uhd::rfnoc::vector_iir_block_control Class Referenceabstract
#include <uhd/rfnoc/vector_iir_block_control.hpp>
Inheritance diagram for uhd::rfnoc::vector_iir_block_control:
virtual void set_alpha (const double alpha, const size_t chan)=0
virtual double get_alpha (const size_t chan) const =0
virtual void set_beta (const double beta, const size_t chan)=0
virtual double get_beta (const size_t chan) const =0
virtual void set_delay (const uint16_t delay, const size_t chan)=0
virtual uint16_t get_delay (const size_t chan) const =0
virtual uint16_t get_max_delay (const size_t chan) const =0
register_iface & regs ()
static const uint32_t REG_DELAY_OFFSET
static const uint32_t REG_ALPHA_OFFSET
static const uint32_t REG_BETA_OFFSET
Vector IIR Block Control Class
The Vector IIR Block is an RFNoC block that implements an infinite impulse filter with a variable length delay line. The transfer function is defined as follows:
               beta
H(z) = ---------------------— 1 - alpha * z ^ -delay
where
  • beta is the feedforward tap
  • alpha is the feedback tap
  • delay (a.k.a. vector length) is the feedback tap delay
◆ get_alpha()
virtual double uhd::rfnoc::vector_iir_block_control::get_alpha ( const size_t  chan) const
Return the feedback tap value
Returns the feedback tap value for channel chan of the IIR filter.
chanThe channel to retrieve the feedback tap value from
The feedback tap value for the filter
◆ get_beta()
virtual double uhd::rfnoc::vector_iir_block_control::get_beta ( const size_t  chan) const
Return the feedforward tap value
Returns the feedforward tap value for channel chan of the IIR filter.
chanThe channel to retrieve the feedforward tap value from
The feedforward tap value for the filter
◆ get_delay()
virtual uint16_t uhd::rfnoc::vector_iir_block_control::get_delay ( const size_t  chan) const
Return the feedback tap delay
Returns the feedback tap delay value in samples for channel chan of the IIR filter.
chanThe channel to retrieve the feedback tap delay value from
The feedback tap delay of the filter in samples
◆ get_max_delay()
virtual uint16_t uhd::rfnoc::vector_iir_block_control::get_max_delay ( const size_t  chan) const
Return the maximum filter delay
Returns the maximum allowable filter delay value, in samples, for channel chan.
chanThe channel to retrieve the maximum delay from
The maximum filter delay
◆ set_alpha()
virtual void uhd::rfnoc::vector_iir_block_control::set_alpha ( const double  alpha,
const size_t  chan
Set the feedback tap value
Sets the feedback tap value for channel chan of the IIR filter.
alphaThe feedback tap value for the filter
chanThe channel to apply the feedback tap value to
◆ set_beta()
virtual void uhd::rfnoc::vector_iir_block_control::set_beta ( const double  beta,
const size_t  chan
Set the feedforward tap value
Sets the feedforward tap value for channel chan of the IIR filter.
betaThe feedforward tap value for the filter
chanThe channel to apply the feedforward tap value to
◆ set_delay()
virtual void uhd::rfnoc::vector_iir_block_control::set_delay ( const uint16_t  delay,
const size_t  chan
Set the feedback tap delay
Sets the feedback tap delay in samples for channel chan of the IIR filter. The delay value for the filter must be less than or equal to the maximum delay length supported by the filter.
delayThe feedback tap delay of the filter in samples
chanThe channel to apply the feedback tap delay to
◆ REG_ALPHA_OFFSET
const uint32_t uhd::rfnoc::vector_iir_block_control::REG_ALPHA_OFFSET
◆ REG_BETA_OFFSET
const uint32_t uhd::rfnoc::vector_iir_block_control::REG_BETA_OFFSET
◆ REG_BLOCK_SIZE
const uint32_t uhd::rfnoc::vector_iir_block_control::REG_BLOCK_SIZE
◆ REG_DELAY_OFFSET
const uint32_t uhd::rfnoc::vector_iir_block_control::REG_DELAY_OFFSET
