uhd::rfnoc::detail::graph_t Class Reference
Container for the logical graph within an uhd::rfnoc_graph. More...
#include <uhd/rfnoc/detail/graph.hpp>
using uptr = std::unique_ptr< graph_t >
using node_ref_t = uhd::rfnoc::node_t *
 A shorthand for a pointer to a node. More...
using graph_edge_t = uhd::rfnoc::graph_edge_t
 Shorthand to existing graph_edge_t. More...
 graph_t ()
 ~graph_t ()
void connect (node_ref_t src_node, node_ref_t dst_node, graph_edge_t edge_info)
void disconnect (node_ref_t src_node, node_ref_t dst_node, graph_edge_t edge_info)
void remove (node_ref_t node)
void commit ()
void release ()
void shutdown ()
std::vector< graph_edge_t > enumerate_edges ()
std::string to_dot ()
Friends
class graph_accessor_t
◆ graph_edge_t
◆ node_ref_t
◆ uptr
using uhd::rfnoc::detail::graph_t::uptr = std::unique_ptr<graph_t>
◆ graph_t()
uhd::rfnoc::detail::graph_t::graph_t ( )
◆ ~graph_t()
uhd::rfnoc::detail::graph_t::~graph_t ( )
◆ commit()
void uhd::rfnoc::detail::graph_t::commit ( )
Commit graph and run initial checks
This method can be called anytime, but it's intended to be called when the graph has been committed. It will run checks on the graph and run a property propagation.
Exceptions
uhd::resolve_errorif the properties fail to resolve.
◆ connect()
void uhd::rfnoc::detail::graph_t::connect ( node_ref_t  src_node,
Add a connection to the graph
After this function returns, the nodes will be considered connected along the ports specified in edge_info.
src_nodeA reference to the source node
dst_nodeA reference to the destination node
edge_infoInformation about the type of edge
◆ disconnect()
void uhd::rfnoc::detail::graph_t::disconnect ( node_ref_t  src_node,
Remove a connection from the graph
After this function returns, the nodes will be considered disconnected along the ports specified in edge_info.
◆ enumerate_edges()
std::vector<graph_edge_t> uhd::rfnoc::detail::graph_t::enumerate_edges ( )
Return a list of all edges
◆ release()
void uhd::rfnoc::detail::graph_t::release ( )
Opposite of commit()
Calling this will disable property propagation until commit() has been called an equal number of times.
◆ remove()
void uhd::rfnoc::detail::graph_t::remove ( node_ref_t  node)
Remove a node from the graph
Disconnects all edges and removes the node from the graph.
nodeA reference to the node
◆ shutdown()
void uhd::rfnoc::detail::graph_t::shutdown ( )
Shutdown graph: Permenanently release
This will release the graph permanently and safely. All ongoing property and action handling is completed and then disabled (this means that calling shutdown while blocks are still working will cause actions to not get delivered).
◆ to_dot()
std::string uhd::rfnoc::detail::graph_t::to_dot ( )
Create a dot representation of the current graph
The graph is represented in the dot language, which can be visualized using the Graphviz tools. It contains all blocks and their connections. The connections are drawn between the ports of the blocks.
Friends And Related Function Documentation
◆ graph_accessor_t
friend class graph_accessor_t
friend
