#include <uhd/rfnoc/addsub_block_control.hpp>
| enum class | forwarding_policy_t { ONE_TO_ONE , ONE_TO_FAN , ONE_TO_ALL_IN , ONE_TO_ALL_OUT , ONE_TO_ALL , DROP , USE_MAP } |
| Number of input ports. Note: This gets passed into this block from the. More... | |
| Number of output ports. Note: This gets passed outto this block from the. More... | |
| Return a unique identifier string for this node. In every RFNoC graph,. More... | |
| Update number of input ports. More... | |
| Update number of output ports. More... | |
Add/Sub Block Control Class
The Add/Sub RFNoC block takes in two streams of sc16-formatted data and performs addition and subtraction on the data in the stream, creating two output streams consisting of the sum and difference of the input streams. The block assumes that the input and output packets are all of the same length.
