uhd::rfnoc::ddc_block_control Class Referenceabstract
#include <uhd/rfnoc/ddc_block_control.hpp>
Inheritance diagram for uhd::rfnoc::ddc_block_control:
virtual double set_freq (const double freq, const size_t chan, const boost::optional< uhd::time_spec_t > time=boost::none)=0
virtual double get_freq (const size_t chan) const =0
virtual uhd::freq_range_t get_frequency_range (const size_t chan) const =0
virtual double get_input_rate (const size_t chan) const =0
virtual void set_input_rate (const double rate, const size_t chan)=0
virtual double get_output_rate (const size_t chan) const =0
virtual uhd::meta_range_t get_output_rates (const size_t chan) const =0
virtual double set_output_rate (const double rate, const size_t chan)=0
virtual void issue_stream_cmd (const uhd::stream_cmd_t &stream_cmd, const size_t port)=0
register_iface & regs ()
static const uint32_t RB_COMPAT_NUM
static const uint32_t RB_NUM_HB
static const uint32_t RB_CIC_MAX_DECIM
static const uint32_t SR_N_ADDR
static const uint32_t SR_M_ADDR
static const uint32_t SR_CONFIG_ADDR
static const uint32_t SR_FREQ_ADDR
static const uint32_t SR_SCALE_IQ_ADDR
static const uint32_t SR_DECIM_ADDR
static const uint32_t SR_MUX_ADDR
static const uint32_t SR_COEFFS_ADDR
static const uint32_t SR_TIME_INCR_ADDR
DDC Block Control Class
The DDC Block is a multi-channel digital downconverter (DDC) with built-in frequency shift. The number of channels as well as the maximum decimation is configurable in the FPGA, the block controller will read out registers to identify the capabilities of this block.
  • freq: The frequency shift at the input. Note: A convenience method set_freq() is provided to set this property. It also takes care of the command time, which set_property() does not, and thus should be preferred.
  • decim: The decimation value
◆ get_freq()
virtual double uhd::rfnoc::ddc_block_control::get_freq ( const size_t  chan) const
Return the current DDS frequency
The current frequency of the DDS
◆ get_frequency_range()
virtual uhd::freq_range_t uhd::rfnoc::ddc_block_control::get_frequency_range ( const size_t  chan) const
Return the range of frequencies that chan can be set to.
The frequency shifter is the first component in the DDC, and thus can shift frequencies (digitally) between -get_input_rate()/2 and +get_input_rate()/2.
The returned values are in Hz (not normalized frequencies) and are valid inputs for set_freq().
The range of frequencies that the DDC can shift the input by
◆ get_input_rate()
virtual double uhd::rfnoc::ddc_block_control::get_input_rate ( const size_t  chan) const
Return the sampling rate at this block's input
chanThe channel for which the rate is being queried
◆ get_output_rate()
virtual double uhd::rfnoc::ddc_block_control::get_output_rate ( const size_t  chan) const
Return the sampling rate at this block's output
This is equivalent to calling get_input_rate() divided by the decimation.
◆ get_output_rates()
virtual uhd::meta_range_t uhd::rfnoc::ddc_block_control::get_output_rates ( const size_t  chan) const
Return a range of valid output rates, based on the current input rate
Note the return value is only valid as long as the input rate does not change.
◆ issue_stream_cmd()
virtual void uhd::rfnoc::ddc_block_control::issue_stream_cmd ( const uhd::stream_cmd_t &  stream_cmd,
const size_t  port
Issue stream command: Instruct the RX part of the radio to send samples
stream_cmdThe actual stream command to execute
portThe port for which the stream command is meant
◆ set_freq()
virtual double uhd::rfnoc::ddc_block_control::set_freq ( const double  freq,
const size_t  chan,
const boost::optional< uhd::time_spec_t >  time = boost::none
Set the DDS frequency
freqThe frequency shift in Hz
chanThe channel to which this change shall be applied
timeWhen to apply the new frequency
The coerced, actual current frequency of the DDS
◆ set_input_rate()
virtual void uhd::rfnoc::ddc_block_control::set_input_rate ( const double  rate,
const size_t  chan
Manually set the sampling rate at this block's input
rateThe requested rate
chanThe channel for which the rate is being set
◆ set_output_rate()
virtual double uhd::rfnoc::ddc_block_control::set_output_rate ( const double  rate,
const size_t  chan
Attempt to set the output rate of this block
This will set the decimation such that the input rate is untouched, and that the input rate divided by the new decimation is as close as possible to the requested rate.
the coerced sampling rate at this block's output
◆ MAJOR_COMPAT
const uint16_t uhd::rfnoc::ddc_block_control::MAJOR_COMPAT
◆ MINOR_COMPAT
const uint16_t uhd::rfnoc::ddc_block_control::MINOR_COMPAT
◆ RB_CIC_MAX_DECIM
const uint32_t uhd::rfnoc::ddc_block_control::RB_CIC_MAX_DECIM
◆ RB_COMPAT_NUM
const uint32_t uhd::rfnoc::ddc_block_control::RB_COMPAT_NUM
◆ RB_NUM_HB
const uint32_t uhd::rfnoc::ddc_block_control::RB_NUM_HB
◆ SR_COEFFS_ADDR
const uint32_t uhd::rfnoc::ddc_block_control::SR_COEFFS_ADDR
◆ SR_CONFIG_ADDR
const uint32_t uhd::rfnoc::ddc_block_control::SR_CONFIG_ADDR
◆ SR_DECIM_ADDR
const uint32_t uhd::rfnoc::ddc_block_control::SR_DECIM_ADDR
◆ SR_FREQ_ADDR
const uint32_t uhd::rfnoc::ddc_block_control::SR_FREQ_ADDR
◆ SR_M_ADDR
const uint32_t uhd::rfnoc::ddc_block_control::SR_M_ADDR
◆ SR_MUX_ADDR
const uint32_t uhd::rfnoc::ddc_block_control::SR_MUX_ADDR
◆ SR_N_ADDR
const uint32_t uhd::rfnoc::ddc_block_control::SR_N_ADDR
◆ SR_SCALE_IQ_ADDR
const uint32_t uhd::rfnoc::ddc_block_control::SR_SCALE_IQ_ADDR
◆ SR_TIME_INCR_ADDR
const uint32_t uhd::rfnoc::ddc_block_control::SR_TIME_INCR_ADDR
