◆ strs_payload() [1/3]
uhd::rfnoc::chdr::strs_payload::strs_payload |
default |
◆ strs_payload() [2/3]
const strs_payload & |
rhs | ) |
default |
◆ strs_payload() [3/3]
strs_payload && |
rhs | ) |
default |
◆ deserialize() [1/2]
void uhd::rfnoc::chdr::strs_payload::deserialize |
const uint64_t * |
buff, |
size_t |
buff_size |
inline |
Deserialize the payload from a uint64_t buffer (no conversion function)
- Parameters
buff | Buffer to deserialize the payload from |
buff_size | Number of elements in the buffer |
◆ deserialize() [2/2]
const uint64_t * |
buff, |
size_t |
buff_size, |
const std::function< uint64_t(uint64_t)> & |
conv_byte_order |
- Parameters
conv_byte_order | Byte order converter function (buffer to host endianness) |
◆ get_length()
size_t uhd::rfnoc::chdr::strs_payload::get_length |
const |
Get the serialized size of this payload in 64 bit words.
◆ operator!=()
bool uhd::rfnoc::chdr::strs_payload::operator!= |
rhs | ) |
const |
inline |
◆ operator=()
◆ operator==()
bool uhd::rfnoc::chdr::strs_payload::operator== |
rhs | ) |
const |
◆ populate_header()
void uhd::rfnoc::chdr::strs_payload::populate_header |
chdr_header & |
header | ) |
const |
Populate the header for this type of packet.
◆ serialize() [1/2]
size_t uhd::rfnoc::chdr::strs_payload::serialize |
uint64_t * |
buff, |
size_t |
max_size_bytes |
| const |
inline |
Serialize the payload to a uint64_t buffer (no conversion function)
◆ serialize() [2/2]
uint64_t * |
buff, |
size_t |
max_size_bytes, |
conv_byte_order |
| const |
Serialize the payload to a uint64_t buffer.
◆ to_string()
std::string uhd::rfnoc::chdr::strs_payload::to_string |
const |
Return a string representation of this object.
◆ buff_info
uint16_t uhd::rfnoc::chdr::strs_payload::buff_info = 0 |
◆ capacity_bytes
uint64_t uhd::rfnoc::chdr::strs_payload::capacity_bytes = 0 |
Buffer capacity in bytes (40 bits)
◆ capacity_pkts
uint32_t uhd::rfnoc::chdr::strs_payload::capacity_pkts = 0 |
Buffer capacity in packets (24 bits)
◆ src_epid
uint16_t uhd::rfnoc::chdr::strs_payload::src_epid = 0 |
The source EPID for the stream (16 bits)
◆ status
The status of the stream (4 bits)
◆ status_info
uint64_t uhd::rfnoc::chdr::strs_payload::status_info = 0 |
Extended status info (48 bits)
◆ xfer_count_bytes
uint64_t uhd::rfnoc::chdr::strs_payload::xfer_count_bytes = 0 |
Transfer count in bytes (64 bits)
◆ xfer_count_pkts
uint64_t uhd::rfnoc::chdr::strs_payload::xfer_count_pkts = 0 |
Transfer count in packets (40 bits)
