virtual freq_range_t get_tx_freq_range(
  1494     virtual freq_range_t get_fe_tx_freq_range(
  1509     virtual void set_tx_gain(
double gain,
  1523     virtual std::vector<std::string> get_tx_gain_profile_names(
  1533     virtual void set_tx_gain_profile(
  1534         const std::string& profile,
  1541     virtual std::string get_tx_gain_profile(
  1546         return this->set_tx_gain(gain, ALL_GAINS, chan);
  1561     virtual void set_normalized_tx_gain(
double gain,
  1570     virtual double get_tx_gain(
  1575         return this->get_tx_gain(ALL_GAINS, chan);
  1588     virtual double get_normalized_tx_gain(
  1597     virtual gain_range_t get_tx_gain_range(
  1602         return this->get_tx_gain_range(ALL_GAINS, chan);
  1611     virtual std::vector<std::string> get_tx_gain_names(
  1632     virtual bool has_tx_power_reference(
  1648     virtual void set_tx_power_reference(
  1649         const double power_dbm,
  1663     virtual double get_tx_power_reference(
  1674     virtual meta_range_t get_tx_power_range(
  1684     virtual void set_tx_antenna(
  1691     virtual std::string get_tx_antenna(
  1698     virtual std::vector<std::string> get_tx_antennas(
  1709     virtual void set_tx_bandwidth(
double bandwidth,
  1716     virtual double get_tx_bandwidth(
  1723     virtual meta_range_t get_tx_bandwidth_range(
  1740     virtual sensor_value_t get_tx_sensor(
  1747     virtual std::vector<std::string> get_tx_sensor_names(
  1755     virtual void set_tx_dc_offset(
  1756         const std::complex<double>& offset,
  1762     virtual meta_range_t get_tx_dc_offset_range(
  1771     virtual void set_tx_iq_balance(
  1772         const std::complex<double>& correction,
  1783     virtual std::vector<std::string> get_gpio_banks(
  1837     virtual void set_gpio_attr(
const std::string& bank,
  1838         const std::string& attr,
  1839         const uint32_t value,
  1840         const uint32_t
mask = 0xffffffff,
  1841         const size_t mboard = 0) = 0;
  1862     virtual uint32_t get_gpio_attr(
  1863         const std::string& bank,
  1881     virtual std::vector<std::string> get_gpio_src_banks(
  1893     virtual std::vector<std::string> get_gpio_srcs(
  1894         const std::string& bank,
  1905     virtual std::vector<std::string> get_gpio_src(
  1906         const std::string& bank,
  1922     virtual void set_gpio_src(
  1923         const std::vector<std::string>& src,
  1924         const size_t mboard = 0) = 0;
  1938     virtual std::vector<std::string> get_rx_filter_names(
  1947         const std::string& name,
  1956     virtual void set_rx_filter(
  1958         const size_t chan) = 0;
  1969     virtual std::vector<std::string> get_tx_filter_names(
  1978         const std::string& name,
  1987     virtual void set_tx_filter(
  1989         const size_t chan) = 0;
Definition: stream.hpp:169
Definition: multi_usrp.hpp:1199
T::sptr get_extension(const direction_t trx, const size_t chan)
Definition: multi_usrp.hpp:686
Definition: stream_cmd.hpp:39
Definition: tune_result.hpp:18
Definition: multi_usrp.hpp:1573
Definition: multi_usrp.hpp:1544
Definition: mb_controller.hpp:25
Definition: time_spec.hpp:28
static const size_t ALL_MBOARDS
A wildcard motherboard index.
Definition: multi_usrp.hpp:103
std::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:98
std::shared_ptr< device > sptr
Definition: device.hpp:29
Definition: multi_usrp.hpp:1172
Definition: tune_request.hpp:24
static const std::string ALL_GAINS
A wildcard gain element name.
Definition: multi_usrp.hpp:109
Definition: build_info.hpp:12
Definition: sensors.hpp:28
Definition: multi_usrp.hpp:95
source
Identify the source of calibration data, i.e., where was it stored.
Definition: database.hpp:23
std::shared_ptr< dboard_iface > sptr
Definition: dboard_iface.hpp:56
direction_t
Definition: direction.hpp:12
Definition: stream.hpp:47
std::shared_ptr< filter_info_base > sptr
Definition: filters.hpp:26
Definition: config.h:87
Definition: soft_register.hpp:86
Definition: multi_usrp.hpp:1119
static const std::string ALL_LOS
A wildcard LO stage name.
Definition: multi_usrp.hpp:112
Definition: radio_control.hpp:101
Definition: subdev_spec.hpp:59
std::shared_ptr< tx_streamer > sptr
Definition: stream.hpp:267
std::shared_ptr< wb_iface > sptr
Definition: wb_iface.hpp:20
Definition: property_tree.hpp:223
static const size_t ALL_CHANS
A wildcard channel index.
Definition: multi_usrp.hpp:106
Definition: multi_usrp.hpp:1600
std::shared_ptr< extension > sptr
Definition: extension.hpp:38
Definition: device_addr.hpp:37
