#include <uhd/rfnoc/siggen_block_ctrl.hpp>
Public Types inherited from uhd::rfnoc::source_block_ctrl_base | |
| typedef boost::shared_ptr< source_block_ctrl_base > | sptr |
Public Types inherited from uhd::rfnoc::block_ctrl_base | |
| typedef boost::shared_ptr< block_ctrl_base > | sptr |
| typedef boost::function< sptr(const make_args_t &)> | make_t |
Public Types inherited from uhd::rfnoc::node_ctrl_base | |
| typedef boost::shared_ptr< node_ctrl_base > | sptr |
| typedef boost::weak_ptr< node_ctrl_base > | wptr |
| typedef std::map< size_t, wptr > | node_map_t |
| typedef std::pair< size_t, wptr > | node_map_pair_t |
Public Types inherited from uhd::rfnoc::source_node_ctrl | |
| typedef boost::shared_ptr< source_node_ctrl > | sptr |
| typedef std::map< size_t, boost::weak_ptr< source_node_ctrl > > | node_map_t |
| typedef std::pair< size_t, boost::weak_ptr< source_node_ctrl > > | node_map_pair_t |
Public Types inherited from uhd::rfnoc::sink_block_ctrl_base | |
| typedef boost::shared_ptr< sink_block_ctrl_base > | sptr |
Public Types inherited from uhd::rfnoc::sink_node_ctrl | |
| typedef boost::shared_ptr< sink_node_ctrl > | sptr |
| typedef std::map< size_t, boost::weak_ptr< sink_node_ctrl > > | node_map_t |
| typedef std::pair< size_t, boost::weak_ptr< sink_node_ctrl > > | node_map_pair_t |
Public Member Functions inherited from uhd::rfnoc::source_block_ctrl_base | |
| virtual void | issue_stream_cmd (const uhd::stream_cmd_t &stream_cmd, const size_t chan=0) |
| stream_sig_t | get_output_signature (size_t block_port=0) const |
| std::vector< size_t > | get_output_ports () const |
| virtual void | set_destination (boost::uint32_t next_address, size_t output_block_port=0) |
| virtual void | configure_flow_control_out (size_t buf_size_pkts, size_t block_port=0, const uhd::sid_t &sid=uhd::sid_t()) |
Public Member Functions inherited from uhd::rfnoc::block_ctrl_base | |
| boost::uint32_t | get_address (size_t block_port=0) |
| block_id_t | get_block_id () const |
| std::string | unique_id () const |
| std::vector< size_t > | get_ctrl_ports () const |
| void | sr_write (const boost::uint32_t reg, const boost::uint32_t data, const size_t port=0) |
| void | sr_write (const std::string ®, const boost::uint32_t data, const size_t port=0) |
| boost::uint64_t | sr_read64 (const settingsbus_reg_t reg, const size_t port=0) |
| boost::uint32_t | sr_read32 (const settingsbus_reg_t reg, const size_t port=0) |
| boost::uint64_t | user_reg_read64 (const boost::uint32_t addr, const size_t port=0) |
| boost::uint64_t | user_reg_read64 (const std::string ®, const size_t port=0) |
| boost::uint32_t | user_reg_read32 (const boost::uint32_t addr, const size_t port=0) |
| boost::uint32_t | user_reg_read32 (const std::string ®, const size_t port=0) |
| void | set_command_time (const time_spec_t &time_spec, const size_t port=ANY_PORT) |
| time_spec_t | get_command_time (const size_t port=0) |
| void | set_command_tick_rate (const double tick_rate, const size_t port=ANY_PORT) |
| void | clear_command_time (const size_t port) |
| void | clear (const size_t port=0) |
| void | set_args (const uhd::device_addr_t &args, const size_t port=0) |
| void | set_arg (const std::string &key, const std::string &val, const size_t port=0) |
Set a specific block argument. val is converted to the corresponding. More... | |
| template<typename T > | |
| void | set_arg (const std::string &key, const T &val, const size_t port=0) |
| Direct access to set a block argument. More... | |
| uhd::device_addr_t | get_args (const size_t port=0) const |
| Return all block arguments as a device_addr_t. More... | |
| std::string | get_arg (const std::string &key, const size_t port=0) const |
| Return a single block argument in string format. More... | |
| T | get_arg (const std::string &key, const size_t port=0) const |
| Direct access to get a block argument. More... | |
| std::string | get_arg_type (const std::string &key, const size_t port=0) const |
Public Member Functions inherited from uhd::rfnoc::node_ctrl_base | |
| virtual void | clear () |
| node_map_t | list_downstream_nodes () |
| node_map_t | list_upstream_nodes () |
| void | set_downstream_port (const size_t this_port, const size_t remote_port) |
| size_t | get_downstream_port (const size_t this_port) |
| void | set_upstream_port (const size_t this_port, const size_t remote_port) |
| size_t | get_upstream_port (const size_t this_port) |
| UHD_INLINE std::vector< boost::shared_ptr< T > > | find_downstream_node () |
| UHD_INLINE std::vector< boost::shared_ptr< T > > | find_upstream_node () |
| template<typename T , typename value_type > | |
| UHD_INLINE value_type | find_downstream_unique_property (boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >()) |
| UHD_INLINE value_type | find_upstream_unique_property (boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >()) |
Public Member Functions inherited from uhd::rfnoc::source_node_ctrl | |
| size_t | connect_downstream (node_ctrl_base::sptr downstream_node, size_t port=ANY_PORT, const uhd::device_addr_t &args=uhd::device_addr_t()) |
| virtual void | set_rx_streamer (bool active, const size_t port) |
Public Member Functions inherited from uhd::rfnoc::sink_block_ctrl_base | |
| stream_sig_t | get_input_signature (size_t block_port=0) const |
| std::vector< size_t > | get_input_ports () const |
| size_t | get_fifo_size (size_t block_port=0) const |
| virtual void | configure_flow_control_in (size_t cycles, size_t packets, size_t block_port=0) |
| virtual void | set_error_policy (const std::string &policy) |
Public Member Functions inherited from uhd::rfnoc::sink_node_ctrl | |
| size_t | connect_upstream (node_ctrl_base::sptr upstream_node, size_t port=ANY_PORT, const uhd::device_addr_t &args=uhd::device_addr_t()) |
| virtual void | set_tx_streamer (bool active, const size_t port) |
Static Public Member Functions inherited from uhd::rfnoc::block_ctrl_base | |
| static void | register_block (const make_t &make, const std::string &name) |
| static sptr | make (const make_args_t &make_args, boost::uint64_t noc_id=~0) |
| Create a block controller class given a NoC-ID or a block name. More... | |
Protected Member Functions inherited from uhd::rfnoc::source_block_ctrl_base | |
| virtual size_t | _request_output_port (const size_t suggested_port, const uhd::device_addr_t &args) const |
Protected Member Functions inherited from uhd::rfnoc::block_ctrl_base | |
| block_ctrl_base (void) | |
| virtual | ~block_ctrl_base () |
| block_ctrl_base (const make_args_t &make_args) | |
| stream_sig_t | _resolve_port_def (const blockdef::port_t &port_def) const |
| uhd::fs_path | get_arg_path (const std::string &key, size_t port=0) const |
Return the property tree path to a block argument key on port. More... | |
| wb_iface::sptr | get_ctrl_iface (const size_t block_port) |
Get a control interface object for block port block_port. More... | |
| virtual void | _clear (const size_t port=0) |
| Override this function if your block does something else. More... | |
Protected Member Functions inherited from uhd::rfnoc::node_ctrl_base | |
| node_ctrl_base (void) | |
| virtual | ~node_ctrl_base () |
Protected Member Functions inherited from uhd::rfnoc::sink_block_ctrl_base | |
| virtual size_t | _request_input_port (const size_t suggested_port, const uhd::device_addr_t &args) const |
Protected Attributes inherited from uhd::rfnoc::block_ctrl_base | |
| uhd::property_tree::sptr | _tree |
| Property sub-tree. More... | |
| uhd::fs_path | _root_path |
| Root node of this block's properties. More... | |
| bool | _transport_is_big_endian |
| Endianness of underlying transport (for data transport) More... | |
| blockdef::sptr | _block_def |
| Block definition (stores info about the block such as ports) More... | |
Protected Attributes inherited from uhd::rfnoc::node_ctrl_base | |
| uhd::device_addr_t | _args |
| Stores default arguments. More... | |
| node_map_t | _upstream_nodes |
| List of upstream nodes. More... | |
| node_map_t | _downstream_nodes |
| List of downstream nodes. More... | |
Protected Attributes inherited from uhd::rfnoc::source_node_ctrl | |
| std::map< size_t, bool > | _rx_streamer_active |
Protected Attributes inherited from uhd::rfnoc::sink_node_ctrl | |
| std::map< size_t, bool > | _tx_streamer_active |
