USRP Hardware Driver and USRP Manual Version: 4.1.0.1
uhd::rfnoc::null_block_control Class Referenceabstract
#include <uhd/rfnoc/null_block_control.hpp>
Inheritance diagram for uhd::rfnoc::null_block_control:
enum  port_type_t { SINK , SOURCE , LOOP }
enum  count_type_t { LINES , PACKETS }
virtual void issue_stream_cmd (const uhd::stream_cmd_t &stream_cmd)=0
virtual void reset_counters ()=0
virtual void set_bytes_per_packet (const uint32_t bpp)=0
virtual void set_throttle_cycles (const uint32_t cycs)=0
virtual uint32_t get_item_width ()=0
virtual uint32_t get_nipc ()=0
virtual uint32_t get_lines_per_packet ()=0
virtual uint32_t get_bytes_per_packet ()=0
virtual uint32_t get_throttle_cycles ()=0
virtual uint64_t get_count (const port_type_t port_type, const count_type_t count_type)=0
static const uint32_t REG_CTRL_STATUS
static const uint32_t REG_SRC_LINES_PER_PKT
static const uint32_t REG_SRC_BYTES_PER_PKT
static const uint32_t REG_SRC_THROTTLE_CYC
static const uint32_t REG_SNK_LINE_CNT_LO
static const uint32_t REG_SNK_LINE_CNT_HI
static const uint32_t REG_SNK_PKT_CNT_LO
static const uint32_t REG_SNK_PKT_CNT_HI
static const uint32_t REG_SRC_LINE_CNT_LO
static const uint32_t REG_SRC_LINE_CNT_HI
static const uint32_t REG_SRC_PKT_CNT_LO
static const uint32_t REG_SRC_PKT_CNT_HI
static const uint32_t REG_LOOP_LINE_CNT_LO
static const uint32_t REG_LOOP_LINE_CNT_HI
static const uint32_t REG_LOOP_PKT_CNT_LO
static const uint32_t REG_LOOP_PKT_CNT_HI
◆ count_type_t
Enumerator
LINES
PACKETS
◆ port_type_t
Enumerator
SINK
SOURCE
LOOP
◆ get_bytes_per_packet()
virtual uint32_t uhd::rfnoc::null_block_control::get_bytes_per_packet ( )
Get bytes per packet
◆ get_count()
virtual uint64_t uhd::rfnoc::null_block_control::get_count ( const port_type_t  port_type,
Returns the number of lines that have been consumed on port 0 since the last reset
port_typeThe port for which the counter value should be returned, sink, source, or loop.
count_typeIf we want the packet count, or the line count
◆ get_item_width()
virtual uint32_t uhd::rfnoc::null_block_control::get_item_width ( )
Get item width (ITEM_W)
◆ get_lines_per_packet()
virtual uint32_t uhd::rfnoc::null_block_control::get_lines_per_packet ( )
Get lines per packet (including the header!)
◆ get_nipc()
virtual uint32_t uhd::rfnoc::null_block_control::get_nipc ( )
Get number of items per clock (NIPC)
◆ get_throttle_cycles()
virtual uint32_t uhd::rfnoc::null_block_control::get_throttle_cycles ( )
Get throttle cycles
◆ issue_stream_cmd()
virtual void uhd::rfnoc::null_block_control::issue_stream_cmd ( const uhd::stream_cmd_t stream_cmd)
Start/stop the null source (port 0)
◆ reset_counters()
virtual void uhd::rfnoc::null_block_control::reset_counters ( )
Reset the counters
◆ set_bytes_per_packet()
virtual void uhd::rfnoc::null_block_control::set_bytes_per_packet ( const uint32_t  bpp)
Set bytes per packet
Note: This sets the entire packet size, including header.
◆ set_throttle_cycles()
virtual void uhd::rfnoc::null_block_control::set_throttle_cycles ( const uint32_t  cycs)
Set throttle cycles
The block will wait this many cycles between packets. Useful for reducing the data output.
◆ REG_CTRL_STATUS
const uint32_t uhd::rfnoc::null_block_control::REG_CTRL_STATUS
◆ REG_LOOP_LINE_CNT_HI
const uint32_t uhd::rfnoc::null_block_control::REG_LOOP_LINE_CNT_HI
◆ REG_LOOP_LINE_CNT_LO
const uint32_t uhd::rfnoc::null_block_control::REG_LOOP_LINE_CNT_LO
◆ REG_LOOP_PKT_CNT_HI
const uint32_t uhd::rfnoc::null_block_control::REG_LOOP_PKT_CNT_HI
◆ REG_LOOP_PKT_CNT_LO
const uint32_t uhd::rfnoc::null_block_control::REG_LOOP_PKT_CNT_LO
◆ REG_SNK_LINE_CNT_HI
const uint32_t uhd::rfnoc::null_block_control::REG_SNK_LINE_CNT_HI
◆ REG_SNK_LINE_CNT_LO
const uint32_t uhd::rfnoc::null_block_control::REG_SNK_LINE_CNT_LO
◆ REG_SNK_PKT_CNT_HI
const uint32_t uhd::rfnoc::null_block_control::REG_SNK_PKT_CNT_HI
◆ REG_SNK_PKT_CNT_LO
const uint32_t uhd::rfnoc::null_block_control::REG_SNK_PKT_CNT_LO
◆ REG_SRC_BYTES_PER_PKT
const uint32_t uhd::rfnoc::null_block_control::REG_SRC_BYTES_PER_PKT
◆ REG_SRC_LINE_CNT_HI
const uint32_t uhd::rfnoc::null_block_control::REG_SRC_LINE_CNT_HI
◆ REG_SRC_LINE_CNT_LO
const uint32_t uhd::rfnoc::null_block_control::REG_SRC_LINE_CNT_LO
◆ REG_SRC_LINES_PER_PKT
const uint32_t uhd::rfnoc::null_block_control::REG_SRC_LINES_PER_PKT
◆ REG_SRC_PKT_CNT_HI
const uint32_t uhd::rfnoc::null_block_control::REG_SRC_PKT_CNT_HI
◆ REG_SRC_PKT_CNT_LO
const uint32_t uhd::rfnoc::null_block_control::REG_SRC_PKT_CNT_LO
◆ REG_SRC_THROTTLE_CYC
const uint32_t uhd::rfnoc::null_block_control::REG_SRC_THROTTLE_CYC
