17 namespace uhd {
namespace rfnoc {
20 class prop_accessor_t;
37 : _id(id), _source_info(source_info)
39 if (_id.find(
':') != std::string::npos) {
41 "Property ID `" + _id +
"' contains invalid character!");
77 return static_cast<uint8_t
>(_access_mode) & 0x1;
83 return static_cast<uint8_t
>(_access_mode) & 0x2;
121 friend class prop_accessor_t;
124 virtual void mark_clean() = 0;
136 const std::string _id;
149 template <
typename data_t>
159 const std::string&
id,
const data_t& value,
const res_source_info& source_info);
171 return _data.is_dirty();
185 if (!is_type_equal(rhs)) {
193 return std::unique_ptr<property_base_t>(
200 set(uhd::cast::from_str<data_t>(new_val_str));
203 std::string(
"Property ") + get_id() +
":" + ex.what());
215 void set(
const data_t& value)
217 if (write_access_granted()) {
220 }
else if (get_access_mode() == RWLOCKED) {
221 if (_data.get() != value) {
223 + get_id() +
"@" + get_src_info().to_string()
224 +
"' with a new value after it was locked!");
228 + get_id() +
"' without access privileges!");
234 if (write_access_granted()) {
236 }
237 if (!_data.is_dirty()) {
240 +
"' with dirty flag after it was locked!");
244 + get_id() +
256 + get_id() +
257 +
"' before it was initialized!");
259 if (read_access_granted()) {
263 +
266 operator const data_t&()
const
283 void mark_clean()
override
288 void forward(property_base_t* next_prop)
override
292 std::string(
"Unable to forward invalid property ") + get_id());
294 property_t<data_t>* prop_ptr =
dynamic_cast<property_t<data_t>*
>(next_prop);
295 if (prop_ptr ==
nullptr) {
297 + next_prop->get_id() +
" to the same type as property "
301 prop_ptr->set(get());
304 bool is_type_equal(property_base_t* other_prop)
const override
306 return dynamic_cast<property_t<data_t>*
>(other_prop) !=
nullptr;
309 dirty_tracked<data_t> _data;
Definition: property.hpp:26
virtual void force_dirty()=0
virtual bool equal(property_base_t *rhs) const =0
Return true if rhs has the same type and value.
access_t
Definition: property.hpp:28
@ NONE
Neither reading nor writing to this property is permitted.
Definition: property.hpp:29
property_base_t(const std::string &id, const res_source_info &source_info)
Definition: property.hpp:36
virtual void set_from_str(const std::string &new_val_str)=0
virtual std::unique_ptr< property_base_t > clone(res_source_info)
Create a copy of this property.
Definition: property.hpp:103
virtual bool is_valid() const =0
Query this property's valid flag.
const res_source_info & get_src_info() const
Return the source info for this property.
Definition: property.hpp:57
access_t get_access_mode() const
Return the current access mode.
Definition: property.hpp:87
virtual ~property_base_t()
Definition: property.hpp:45
const std::string & get_id() const
Gets the ID (name) of this property.
Definition: property.hpp:51
bool write_access_granted() const
Returns true if this property can be written to.
Definition: property.hpp:81
bool read_access_granted() const
Returns true if this property can be read.
Definition: property.hpp:75
virtual bool is_dirty() const =0
Query this property's dirty flag.
Definition: property.hpp:151
void set(const data_t &value)
Returns the source info for the property.
Definition: property.hpp:215
bool is_dirty() const override
Returns the dirty state of this property.
Definition: property.hpp:169
const data_t & get() const
Get the value of this property.
Definition: property.hpp:252
bool is_valid() const override
Definition: property.hpp:178
std::unique_ptr< property_base_t > clone(res_source_info new_src_info) override
Definition: property.hpp:191
void set_from_str(const std::string &new_val_str) override
Definition: property.hpp:197
data_t value_type
We want to be good C++ citizens.
Definition: property.hpp:154
bool operator==(const data_t &rhs)
Definition: property.hpp:271
property_t< data_t > & operator=(const data_t &value)
Definition: property.hpp:276
bool equal(property_base_t *rhs) const override
Definition: property.hpp:183
void force_dirty() override
Definition: property.hpp:232
property_t(const property_t< data_t > &prop)=default
#define UHD_API_HEADER
Definition: config.h:88
Definition: config.h:87
Definition: build_info.hpp:12
Definition: exception.hpp:168
Definition: exception.hpp:157
Definition: exception.hpp:281
Definition: res_source_info.hpp:18
Definition: exception.hpp:132
Definition: exception.hpp:96
Definition: exception.hpp:108
