#include <uhd/rfnoc/moving_average_block_control.hpp>
virtual void | set_sum_len (const uint8_t sum_len)=0 |
virtual uint8_t | get_sum_len () const =0 |
virtual void | set_divisor (const uint32_t divisor)=0 |
virtual uint32_t | get_divisor () const =0 |
~noc_block_base () override | |
std::string | get_unique_id () const override |
Unique ID for an RFNoC block is its block ID. More... | |
size_t | get_num_input_ports () const override |
size_t | get_num_output_ports () const override |
noc_id_t | get_noc_id () const |
const block_id_t & | get_block_id () const |
double | get_tick_rate () const |
size_t | get_mtu (const res_source_info &edge) |
size_t | get_chdr_hdr_len (const bool account_for_ts=true) const |
size_t | get_max_payload_size (const res_source_info &edge, const bool account_for_ts=true) |
uhd::device_addr_t | get_block_args () const |
uhd::property_tree::sptr & | get_tree () const |
Return a reference to this block's subtree. More... | |
uhd::property_tree::sptr & | get_tree () |
Return a reference to this block's subtree (non-const version) More... | |
std::shared_ptr< mb_controller > | get_mb_controller () |
node_t () | |
virtual | ~node_t () |
std::vector< std::string > | get_property_ids () const |
template<typename prop_data_t > | |
void | set_property (const std::string &id, const prop_data_t &val, const size_t instance=0) |
void | set_properties (const uhd::device_addr_t &props, const size_t instance=0) |
const prop_data_t & | get_property (const std::string &id, const size_t instance=0) |
virtual void | set_command_time (uhd::time_spec_t time, const size_t instance) |
virtual uhd::time_spec_t | get_command_time (const size_t instance) const |
virtual void | clear_command_time (const size_t instance) |
register_iface_holder (register_iface::sptr reg) | |
virtual | ~register_iface_holder ()=default |
register_iface & | regs () |
static const uint32_t | REG_SUM_LEN_ADDR |
static const uint32_t | REG_DIVISOR_ADDR |
static const size_t | ANY_PORT = size_t(~0) |
using | sptr = std::shared_ptr< noc_block_base > |
using | make_args_ptr = std::unique_ptr< make_args_t > |
Opaque pointer to the constructor arguments. More... | |
enum class | forwarding_policy_t { ONE_TO_ONE , ONE_TO_FAN , ONE_TO_ALL_IN , ONE_TO_ALL_OUT , ONE_TO_ALL , DROP , USE_MAP } |
Types of property/action forwarding for those not defined by the block itself. More... | |
using | resolver_fn_t = std::function< void(void)> |
using | resolve_callback_t = std::function< void(void)> |
using | graph_mutex_callback_t = std::function< std::recursive_mutex &(void)> |
using | action_handler_t = std::function< void(const res_source_info &, action_info::sptr)> |
using | forwarding_map_t = std::unordered_map< res_source_info, std::vector< res_source_info > > |
using | prop_ptrs_t = std::vector< property_base_t * > |
noc_block_base (make_args_ptr make_args) | |
void | set_num_input_ports (const size_t num_ports) |
void | set_num_output_ports (const size_t num_ports) |
void | set_tick_rate (const double tick_rate) |
void | set_mtu_forwarding_policy (const forwarding_policy_t policy) |
void | set_mtu (const res_source_info &edge, const size_t new_mtu) |
property_base_t * | get_mtu_prop_ref (const res_source_info &edge) |
virtual void | deinit () |
void | register_property (property_base_t *prop, resolve_callback_t &&clean_callback=nullptr) |
void | add_property_resolver (prop_ptrs_t &&inputs, prop_ptrs_t &&outputs, resolver_fn_t &&resolver_fn) |
void | set_prop_forwarding_policy (forwarding_policy_t policy, const std::string &prop_id="") |
void | set_prop_forwarding_map (const forwarding_map_t &map) |
void | set_property (const std::string &id, const prop_data_t &val, const res_source_info &src_info) |
const prop_data_t & | get_property (const std::string &id, const res_source_info &src_info) |
void | register_action_handler (const std::string &id, action_handler_t &&handler) |
void | set_action_forwarding_policy (forwarding_policy_t policy, const std::string &action_key="") |
void | set_action_forwarding_map (const forwarding_map_t &map) |
void | post_action (const res_source_info &edge_info, action_info::sptr action) |
virtual bool | check_topology (const std::vector< size_t > &connected_inputs, const std::vector< size_t > &connected_outputs) |
void | update_reg_iface (register_iface::sptr new_iface=nullptr) |
static dirtifier_t | ALWAYS_DIRTY |
A dirtifyer object, useful for properties that always need updating. More... | |
Moving Average Block Control Class
The Moving Average block is an RFNoC block that computes the running average of an input data stream. The output is the sum of the last SUM_LEN samples divided by DIVISOR which may or may not be equal to SUM_LEN. For example, if SUM_LEN is set to 10 and DIVISOR is set to 10, the block will return a sample that is the average of the last 10 samples. If SUM_LEN is set to 10 and DIVISOR is set to 1, the block will return a sample that is equal to the sum of the last 10 samples.
Return the current divisor
Return the current sum length
Set the divisor
divisor | The amount to divide the sum by |
Set the Sum Length
Changing the sum length will clear the history and reset the accumulated sum to 0.
sum_len | The number of samples to sum |
