#include <uhd/rfnoc/property.hpp>
Public Types | |
enum | access_t { NONE , RO = 0x1 , RW = 0x3 , RWLOCKED = 0x5 } |
property_base_t (const std::string &id, const res_source_info &source_info) | |
virtual | ~property_base_t () |
const std::string & | get_id () const |
Gets the ID (name) of this property. More... | |
const res_source_info & | get_src_info () const |
Return the source info for this property. More... | |
virtual bool | is_dirty () const =0 |
Query this property's dirty flag. More... | |
virtual bool | is_valid () const =0 |
Query this property's valid flag. More... | |
bool | read_access_granted () const |
Returns true if this property can be read. More... | |
bool | write_access_granted () const |
Returns true if this property can be written to. More... | |
access_t | get_access_mode () const |
Return the current access mode. More... | |
virtual bool | equal (property_base_t *rhs) const =0 |
Return true if rhs has the same type and value. More... | |
virtual std::unique_ptr< property_base_t > | clone (res_source_info) |
Create a copy of this property. More... | |
virtual void | force_dirty ()=0 |
virtual void | set_from_str (const std::string &new_val_str)=0 |
Friends | |
class | prop_accessor_t |
Base class for properties
inline |
inlinevirtual |
inlinevirtual |
Reimplemented in uhd::rfnoc::property_t< data_t >, uhd::rfnoc::property_t< double >, and uhd::rfnoc::property_t< size_t >.
Implemented in uhd::rfnoc::property_t< data_t >, uhd::rfnoc::property_t< double >, uhd::rfnoc::property_t< size_t >, and uhd::rfnoc::dirtifier_t.
inline |
inline |
inline |
inline |
Set this property's value using a string
This requires the underlying property type to be convertible from a string.
uhd::runtime_error | if the underlying type has no conversion from a string |
inline |
friend |
