block_ctrl_base.hpp File Reference
#include <uhd/rfnoc/block_id.hpp>
#include <uhd/rfnoc/blockdef.hpp>
#include <uhd/rfnoc/constants.hpp>
#include <uhd/rfnoc/node_ctrl_base.hpp>
#include <uhd/rfnoc/stream_sig.hpp>
#include <uhd/stream.hpp>
#include <uhd/types/sid.hpp>
#include <uhd/types/wb_iface.hpp>
#include <uhd/utils/static.hpp>
#include <stdint.h>
Classes
struct  uhd::rfnoc::make_args_t
class  uhd::rfnoc::block_ctrl_base
Namespaces
 uhd
 uhd::rfnoc
 uhd::rfnoc::nocscript
Macros
#define UHD_RFNOC_BLOCK_OBJECT(class_name)   typedef boost::shared_ptr<class_name> sptr;
 This macro must be put in the public section of an RFNoC. More...
#define UHD_RFNOC_BLOCK_CONSTRUCTOR(CLASS_NAME)   CLASS_NAME##_impl(const make_args_t& make_args) : block_ctrl_base(make_args)
 Shorthand for block constructor. More...
#define UHD_RFNOC_BLOCK_REGISTER(CLASS_NAME, BLOCK_NAME)
 This macro must be placed inside a block implementation file. More...
Variables
class UHD_RFNOC_API uhd::rfnoc::block_ctrl_base
 Base class for all RFNoC block controller objects. More...
◆ UHD_RFNOC_BLOCK_CONSTRUCTOR
#define UHD_RFNOC_BLOCK_CONSTRUCTOR (   CLASS_NAME)    CLASS_NAME##_impl(const make_args_t& make_args) : block_ctrl_base(make_args)
◆ UHD_RFNOC_BLOCK_OBJECT
#define UHD_RFNOC_BLOCK_OBJECT (   class_name)    typedef boost::shared_ptr<class_name> sptr;
◆ UHD_RFNOC_BLOCK_REGISTER
#define UHD_RFNOC_BLOCK_REGISTER (   CLASS_NAME,
  BLOCK_NAME
Value:
block_ctrl_base::sptr CLASS_NAME##_make(const make_args_t& make_args) \
return block_ctrl_base::sptr(new CLASS_NAME##_impl(make_args)); \
UHD_STATIC_BLOCK(register_rfnoc_##CLASS_NAME) \
uhd::rfnoc::block_ctrl_base::register_block(&CLASS_NAME##_make, BLOCK_NAME); \
static void register_block(const make_t &make, const std::string &name)
