19 #define RFNOC_BLOCK_CONSTRUCTOR(CLASS_NAME) \
20 CLASS_NAME##_impl(make_args_ptr make_args) : CLASS_NAME(std::move(make_args))
22 #define RFNOC_DECLARE_BLOCK(CLASS_NAME) \
23 using sptr = std::shared_ptr<CLASS_NAME>; \
24 CLASS_NAME(make_args_ptr make_args) : noc_block_base(std::move(make_args)) {}
26 namespace uhd {
namespace rfnoc {
44 using sptr = std::shared_ptr<noc_block_base>;
64 struct make_args_int_t;
73 using make_args_ptr = std::unique_ptr<make_args_int_t, make_args_deleter>;
83 return get_block_id().to_string();
95 return _num_input_ports;
107 return _num_output_ports;
337 friend class block_initializer;
344 void _set_tick_rate(
const double tick_rate);
351 void shutdown()
override;
375 size_t _num_input_ports;
378 size_t _num_output_ports;
383 std::vector<property_t<double>> _tick_rate_props;
389 bool _mtu_fwd_policy_set =
false;
394 std::vector<property_t<size_t>> _mtu_props;
397 std::unordered_map<res_source_info, size_t> _mtu;
403 std::shared_ptr<clock_iface> _ctrlport_clock_iface;
406 std::shared_ptr<clock_iface> _tb_clock_iface;
411 std::shared_ptr<mb_controller> _mb_controller;
Definition: device_addr.hpp:39
Definition: property_tree.hpp:224
Definition: block_id.hpp:40
Definition: noc_block_base.hpp:42
uhd::device_addr_t get_block_args() const
Definition: noc_block_base.hpp:202
void set_mtu_forwarding_policy(const forwarding_policy_t policy)
uhd::property_tree::sptr & get_tree() const
Return a reference to this block's subtree.
Definition: noc_block_base.hpp:208
size_t get_num_output_ports() const override
Definition: noc_block_base.hpp:105
Return a reference to this block's subtree (non-const version)
Definition: noc_block_base.hpp:214
size_t get_mtu(const res_source_info &edge)
void set_mtu(const res_source_info &edge, const size_t new_mtu)
size_t get_max_payload_size(const res_source_info &edge, const bool account_for_ts=true)
double get_tick_rate() const
std::shared_ptr< mb_controller > get_mb_controller()
void set_num_input_ports(const size_t num_ports)
size_t get_num_input_ports() const override
Definition: noc_block_base.hpp:93
std::string get_unique_id() const override
Unique ID for an RFNoC block is its block ID.
Definition: noc_block_base.hpp:81
noc_block_base(make_args_ptr make_args)
size_t get_chdr_hdr_len(const bool account_for_ts=true) const
~noc_block_base() override
const block_id_t & get_block_id() const
Definition: noc_block_base.hpp:126
noc_id_t get_noc_id() const
Definition: noc_block_base.hpp:117
property_base_t * get_mtu_prop_ref(const res_source_info &edge)
std::unique_ptr< make_args_int_t, make_args_deleter > make_args_ptr
Opaque pointer to the constructor arguments with custom deleter.
Definition: noc_block_base.hpp:73
Definition: noc_block_base.hpp:44
void set_tick_rate(const double tick_rate)
void set_num_output_ports(const size_t num_ports)
forwarding_policy_t
Types of property/action forwarding for those not defined by the block itself.
Definition: node.hpp:54
Definition: property.hpp:26
Definition: register_iface_holder.hpp:19
Definition: config.h:87
uint32_t noc_id_t
Definition: defaults.hpp:52
chdr_w_t
Type that indicates the CHDR Width in bits.
Definition: rfnoc_types.hpp:19
Definition: build_info.hpp:12
Custom deleter for make_args_int_t that doesn't require complete type.
Definition: noc_block_base.hpp:68
void operator()(make_args_int_t *ptr)
Dummy make_args_t class.
Definition: noc_block_base.hpp:54
Definition: res_source_info.hpp:18
