#include <uhd/rfnoc/fft_block_control.hpp>
virtual void | set_direction (const fft_direction direction)=0 |
virtual fft_direction | get_direction () const =0 |
virtual void | set_magnitude (const fft_magnitude magnitude)=0 |
virtual fft_magnitude | get_magnitude () const =0 |
virtual void | set_shift_config (const fft_shift shift)=0 |
virtual fft_shift | get_shift_config () const =0 |
virtual void | set_scaling (const uint16_t scaling)=0 |
virtual uint16_t | get_scaling () const =0 |
virtual void | set_length (const size_t length)=0 |
virtual size_t | get_length () const =0 |
~noc_block_base () override | |
std::string | get_unique_id () const override |
Unique ID for an RFNoC block is its block ID. More... | |
size_t | get_num_input_ports () const override |
size_t | get_num_output_ports () const override |
noc_id_t | get_noc_id () const |
const block_id_t & | get_block_id () const |
double | get_tick_rate () const |
size_t | get_mtu (const res_source_info &edge) |
size_t | get_chdr_hdr_len (const bool account_for_ts=true) const |
size_t | get_max_payload_size (const res_source_info &edge, const bool account_for_ts=true) |
uhd::device_addr_t | get_block_args () const |
uhd::property_tree::sptr & | get_tree () const |
Return a reference to this block's subtree. More... | |
uhd::property_tree::sptr & | get_tree () |
Return a reference to this block's subtree (non-const version) More... | |
std::shared_ptr< mb_controller > | get_mb_controller () |
node_t () | |
virtual | ~node_t () |
std::vector< std::string > | get_property_ids () const |
template<typename prop_data_t > | |
void | set_property (const std::string &id, const prop_data_t &val, const size_t instance=0) |
void | set_properties (const uhd::device_addr_t &props, const size_t instance=0) |
const prop_data_t & | get_property (const std::string &id, const size_t instance=0) |
virtual void | set_command_time (uhd::time_spec_t time, const size_t instance) |
virtual uhd::time_spec_t | get_command_time (const size_t instance) const |
virtual void | clear_command_time (const size_t instance) |
register_iface_holder (register_iface::sptr reg) | |
virtual | ~register_iface_holder ()=default |
register_iface & | regs () |
static const uint32_t | REG_RESET_ADDR |
static const uint32_t | REG_LENGTH_LOG2_ADDR |
static const uint32_t | REG_MAGNITUDE_OUT_ADDR |
static const uint32_t | REG_DIRECTION_ADDR |
static const uint32_t | REG_SCALING_ADDR |
static const uint32_t | REG_SHIFT_CONFIG_ADDR |
static const size_t | ANY_PORT = size_t(~0) |
using | sptr = std::shared_ptr< noc_block_base > |
using | make_args_ptr = std::unique_ptr< make_args_t > |
Opaque pointer to the constructor arguments. More... | |
enum class | forwarding_policy_t { ONE_TO_ONE , ONE_TO_FAN , ONE_TO_ALL_IN , ONE_TO_ALL_OUT , ONE_TO_ALL , DROP , USE_MAP } |
Types of property/action forwarding for those not defined by the block itself. More... | |
using | resolver_fn_t = std::function< void(void)> |
using | resolve_callback_t = std::function< void(void)> |
using | graph_mutex_callback_t = std::function< std::recursive_mutex &(void)> |
using | action_handler_t = std::function< void(const res_source_info &, action_info::sptr)> |
using | forwarding_map_t = std::unordered_map< res_source_info, std::vector< res_source_info > > |
using | prop_ptrs_t = std::vector< property_base_t * > |
noc_block_base (make_args_ptr make_args) | |
void | set_num_input_ports (const size_t num_ports) |
void | set_num_output_ports (const size_t num_ports) |
void | set_tick_rate (const double tick_rate) |
void | set_mtu_forwarding_policy (const forwarding_policy_t policy) |
void | set_mtu (const res_source_info &edge, const size_t new_mtu) |
property_base_t * | get_mtu_prop_ref (const res_source_info &edge) |
virtual void | deinit () |
void | register_property (property_base_t *prop, resolve_callback_t &&clean_callback=nullptr) |
void | add_property_resolver (prop_ptrs_t &&inputs, prop_ptrs_t &&outputs, resolver_fn_t &&resolver_fn) |
void | set_prop_forwarding_policy (forwarding_policy_t policy, const std::string &prop_id="") |
void | set_prop_forwarding_map (const forwarding_map_t &map) |
void | set_property (const std::string &id, const prop_data_t &val, const res_source_info &src_info) |
const prop_data_t & | get_property (const std::string &id, const res_source_info &src_info) |
void | register_action_handler (const std::string &id, action_handler_t &&handler) |
void | set_action_forwarding_policy (forwarding_policy_t policy, const std::string &action_key="") |
void | set_action_forwarding_map (const forwarding_map_t &map) |
void | post_action (const res_source_info &edge_info, action_info::sptr action) |
virtual bool | check_topology (const std::vector< size_t > &connected_inputs, const std::vector< size_t > &connected_outputs) |
void | update_reg_iface (register_iface::sptr new_iface=nullptr) |
static dirtifier_t | ALWAYS_DIRTY |
A dirtifyer object, useful for properties that always need updating. More... | |
FFT Block Control Class
The FFT block is an RFNoC block that accepts signed complex 16-bit data at its input and computes the forward or reverse FFT of the input data, outputting signed complex 16-bit data at its output. The output data may be configured as complex, magnitude, or mag-squared values, its spectrum shifted and/or reversed, and scaled by a scaled factor.
The FFT length is configured via the length parameter, up to a maximum of 2048 samples. The FFT IP requires a power-of-two number of samples; the length will be coerced to the closest power of two which is smaller than length. The block will output packets of the same length in the desired format as configured via the API.
Get the FFT direction
Returns the current direction of the FFT.
Get the length of the FFT
Returns the current length of the FFT.
Get the format of the returned FFT output data
Returns the current output format of the FFT data.
Get the scaling schedule for the FFT block
Returns the current scaling schedule for the FFT block.
Get the shift configuration of the output FFT data
Returns the current shift configuration of the output FFT data.
Set the FFT direction
Sets the direction of the FFT, either forward (FORWARD) or inverse (REVERSE).
direction | FFT direction |
Set the length of the FFT
Sets the length of the FFT in number of samples. Note that the FFT IP requires a power-of-two number of samples; the incoming value will be coerced to the closest smaller power of two.
length | Desired FFT length |
Set the format of the returned FFT output data
Sets the format in which the FFT output data is returned. The following formats are supported:
* amplitude/phase data (COMPLEX) * magnitude data (MAGNITUDE) * mag-squared data (MAGNITUDE_SQUARED)
magnitude | Format of the returned FFT output data |
Set the scaling schedule for the FFT block
Sets the scaling for each stage of the FFT. This value maps directly to the scale schedule field in the configuration channel data that is passed to the Xilinx AXI FFT IP. For more information on the format of this data, see Xilinx document PG109, Fast Fourier Transform LogiCORE IP Product Guide.
scaling | Scaling schedule for the FFT block |
Set the shift configuration of the output FFT data
Sets how the FFT output data is shifted (to get the zero frequency bin to the center of the output data). The following output data shift configurations are supported:
* Negative frequencies first, then positive frequencies (NORMAL) * Positive frequencies first, then negative frequencies (REVERSE) * Bypass the shift altogether, leaving the zero frequency bin returned first (NATURAL).
shift | Configuration for shifting FFT output data |
