#include <uhd/rfnoc/property.hpp>
Public Types | |
using | value_type = data_t |
We want to be good C++ citizens. More... | |
Public Types inherited from uhd::rfnoc::property_base_t | |
enum | access_t { NONE , RO = 0x1 , RW = 0x3 , RWLOCKED = 0x5 } |
property_t (const std::string &id, data_t &&value, const res_source_info &source_info) | |
property_t (const std::string &id, const data_t &value, const res_source_info &source_info) | |
property_t (const std::string &id, const res_source_info &source_info) | |
property_t (const property_t< data_t > &prop)=default | |
bool | is_dirty () const override |
Returns the dirty state of this property. More... | |
bool | is_valid () const override |
Query this property's valid flag. More... | |
bool | equal (property_base_t *rhs) const override |
Return true if rhs has the same type and value. More... | |
std::unique_ptr< property_base_t > | clone (res_source_info new_src_info) override |
Create a copy of this property. More... | |
void | set_from_str (const std::string &new_val_str) override |
void | set (const data_t &value) |
Returns the source info for the property. More... | |
void | force_dirty () override |
const data_t & | get () const |
Get the value of this property. More... | |
operator const data_t & () const | |
bool | operator== (const data_t &rhs) |
property_t< data_t > & | operator= (const data_t &value) |
Public Member Functions inherited from uhd::rfnoc::property_base_t | |
property_base_t (const std::string &id, const res_source_info &source_info) | |
virtual | ~property_base_t () |
const std::string & | get_id () const |
Gets the ID (name) of this property. More... | |
const res_source_info & | get_src_info () const |
Return the source info for this property. More... | |
bool | read_access_granted () const |
Returns true if this property can be read. More... | |
bool | write_access_granted () const |
Returns true if this property can be written to. More... | |
access_t | get_access_mode () const |
Return the current access mode. More... | |
An encapsulation class for a block property.
using uhd::rfnoc::property_t< data_t >::value_type = data_t |
uhd::rfnoc::property_t< data_t >::property_t | ( | const std::string & | id, |
data_t && | value, | ||
const res_source_info & | source_info | ||
const data_t & | value, | ||
default |
inlineoverridevirtual |
Reimplemented from uhd::rfnoc::property_base_t.
Implements uhd::rfnoc::property_base_t.
inline |
inline |
inline |
inline |
inline |
Set the value of this property
Set this property's value using a string
This requires the underlying property type to be convertible from a string.
uhd::runtime_error | if the underlying type has no conversion from a string |
