FPGA IP Blocks
RFNoC Blocks
The RFNoC FPGA IP blocks that ship with UHD are listed below. These blocks can be incorporated into a custom FPGA design by instantiating them in the respective image core yaml file that defines that FPGA design.
In-Tree Blocks
The list of RFNoC IP blocks that are maintained within the UHD repository are listed below.
Name (Link to Documentation) File Name Description
Add / Subtract (Manual) addsub Computes the sum and the difference of two input streams
Digital Down Conversion (Manual) ddc Frequency shift and integer sample rate down conversion
RAM FIFO (Manual) axi_ram_fifo A large FIFO buffer that uses DRAM on the USRP for storage.
Digital Up Conversion (Manual) duc Integer sample rate upconversion and frequency shift
FFT (Manual) fft (i)FFT with cyclic prefix insertion and removal
FIR Filter (Manual) fir_filter FIR filter with compile time configurable length and run time configurable filter coefficients
Fosphor (Manual) fosphor Computes histogram and waterfall of FFT-converted input packets
Keep One in N (Manual) keep_one_in_n Keeps 1 sample or packet and drops the following N-1 samples or packets
License Checker (Manual) license_check Reads and evaluates license keys
Log Power (Manual) logpwr Computes an estimate for 1024 * log2(i^2 + q^2) of a complex-valued input sample
Moving Average (Manual) moving_avg Computes the moving average of an input stream.
Null Source / Sink(Manual) null_src_sink Acts as FPGA data source, sink or input-output loopback
Radio (Manual) radio Interface between RFNoC framework and RF hardware, providing radio control and data streaming capabilities
Replay (Manual) replay Records data to DRAM memory or plays data back from DRAM memory
Signal Generation (Manual) siggen Generates constant, sinusoidal or uniformly distributed noise signals
Split Stream (Manual) split_stream Replicates a single input stream into multiple output streams
Switchboard (Manual) switchboard Routes any single input to any single output
Vector IIR (Manual) vector_iir IIR filter with a single feedforward and feedback tap and a variable delay
Window (Manual) window Multiplies an input signal by a shaping function (window)
Out-Of-Tree Blocks
Out-of-tree blocks are RFNoC blocks that are developed and maintained outside of the main UHD repository here: https://github.com/EttusResearch/rfnoc-oot-blocks
Aurora (Manual, Getting Started) aurora Remote Tx / Rx streaming between X4xx and non-UHD (FPGA) devices using the Aurora protocol
