#include <uhd/rfnoc/keep_one_in_n_block_control.hpp>
Public Types | |
| enum class | mode { SAMPLE_MODE , PACKET_MODE } |
| enum class | forwarding_policy_t { ONE_TO_ONE , ONE_TO_FAN , ONE_TO_ALL_IN , ONE_TO_ALL_OUT , ONE_TO_ALL , DROP , USE_MAP } |
| virtual size_t | get_max_n () const =0 |
| virtual size_t | get_n (const size_t chan=0) const =0 |
| virtual void | set_n (const size_t n, const size_t chan=0)=0 |
| virtual mode | get_mode (const size_t chan=0) const =0 |
| virtual void | set_mode (const mode mode, const size_t chan=0)=0 |
| Number of input ports. Note: This gets passed into this block from the. More... | |
| Number of output ports. Note: This gets passed outto this block from the. More... | |
| Return a unique identifier string for this node. In every RFNoC graph,. More... | |
| static const uint32_t | REG_N_OFFSET |
| static const uint32_t | REG_MODE_OFFSET |
| static const uint32_t | REG_WIDTH_N_OFFSET |
| Update number of input ports. More... | |
| Update number of output ports. More... | |
Keep One in N Block Control Class
The Keep One in N block has two modes: sample mode and packet mode. In sample mode, the first sample is kept and then N-1 samples are dropped. Packet mode is similar to sample mode, except a packet of samples is kept and then N-1 packets are dropped. The packet size is determined automatically.
strong |
Get the maximum supported value for N
Get the maximum supported value for N for all channels
Get the current mode
Get the current mode (sample or packet mode, see mode enum)
| chan | The block channel |
Get the current value of N
Set the mode
Set the mode. There are two modes, sample mode (0) and packet mode (1). In sample mode, the block will keep 1 value and then drop N-1 values. In packet mode, the block will keep 1 packet and then drop N-1 packets.
| mode | The mode of the block |
Set the value of N
Set the value of N. See set_mode() for how the value of N is interpreted depending on the mode.
| n | The number of samples or packets to drop (minus one) |
