virtual double | set_freq (const double freq, const size_t chan, const boost::optional< uhd::time_spec_t > time=boost::none)=0 |
virtual double | get_freq (const size_t chan) const =0 |
virtual uhd::freq_range_t | get_frequency_range (const size_t chan) const =0 |
virtual double | get_input_rate (const size_t chan) const =0 |
virtual void | set_input_rate (const double rate, const size_t chan)=0 |
virtual double | get_output_rate (const size_t chan) const =0 |
virtual uhd::meta_range_t | get_output_rates (const size_t chan) const =0 |
virtual double | set_output_rate (const double rate, const size_t chan)=0 |
virtual void | issue_stream_cmd (const uhd::stream_cmd_t &stream_cmd, const size_t port)=0 |
| ~noc_block_base () override |
std::string | get_unique_id () const override |
| Unique ID for an RFNoC block is its block ID. More...
size_t | get_num_input_ports () const override |
size_t | get_num_output_ports () const override |
noc_id_t | get_noc_id () const |
const block_id_t & | get_block_id () const |
double | get_tick_rate () const |
size_t | get_mtu (const res_source_info &edge) |
size_t | get_chdr_hdr_len (const bool account_for_ts=true) const |
size_t | get_max_payload_size (const res_source_info &edge, const bool account_for_ts=true) |
uhd::device_addr_t | get_block_args () const |
uhd::property_tree::sptr & | get_tree () const |
| Return a reference to this block's subtree. More...
uhd::property_tree::sptr & | get_tree () |
| Return a reference to this block's subtree (non-const version) More...
std::shared_ptr< mb_controller > | get_mb_controller () |
| node_t () |
virtual | ~node_t () |
std::vector< std::string > | get_property_ids () const |
template<typename prop_data_t > |
void | set_property (const std::string &id, const prop_data_t &val, const size_t instance=0) |
void | set_properties (const uhd::device_addr_t &props, const size_t instance=0) |
const prop_data_t & | get_property (const std::string &id, const size_t instance=0) |
virtual void | set_command_time (uhd::time_spec_t time, const size_t instance) |
virtual uhd::time_spec_t | get_command_time (const size_t instance) const |
virtual void | clear_command_time (const size_t instance) |
| register_iface_holder (register_iface::sptr reg) |
virtual | ~register_iface_holder ()=default |
register_iface & | regs () |
using | sptr = std::shared_ptr< noc_block_base > |
using | make_args_ptr = std::unique_ptr< make_args_t > |
| Opaque pointer to the constructor arguments. More...
enum class | forwarding_policy_t {
ONE_TO_ONE
, ONE_TO_FAN
, ONE_TO_ALL_IN
, ONE_TO_ALL_OUT
ONE_TO_ALL
, DROP
, USE_MAP
| Types of property/action forwarding for those not defined by the block itself. More...
using | resolver_fn_t = std::function< void(void)> |
using | resolve_callback_t = std::function< void(void)> |
using | graph_mutex_callback_t = std::function< std::recursive_mutex &(void)> |
using | action_handler_t = std::function< void(const res_source_info &, action_info::sptr)> |
using | forwarding_map_t = std::unordered_map< res_source_info, std::vector< res_source_info > > |
using | prop_ptrs_t = std::vector< property_base_t * > |
| noc_block_base (make_args_ptr make_args) |
void | set_num_input_ports (const size_t num_ports) |
void | set_num_output_ports (const size_t num_ports) |
void | set_tick_rate (const double tick_rate) |
void | set_mtu_forwarding_policy (const forwarding_policy_t policy) |
void | set_mtu (const res_source_info &edge, const size_t new_mtu) |
property_base_t * | get_mtu_prop_ref (const res_source_info &edge) |
virtual void | deinit () |
void | register_property (property_base_t *prop, resolve_callback_t &&clean_callback=nullptr) |
void | add_property_resolver (prop_ptrs_t &&inputs, prop_ptrs_t &&outputs, resolver_fn_t &&resolver_fn) |
void | set_prop_forwarding_policy (forwarding_policy_t policy, const std::string &prop_id="") |
void | set_prop_forwarding_map (const forwarding_map_t &map) |
void | set_property (const std::string &id, const prop_data_t &val, const res_source_info &src_info) |
const prop_data_t & | get_property (const std::string &id, const res_source_info &src_info) |
void | register_action_handler (const std::string &id, action_handler_t &&handler) |
void | set_action_forwarding_policy (forwarding_policy_t policy, const std::string &action_key="") |
void | set_action_forwarding_map (const forwarding_map_t &map) |
void | post_action (const res_source_info &edge_info, action_info::sptr action) |
virtual bool | check_topology (const std::vector< size_t > &connected_inputs, const std::vector< size_t > &connected_outputs) |
void | update_reg_iface (register_iface::sptr new_iface=nullptr) |
static dirtifier_t | ALWAYS_DIRTY |
| A dirtifyer object, useful for properties that always need updating. More...
DDC Block Control Class
The DDC Block is a multi-channel digital downconverter (DDC) with built-in frequency shift. The number of channels as well as the maximum decimation is configurable in the FPGA, the block controller will read out registers to identify the capabilities of this block.
freq
: The frequency shift at the input. Note: A convenience method set_freq() is provided to set this property. It also takes care of the command time, which set_property() does not, and thus should be preferred.
decim
: The decimation value
virtual double uhd::rfnoc::ddc_block_control::set_freq |
const double |
freq, |
const size_t |
chan, |
const boost::optional< uhd::time_spec_t > |
time = boost::none |
Set the DDS frequency
- Parameters
freq | The frequency shift in Hz |
chan | The channel to which this change shall be applied |
time | When to apply the new frequency |
- Returns
- The coerced, actual current frequency of the DDS
